SketchUcation Plugin Store
[Plugin] SketchyBevel 0.1(Updated May 11)
Re: [Plugin] SketchyBevel 0.1
Postby Daniel S » Thu May 08, 2008 1:50 am
Thank you Chris!!! Extra line is the solution :enlight: :enlight:
Daniel S
PS. Not very important but when you apply the sketchybevel tool 2 times.. the plugin create a lot of extra lines that are not used and not create faces... is there a way to easily eliminate this lines?
Daniel S
Postby CPhillips » Thu May 08, 2008 4:49 am
Daniel S wrote:Thank you Chris!!! Extra line is the solution :enlight: :enlight:
Daniel S
Only thing you can do is turn off "cap holes" after 1st bevel and then fill them in by hand. Hopefully I can figure out how to eliminate the extra faces in future version.
CPhillips
Postby witjazz » Thu May 08, 2008 5:44 am
witjazz
Postby remus » Thu May 08, 2008 7:14 am
Daniel, you could also try running that CAD cleanup script that was recently released (sorry i cant remeber exactly what its called or who its by :P )
EDIT: this is the one i meant.
remus
Postby Dylan » Thu May 08, 2008 10:51 am
Missed this one while I was away, but a nice present upon my return - Thanks! :thumb:
Dylan
Postby Daniel S » Thu May 08, 2008 11:50 am
remus wrote:Daniel, you could also try running that CAD cleanup script that was recently released (sorry i cant remeber exactly what its called or who its by :P )
Thank you, but it dosen´t work with this lines. I have another old script that removes unused Edges but don´t delete this ones.
It´s not a big problem, but when you use soften edges this lines affect the model.
Daniel S
Daniel S
Postby David_H » Thu May 08, 2008 3:36 pm
:fro: very cool! :fro:
Merci. Spasibo. Gracias. Danke. Tanks a lot!
If I make it look easy. . .rest assured--it probably is.
User avatar
David_H
Top SketchUcator
Postby Julius » Fri May 09, 2008 10:05 pm
too bad i don't visit the ruby forum...i found a link to this topic in the Kerkythea forum. :oops:
anyway, thanks a lot for this plugin!
Julius
Postby bellwells » Sat May 10, 2008 2:56 am
Chris, this is incredibly useful script. What a stud you are. Thank you very much. In case anybody was wondering, this works in SU5 as well as SU6.
Ron
bellwells
Postby Jon » Sun May 11, 2008 12:03 am
I have a little problem with Bevel and components...
that aside, this script is incredible!!! :ecstatic: :ecstatic: )
Jon
KT Team member
Jon
Postby Dave R » Sun May 11, 2008 2:42 am
Jon wrote:I have a little problem with Bevel and components...
Ah yes, the old "delete the related components" trick. It's a feature. ;)
Actually I see the same thing. It appears that the plugin doesn't appreciate components.
Still, thank you very much for this.
Inspecting mirrors is a job I could easily see myself doing.
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: woodworking
Level of SketchUp: Advanced
Postby CPhillips » Sun May 11, 2008 6:19 am
So the problem is that you cant bevel geometry inside a component?
Ill try to fix that next version.
CPhillips
Postby Dave R » Sun May 11, 2008 12:02 pm
That seems to be half of what Jon was illustrating. The other is that the other instances of the component get deleted and the one that is being edited ends up exploded.
Thanks again for this plugin. :thumb:
Dave
User avatar
Global Moderator
License type: Pro
Postby CPhillips » Sun May 11, 2008 11:18 pm
Dave R wrote:That seems to be half of what Jon was illustrating. The other is that the other instances of the component get deleted and the one that is being edited ends up exploded.
Dave
Oh, That. Yeah Ill fix.
CPhillips
Postby utiler » Sun May 11, 2008 11:33 pm
watkins wrote:Dear Majid,
Remember, the input is in inches. Try using a fraction like 0.01 inches.
Regards,
Bob
Have been following this thread for a while, great ruby!!
Is there a chance of the plug-in being converted to metric for those of us on the other side?
cheers,
purpose/expression/purpose/....
User avatar
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby Jon » Mon May 12, 2008 12:02 am
CPhillips wrote:Oh, That. Yeah Ill fix.
Thanks a lot :ecstatic: :ecstatic:
Jon
KT Team member
Jon
Re: [Plugin] SketchyBevel 0.1(Updated May 11)
Postby CPhillips » Mon May 12, 2008 5:54 am
May 11 update.
-Fixed hang bug if input box canceled.
-Beveling now works inside of groups and components.
-Bevel amount should now be in the set unit format (meters, cm, feet, etc)
-Somewhat better capping of holes. Still far from perfect. Sometimes it still leaves holes so there is a "Cap Holes" right click option.
download/file.php?id=9003
CPhillips
Postby remus » Mon May 12, 2008 6:21 am
Cheers chris, good to see cotinued development :)
remus
Postby utiler » Mon May 12, 2008 6:52 am
champion, Chris!!!
User avatar
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby erikB » Mon May 12, 2008 11:57 am
Thanks very much for the input in metric. !!
erikB
User avatar
erikB
Postby mike d » Mon May 12, 2008 1:39 pm
thanks chris
The grass is always GREENER on the roof.
mike d
Postby modelhead » Mon May 12, 2008 4:02 pm
Thanks again ...great little ruby!!
modelhead
Postby CadFather » Mon May 12, 2008 7:43 pm
fantastic, i used to get some persistent error message at times - end task being the only way out - i'll report if any.. Thank You
now i bevel just about anything.. :geek:
Quarr-IT - SketchUp Training from the Master.. . ;) .
User avatar
CadFather
Postby BubbaLove » Mon May 12, 2008 8:48 pm
This may be a dumb question but when I try to download the file I keep getting it in text format... do I just the delete the .txt from the end of it or just put it in the script folder and it knows what to do? Ohh.. and I am using Safari as my internet browser.
"Success consists of going from failure to failure without loss of enthusiasm." - Churchill
BubbaLove
Postby remus » Mon May 12, 2008 8:53 pm
You'll need to change the file extension to .rb for it to work. Not sure why its downloading it as a .txt though ;) perhaps some of the more apple savy have an answer?
remus
Postby BubbaLove » Mon May 12, 2008 8:55 pm
Figured it out... for some reason Safari downloads it as a txt file for some reason. Worked like a charm in IE even though I don't like using IE. Thanks Remus!
BubbaLove
Postby solo » Mon May 12, 2008 8:56 pm
I use safari on my Mac and .rb's save normally, must be a setting.
My site
Quod gratis asseritur, gratis negatur.
User avatar
Global Moderator
License type: Pro
SketchUp use: other
Postby BubbaLove » Mon May 12, 2008 9:07 pm
I looked at my preferences... everything is the way it is supposed to be. Maybe it is because I'm using Safari on Windows or something. Do they automatically save to your desktop or does it give you an option on where you want to save it?
BubbaLove
Postby solo » Mon May 12, 2008 9:12 pm
Yup to the desktop unfortunately, I hardly use the Mac so it's no big deal really. every now and again I have to clean it all up as I run out of space on desktop.
My site
User avatar
Global Moderator
License type: Pro
SketchUp use: other
Postby REGIS » Wed May 14, 2008 6:49 am
with safari 2 it saves on the desktop but with safari 3 and 10.5 it saves where you want and you can check this in safari's preferences
Never tried safari 3 with 10.4
REGIS
by Ad Machine » 5 minutes ago
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: chelba_anamaria, Flippie123, ioanatoma, sebayo and 7 guests
