Wish list for Sketchup 2018
Got an idea to improve SketchUp?
Re: Wish list for Sketchup 2018
Postby juju » Tue Mar 07, 2017 8:28 am
GMthompson wrote:i am voting for the use of dwg's with layout insertion of pdfs into layout and sketchup, also coming from a non developer or programming knowledge why do dimensions not import "if you have turbocad pro you can workaround that dimensions import"
yep, I've requested the ability to insert DWG's in LO before, it's really a must-have if you're pitching the software to professionals. The DWG's imported into SU looses a lot of information that I would like to have when I'm coordinating information.
User avatar
juju
Premium Member
Premium Member
Postby sanya_pp » Thu Mar 09, 2017 10:20 pm
The main thing that Sketchup must have is true curves, not a series of line segments, true circles, true arcs and so on, like in Autocad. And the main is a real NURBS ! Why it is important ?! Because these features will give a powerful possibilities to do your modeling more efficient, faster and better looking ! And your model will looks like more realistic, and not like a low-poly sh&%, it will looks more professional, and not like a "kid drawings" !
Seriously, why this very important thing is not still in Sketchup, Sketchup will never be a real CAD (or nearby) without it !
P.S. sorry for my bad english, but I really want it for so long time, and new versions of SU have nothing REAL"new" since Google dropped it to the Trimble, so i decided to post right here
sanya_pp
Postby juju » Fri Mar 10, 2017 12:25 pm
So you do not consider 64 bit version and a new rendering engine anything new? I agree with the need for true curves though, not sure about nurbs...
-1
User avatar
juju
Premium Member
Premium Member
Postby ntxdave » Fri Mar 10, 2017 5:48 pm
I would also like to see something like real solids in that when you do a section cut you do not get the front and back face with a blank gap in between.
Hope that makes sense.
User avatar
ntxdave
Postby cuttingedge » Sat Mar 11, 2017 4:38 am
MULTIPLE VIEWPORTS -(extra window that can be turned on and off)...I wished this in every release despite many people not convinced about it. But there is no reason every professional 3d software keep it without its good use! Its always good to see your meshes in different angle while you edit...
cuttingedge
Postby JQL » Sat Mar 11, 2017 12:30 pm
I'd like LO tools to behave like SU tools and to have drafting tools in LO that are missing like fillet, trim and extend.
I'd also simply LOVE to be able to control SU's linestyles.
Finally I'd like to have flawless DWG in/out from Sketchup and Layout:
1 - Layers:
- SU would import each layer into a group with all objects in Layer0 and the layer applied to groups;
- A material would be created for each layer with the corresponding color of the layer and applied to the group;
- LO would export every SU line in it's corresponding layer besides exporting the LO layers.
- SU layers would go to model space, LO layers would go to paperspace.
- Section cut profiles would export in it's own layer from LO as they do in SU.
2 - Texts:
- Would import into Sketchup flawlessly;
- It would be cool if the point of insertion would be kept and we could pick it (I'm thinking on topo drawings which have texts to mark heights)
- Import into LO.
3 - Dimensions:
- Would import into SU;
- Into LO too.
4 - Hatches:
- Would be imported into SU and converted into grouped faces with hidden lines and each hatch would have a corresponding material with or without texture, named after the name of the hatch pattern.
- Into LO the same thing could happen.
- Export
5 - Leaders:
- Would be converted to SU or LO leaders;
User avatar
JQL
Premium Member
Premium Member
Postby sanya_pp » Sun Mar 12, 2017 7:55 pm
juju wrote:So you do not consider 64 bit version and a new rendering engine anything new? I agree with the need for true curves though, not sure about nurbs...
I mean that SU must be a still easy modeler as many years ago, but with a new BASIC features that have other BIM/3D/CAD or half CAD products, and these features will not be obligatory, so you will have two ways to create your models: 1). as newbie, who wants fast and simple model with basic instruments as usual, 2). as a professional user, who requiers more powerful/specialized instruments for it's job to create architectural/sculpture/mechanic models and even masterpieces with ease of SketchUp.
64bit and new rendering engine, that's not what I've waited for, that is not "WOW things" in this case.
sanya_pp
Postby zain01 » Fri Mar 24, 2017 11:32 am
I would like to customise my tools bars on Mac like they can be in windows. Floating toolbars are a bit annoying and time consuming moving them around.
-1
User avatar
zain01
Postby zain01 » Fri Mar 24, 2017 11:36 am
A button for locking the orthographic view when working in 2d would be helpful.
Would make panning around easier. If i accidentally orbit i have to click on plan view button again to align the view again. Also maybe being able to rotate the view locked in orthographic would be useful.
User avatar
zain01
Postby drafter » Fri Mar 24, 2017 2:36 pm
A program loading Progress Bar such as found in Windows. No big deal.
drafter
Postby ezlde » Fri Mar 31, 2017 9:23 am
in older versions there could be found LINE TO FACE plugin, that made face from single line, like push/pull for faces, just for line and face could be pulled to any direction, now with the "older extensions won't apply in the warehouse" that usefull plugin nowhere to be found and is so missing, would be great to recreate again this tool
ezlde
Postby pbacot » Fri Mar 31, 2017 5:11 pm
ezlde wrote:in older versions there could be found LINE TO FACE plugin, that made face from single line, like push/pull for faces, just for line and face could be pulled to any direction, now with the "older extensions won't apply in the warehouse" that usefull plugin nowhere to be found and is so missing, would be great to recreate again this tool
I use extrude tools for this now, or Vertex tools ($). You can draw out a face with one edge or multiple edges.
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
Postby bobrsta » Fri Mar 31, 2017 10:54 pm
I may have posted this request before, but I'd really like the ability to "Lock" an object yet still be able to hide it. Locking should keep me from moving it, deleting it, changing any attribute - except visibility. I understand that layers are the main way that SU handles visibility, but my models have well over 100 layers now and if I was to create a layer for every single entity that I may want to randomly and temporarily remove from view (blocking something I'm looking at / modeling), I'd have thousands of layers. As it is, I must either unlock / lock an object every time its in the way of modeling something else, or risk moving it inadvertently and not discovering that until who knows when and after who knows how many objects have been modeled based on it. Which happens too often.
Another request, I often create a group or component, move to a layer, then hit the "m" key to move the object into place. Except I just created a layer "m" instead. I can't tell you how often I do that each and every day. In order to make that work flow work, I have to deselect my object, then reselect it! Find a way to make that work better, please, such as requiring that I actually hit the "+" in the layer window.
Another request, if anyone from Trimble watches this forum, some awareness in the program about where current modeling is taking place - as in, I often start to model something (usually piping or ductwork diagram with 3Skeng tools) in close and in perspective 3D. I then go to top view parallel so I can see my end point. I find that I have to scroll waaaay out and then back in on my modeling location. To have the top view / parallel automatically be over where I last was in the model would be superb!
Whew, glad to get those off my chest.
Bob
bobrsta
Premium Member
Premium Member
Postby sketchgirl1 » Sat Apr 22, 2017 7:43 pm
My concern is for the artistic direction of SketchUp. For instance, the new orbit symbol isn't as nice as the last one, not even as descriptive. And we have to use this constantly. The "architectural design style" style isn't exactly the same, and not as nice. It can be changed to be more like the original, but why was it changed? It just doesn't seem like a truly artistic person is making decisions for Trimble or is on the staff.
sketchgirl1
Postby sketchgirl1 » Sat Apr 22, 2017 7:52 pm
But I love SketchUp!
sketchgirl1
Postby db11 » Sat Apr 22, 2017 10:45 pm
bobrsta wrote:I often create a group or component, move to a layer, then hit the "m" key to move the object into place. Except I just created a layer "m" instead. I can't tell you how often I do that each and every day.
Bob
Agree with all of your points, but have little faith that they'll ever be addressed.
Just finished writing a short rant at the other forum on a similar theme — the number of times a day I accidentally rename layers and components (usually with "m") because SU doesn't release focus on pressing enter — it highlights the entered text instead.
bobrsta wrote:To have the top view / parallel automatically be over where I last was in the model would be superb!
Bob
An available solution to your last request is provided by the Eneroth Relative Top View plugin, which works pretty much exactly that way. (If only she was designing the SketchUP UI I'd be so happy :) ... I'm a big fan of her work and her way of thinking)
db11
Postby SJS66 » Sun Apr 30, 2017 1:26 am
Not having to Save As a component, then open the component file, draw a line then erase it, just to give yourself credit for the work you have done. What pain in the **** that is! Automatic credit if you are logged in or something similar to save having to go through this time consuming exercise.
User avatar
SJS66
Premium Member
Premium Member
Postby pipingguy » Fri May 05, 2017 3:35 pm
Would like to strike the spacebar to activate last tool used.
pipingguy
Postby pbacot » Fri May 05, 2017 4:30 pm
pipingguy wrote:Would like to strike the spacebar to activate last tool used.
Yes. I've wanted this for a long time. I would like to be able to assign a key. I use the return key in other apps, and if it doesn't interfere with anything, I'd use that. The space bar may be used by people in SU for the selection cursor (or NO tool).
User avatar
Top SketchUcator
Postby driven » Sat May 06, 2017 3:16 pm
pbacot wrote: I've wanted this for a long time.
there's been a plugin around since v7, but the mac version is just code, hidden in the thread...
http://sketchucation.com/forums/viewtopic.php?p=135218#p135218
it can only work with SU Tools because a large majority of plugins aren't even 'Tools', but a stream of macro commands...
I would also rather they fix the 'Return' key to work properly with the various input boxes than allow us to use it for a shortcut...
@ piping guy, without the Spacebar for 'Select Tool' as the default behaviour, my modelling would slow to a crawl...
driven
PluginStore Author
PluginStore Author
Postby JQL » Sat May 06, 2017 4:21 pm
driven wrote:@ piping guy, without the Spacebar for 'Select Tool' as the default behaviour, my modelling would slow to a crawl...
Me too, but if it could be configured by user both could set it up as wished.
I don't understand why some commands are hard built into some keys...
User avatar
JQL
Premium Member
Premium Member
Postby driven » Sat May 06, 2017 5:23 pm
JQL wrote:I don't understand why some commands are hard built into some keys...
without the hard coded defaults they can't appear in menus or Help files...
you would also need to set all of them from scratch...
you can change any of the SU ones [on a mac] if you think the choice of key is illogical...
driven
PluginStore Author
PluginStore Author
Postby JQL » Sat May 06, 2017 8:09 pm
driven wrote:you can change any of the SU ones [on a mac] if you think the choice of key is illogical...
You're right!
What a Duh moment from me!
Somehow I was under the impression that Sketchup had some hardcoded keys that you couldn't change ever. Like "M" for the move tool. But that's not true, of course, I changed many of them myself.
What was I thinking?
I'm almost sure I had a key that I wanted to change but could not... maybe it was another software!
User avatar
JQL
Premium Member
Premium Member
Postby veerlexyz » Sun May 07, 2017 9:47 am
- Possibility to hide scenes in the toolbar (checkmark icon above "include in animation" in scenes-tab in default tray?)
- Possibility to put (less used) plugins (+ icons) in a library folder in the default tray
veerlexyz
Postby JQL » Sun May 07, 2017 1:14 pm
veerlexyz wrote:- Possibility to hide scenes in the toolbar (checkmark icon above "include in animation" in scenes-tab in default tray?)
And be able to group them... Scene Groups and ability for users to define where the plugins show up, overriding the defaults.
User avatar
JQL
Premium Member
Premium Member
Postby sicksickisck » Tue May 09, 2017 9:22 pm
:bounce: Blender/Cycles render engine + node wrangler/ in Sketchup! this is sound like Christmas...
User avatar
sicksickisck
Postby pipingguy » Wed May 24, 2017 12:26 pm
bigger close-out button for model info box.
pipingguy
Postby TBoy » Thu May 25, 2017 5:18 pm
In "Metric world" it is usual length to be measured in cm or mm, but area in sq.m or bigger units (not sq.cm or sq.mm) that's why in "Model Info > model units" must be separate independent field for area units.
6
TBoy
Postby pep75 » Mon Jun 05, 2017 9:08 am
Please add Material NAMES in the materials list!!! Now you've to hoover over to see its name. I can't believe that they still haven't done so. :(
User avatar
pep75
Postby pipingguy » Fri Jun 16, 2017 4:28 pm
A choice for non-instantaneous transitions when toggling between camera views would be good. (just like the adjustable scene transitions)
pipingguy
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to SketchUp Feature Requests
Who is online
Users browsing this forum: No registered users and 0 guests
Visit our sponsors:
