[Plugin] QuadFaceToolsRe: [Plugin] QuadFaceToolsJust need an icon...
Re: [Plugin] QuadFaceToolsVersion 0.11.0 is out.
Re: [Plugin] QuadFaceToolsNice!
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
Re: [Plugin] QuadFaceToolsWorking nicely! Very valuable tool for quick and clean quad face modelling.
Could you make it so, that the green / red color is removed when disabling Live Mesh Analysis? That would show clearly, if the system is switched on or off. Re: [Plugin] QuadFaceTools
hm... yea, that's not a bad idea. All though - it would remove the materials completely. It would not restore any materials that might previously been there as it's not being tracked and isn't easily trackable either. Logged in issue tracker: https://bitbucket.org/thomthom/quadface ... oggling-it Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] QuadFaceToolsHello ThomThom,
I'm currently attempting to size a UV texture using the UV Mapping tool with standard measurements (i.e inches 12", 12") but the value is ignored when typed. Did I type the values correctly or miss something else? Thanks. Regards Re: [Plugin] QuadFaceToolsHm... can you share a sample model? Maybe it's related to model units or something. (which version of QFT do you have?)
See attached model. I have the latest version 0.11.0 Re: [Plugin] QuadFaceToolsOh, I see now. The input is accepting input as relative scale - not model units. The input currently represent how many times the texture tiles across the X and Y UV axes.
Thank you for looking at this. I was just converting from metric to standard, but it would be convenient if you could enter the actual model units. Thanks again for a great plugin. Regards Re: [Plugin] QuadFaceToolsVersion 0.12.0
Re: [Plugin] QuadFaceToolsVersion 0.12.0 was made to allow OBJs exported using Mineways read properly in SketchUp:
http://www.realtimerendering.com/erich/ ... /mineways/ Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] QuadFaceToolsThis is my home in minecraft
![]() https://3dwarehouse.sketchup.com/model. ... 3d3de85f27 My website: http://julia-christina-eneroth.se/
Re: [Plugin] QuadFaceToolsAnyone uses OffsetLoop? Whats the best way to use it? I'm getting mostly crashes / bugreport Oops-loops with 0.12.
Re: [Plugin] QuadFaceToolsGot a sample model? Screenshot?
Just a simple box and there we go again. If nobody else has problems I guess its a clash with other plugins. I will try to do a clean install for all my plugins soon. Re: [Plugin] QuadFaceToolsDoesn't have to be a clash. The offset tool is a recent one that was more of an experiment. I had it hidden for a while but people insisted it should be visible by default. But it will have some problems still. I have an open issue to improve or rewrite it.
That being said - I wasn't able to reproduce your exact scenario. Can you share the model please? Also, what version of the extension do you have? Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] QuadFaceToolsI'm using
QFC 0.12.0 TTlib 2.10.6 I attached a file. The shape doesn't really matter though - sometimes it crashes on me on a simple box... Edit 10-10-2016: just cleaned my plugin directory. Installed TT_lib2, QFT, Selectiontoys and tested again. Same crashes so I would suspect no clashing plugins. Re: [Plugin] QuadFaceToolsHmm.... I cannot reproduce on this one either. Can you do a video capture to show your steps?
Here you go - shocking isn't it? I'm thinking I'm wasting your time. There must be something wrong at my end. Although it is strange; only TTlib2, QFT, Selection toys installed (all fresh from SketchUcation tools & TTlib2 from Extension warehouse). SU-pro 16.1.1449 64 bit. Edit + pic: it also crashes after adding a few loops and at some point it doesn't detect the loop anymore (blue line) and...ooops Re: [Plugin] QuadFaceToolsHmm... have you submitted the reports? Did you include your name/email other info?
Also, what version of Internet Explorer do you have installed? The error reporting dialog looks odd. Thomas Thomassen — SketchUp Monkey & Coding addict
I have submitted only a very few (user name Max). Sometimes it caused an oops-loop and I didn't report those either. I'm running win7 x64 on my desktop with IE11.0.9600.18449 Re: [Plugin] QuadFaceToolsI see the issue now. It's when you offset only one edge.
https://bitbucket.org/thomthom/quadface ... g-only-one I also noticed another issue, if you pick an edge at the end of your selection the offset is missing an edge. https://bitbucket.org/thomthom/quadface ... sing-edges Thomas Thomassen — SketchUp Monkey & Coding addict
Both true. Glad you could reproduce the issue. I'm a bit confused nobody has noticed this before. The offset tool itself could be quite useful. Re: [Plugin] QuadFaceToolsAs it is now, consider the OffsetTool an alpha-version. I would not have exposed it yet had it not been for being persistently nagged to do so.
![]() Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] QuadFaceToolsHi All
I just nee a little help how to install the current QuadFace tools correctly, to get access to this cool live mesh analysis feature. I always get the error message (shown below) when I activate live mesh analysis. I also installed the current tt Lib². I´m trying to run Quadface tools within my SU 2015 Make which is my prefered Quad-version with tools like SubD, Vertex tools etc... I appreciate any help - Thanks never trust a skinny cook
Ah, sorry - bad user feedback on my end. The error is due to the functionality being SU2016+ only. Thomas Thomassen — SketchUp Monkey & Coding addict
