Power Toolbar (2.5) - fix for 2019
Thank you so much for this great tool collection - I've missed so much !!
(it works great!) -
@onzki said:
Hi, Thanks for sharing this amazing plugins, I installed it via Sketchucation Store (Autoinstall)but how come mine seems lacking? Do I need to uninstall old plugins first? Please see attached screenshot. Thanks!
Funny It's been a year and I have to reply to my own post LOL.. Anyway, for those with similar question like mine here, I finally found where the missing icons are, Euerka! They're under the main menu "HELP->CADFATHER PACK->POWERBARICONS." It took me a year to discover by accident since I don't often scroll down the help menu path.
These are truly amazing plugins, thanks a lot!
Extrude tool fails in sketchup 2017
It does not create surface
please fix it
thank -
These are truly amazing plugins, thanks a lot!sorry, haven't been around - though the answer was on the first post: "- The menu itself is under the Help section, this is due to traffic and it ties up with things to come."
glad you got it working
aware of the glitch with extrude and 2017. busy at present, but as soon as i get some time to dive into the code again, i'll post a working update
Ciao Max!
Ciao Rich, hope you're good! : )
Great! Looking forward to it!
posted a new update - should be working with 2017 (thanks to TIG).
also just to let you know, i hope to be working on a fuller update sometime in the new year.
Cheers
Great, thank you!
this plugin makes my work faster..thanks alot
LOL, I was too lazy to read! I miss that one. I'll charge this to my Duh moments.
hi
I have installed and uninstalled several times but the whole powerbar just doesn't show up in my SU 2015. what are my options? -
@nickweboffer said:
hi
I have installed and uninstalled several times but the whole powerbar just doesn't show up in my SU 2015. what are my options?did you remember to go to View > Toolbars and check that the toolbar is selected?
Hello,
I have a small issue with one of the functions and I wonder if anything can be done about it. It's about the "Equalise Curves" tool, which is very handy in certain situations, but whenever I use it, one end of the curve moves a little. I am only using "Divide by number", not by length, but it happens in both modes. Is it possible to change it so that both ends stay in their original position? Or is there another plugin which can do that? Unlike other tools in this collection, I can't find a corresponding separate plugin for this function. And for example Fredo6's Curvizard can only simplify contours by angle, but not equalise the segments.
Hi Pherim, i'll have a look at it, though that might be a while as i'm away
Thank you! Also, sometimes it does not redraw the curve, but it just disappears.
Then I get this error in the Ruby Console:
Error; #<ArgumentError; Not enough points - at least 2 required> C;/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb;3841;in `add_curve' C;/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb;3841;in `main' C;/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb;578;in `block in <module;Max_Coppoletta>' SketchUp;1;in `call'
JHS powerbar 2.4 + su17! What was the problem?
thanks for the wonderful plugin! very useful. I have a problem with the "extrude lines" tool. it does not work correctly. when I specify the height to which you want to squeeze a curved line, it does not squeeze it out, but simply moves it with copying. Do you know why this is so?
Silly question: Does it work with the latest SU?
Hi…
I have a question about extrude line in JHS Power Bar plugin. I have tried to create a line and select the line, then click on extrude line in that plugin, but it didn’t extruded as seen in youtube tutorial, it was only an offset from first to second point with the same line, there is no any extrusion at all. Please advise me how to correct my steps thanks.please refers to my link : https://ufile.io/fk7et
