[Plugin] Automatic Face Reverser
teşekkürler:)
@tig said:
@sijeljaaf said:
Thank you so much but it doesn't work with my sketchup pro 8
You have to explain how it doesn't work...
Does it download, install, add menu entires, any error messages [on screen or in the Ruby Console?], run as expected but not reverse faces, do it sometimes work, does it work but not work as you envisaged???Once we have a better idea we can think about how we can resolve the issue, clearly it works for lots of people so something must be awry with your setup...
It comes up in the plugin manager but it doesn't appear in the drop down menu for plugins.
If you read the PDF file that came with the plugin you would see on the third page that this plugin shows only in the context menu. It doesn't appear in Plugins or any other the other menus.
Works fine, well done
I'm not seeing the context menu in 2014... this plugin is great!
Baz, Didiers plugins haven't been updated to work with SU2014 but some of them can be fixed. This is one of them. It's a simple edit.
Tig explains how here.
http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=12354%26amp;start=60#p513679 -
Didier has agreed that I might update some of his Plugins available from the PluginStore...
Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=Vbfr It is compatible with v2014 and v2015. -
thanks! very good. 5 stars.
Automatic face reverser? Wonder how it works on a mobius strip...
Thanks for this Plugin
@boofredlay said:
It would generate perpetual energy like the cat and toast in this video
Great video - i love this physics fun
This does not work. I use skp pro 2018. Please include a video on how to use it.
