by BryanHL » Mon Apr 17, 2017 2:39 pm
Hi, I am just learning Ruby... Given arrIcosaVtxs = Array.new(12, Array.new(3))I can assign like this - Code: Select all
arrIcosaVtxs[0] = [Geom::Point3d.new(0, 0, 0), Geom::Point3d.new(1.m, 0, 0), Geom::Point3d.new(0, 1.m, 0)]
but this - Code: Select all
arrIcosaVtxs[0, 0] = [Geom::Point3d.new(0, 0, 0)] arrIcosaVtxs[0, 1] = [Geom::Point3d.new(1.m, 0, 0)] arrIcosaVtxs[0, 2] = [Geom::Point3d.new(0, 1.m, 0)]
fails here component.entities.add_face(arrIcosaVtxs[0]) ; # returns a FaceI am happy to use what works, just wondering why... Q2 I lifted the add_face code from a tutorial. In the tute the author assigned the result to a variable. newface = new_comp_def.entities.add_face(points) ; # returns a Face I have removed the assignment assuming I can access a face in the entities later if need be? Q3 Also, is it possible to create all my geometry and add to a component later? Q4 And possible to make a created component appear in the tray? thx...
BryanHL
- Name: Bryan
- Operating system: Windows
- SketchUp version: 2017
- License type: Free/Make
- SketchUp use: hobby
- Level of SketchUp: Intermediate
by TIG » Mon Apr 17, 2017 4:31 pm
Q1: Your failing part is setting the array's three elements to three separate arrays - each containing one element [a point]. The working version is setting the array to contain three elements - each being a point. A working version for the failing part would be: - Code: Select all
arrIcosaVtxs[0, 0] = Geom::Point3d.new(0, 0, 0) arrIcosaVtxs[0, 1] = Geom::Point3d.new(1.m, 0, 0) arrIcosaVtxs[0, 2] = Geom::Point3d.new(0, 1.m, 0)
Q2: You don't need to make a reference to that face as you create it. However, it does no harm. Unless it'll be easy to retrieve a reference to that face later on - e.g. it's the only one in that entities collection... Q3: You normally add the geometry into and entities context, so why would you want to add it into one context and move it into another ? Normally you would add the geometry directly into the component definition's entities collection. The only exception to this is if you have a selection of entities [in the current active_entities] and you add a group made from those - that group must also be in the same active_entities... otherwise it'll bugsplat! group = model.active_entities.add_group(model.selection.to_a)After that you could convert the group into a component instance and rename its definition as desired... Q4: Any new definition you add to the model should appear in the Component Browser's model tray...
- Global Moderator
- Name: TIG
- SketchUp version: 2021
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by BryanHL » Mon Apr 17, 2017 4:41 pm
I can answer my first question myself In another language, - Code: Select all
arrIcosaVtxs[0, 0] = (Geom::Point3d.new(0, 0, 0)) arrIcosaVtxs[0, 1] = (Geom::Point3d.new(1.m, 0, 0)) arrIcosaVtxs[0, 2] = (Geom::Point3d.new(0, 1.m, 0))
would be setting the array second dimension elements Just realised that in Ruby, the second digit after the comma above is a count... Tried this and it works - Code: Select all
arrIcosaVtxs[0][0] = (Geom::Point3d.new(0, 0, 0)) arrIcosaVtxs[0][1] = (Geom::Point3d.new(1.m, 0, 0)) arrIcosaVtxs[0][2] = (Geom::Point3d.new(0, 1.m, 0))
BryanHL
- Name: Bryan
by BryanHL » Mon Apr 17, 2017 5:06 pm
Hi TIG, I just posted re my Q1 when I realised what I was doing wrong... Q2: You don't need to make a reference to that face as you create it. However, it does no harm. Unless it'll be easy to retrieve a reference to that face later on - e.g. it's the only one in that entities collection...
There will be many faces. I am creating polyhedrons. You used the word "collection" which was the reason for my post. Is the entities collection an ordered list? As in, if I put 5 in, I can get the 2nd one out from the 2nd position? Q3: You normally add the geometry into and entities context, so why would you want to add it into one context and move it into another ?
I dunno, just learning... I was wondering if the geometry can be created separately. But maybe the methods are only available through the entities context? Lets say I make a face into a component. I have multiple instances of that component, and I want to add them all to a separate single instance component at the end... Q4: Any new definition you add to the model should appear in the Component Browser's model tray...
Thx, I didn't notice it there bcoz no name...
BryanHL
- Name: Bryan
by TIG » Mon Apr 17, 2017 6:26 pm
You can't rely on the ordering of a selection or an entities collection. Also you should never 'loop' through a selection or an entities collection, IF your code will affect the selection or collection - since it's references will 'shift' - use .to_a to free it as an array if you must do this... If you are adding several faces you make a simple empty array at the start: faces = [] Then every time you make a face you can add that into that array. ... face = ... faces << face ... Later on you can access the faces array and its ordering will remain constant.
You can only add geometry into an entities context - so that's either the model.entities [the lowest base level - even if not currently active], model.active_entities [current active context - which might be any collection], or any group.entities or definition.entities ...
In passing, a group is just a special subset of a component. They both have a definition [so does an Image, but we'll not go there yet]. A definition can have instances - placed into some entities context. A component definition can have several instances - changing one changes the others. You can make an instance unique so that editing does not affect its relatives. A group definition can have several instances, BUT editing one of them automatically makes it unique. When iterating a definitions collection you can filter its members using defn.image? and defn.group? to choose or avoid those types...
- Global Moderator
- Name: TIG
- License type: Pro
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Developers' Forum
