[Plugin][$] FredoScale - v3.5a - 31 Jul 22
Hi Fredo,
EDIT: I moved this post over to the thread you linked in last reply.
http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=66489
-Terry
Hi Fredo,
EDIT: I moved this message over to this thread (sorry for the mis-post).
-Terry
Just reinstalled FredoScale v2.8a in SU 2017. Working fine, but the Extension Manager says 'Outdated signature'. The LibGFredo6 extension is happily saying 'Signed'.
Does this matter?
It won't keep Fredoscale from working correctly.
NEW RELEASE: FredoScale v2.9a - 24 Dec 16
FredoScale 2.9a is a maintenance release providing a workaround to potential bugsplats encountered specifically with SU2017.
One small limitation in SU2017 is that you can only do one single Radial Bend at a time.
NEW RELEASE: FredoScale v2.9b - 02 Jan 17
FredoScale 2.9b is a maintenance release providing another workaround to potential bugsplats encountered specifically with SU2017, for Radial Bend and Twist when dicer is on.
I was with a guy who had SU 8 : Radial Bending don't display the orange horizontal lines and makes not the rounding volume : only an inclined volume!
I think he needs to activate the dicer
- press F4
- or Contextual menu
What is a dicer ?
The first one is what I was referring to although if you could push it through the strings of the second one, you'd get a similar result.
Sure but more difficult to extract slices of cucumber falling inside!
Good point.
Fredo,
latest release seems to have an issue that at the end of stretching operation and click outside of group, instead of accepting the scale change it springs back to original shape, when I repeat the operation a second time, then the change is accepted. is happening consistently on every drawing.
I am on SU 2015, windows 7.
Any thoughts?
Thanks.
I just tried and I'm not seeing it. Could you upload an SKP file in which this happens?
File attached. If you don't see the behavior when trying to stretch any of the building elements you see here then I must have interference from another plugin.
Which direction are you trying to stretch them in?
Actually, I do see it in your model when I try stretching the large building.
I use the scale to target tool and also I invoke the input dialog box via the TAB key. Either way the issue exists in any stretching direction.
