Animator Gallery
@Falstaff, if you edit your post and remove the "s" and just make it http:// in the URLthen the videos will show up inline.
@Falstaff I really like you examples of the camera following an object. I am going to work on one for learning purposes but I think you have a perfect example.
@Falstaff: this are really impressing examples for the use of Animator. The walking and gesturing people are well made. The SketchUp design is simple and clear.
click to watch....
interesting that TIG SKMtools works with Animator.
Could you try rendering that with Thea Rich? Please?
No point. The image sequence plays in the viewport so it would not sync with the frame rate.
Only direct viewport recording would work.
Ok, thanks! Then I guess I'll wait for other kind of implementation...
I've got a certain project wich would really benefit from texture animation, particularly .exr/.hdr files for animated hdri skies.
Alas, I will probably learn Unreal engine someday.
Unreal is some more difficult than Unity!
I've seen nicer images from Unreal than Unity. Basically, lighting is better. However I've heard something about Unity having revamped their lighting... Why is it easier?
So, are you saying this would not work with Animator or was you animation generated with Animator?
I'm saying to only way to capture the animated texture is to record the viewport.
Exporting the animation won't export the animation applied with SKMtools.
That is what I thought you were saying. What did you use to create the animated gif?
It's not a gif. It's an image sequence of pngs.
If you google fire image sequence you get a result for them at opengameart
You could even try for water spray to see if you can find something for your car wash
RHas any one worked with Maxwell Render and this plugin?
Would be great to hear the workflow! -
Would be great to hear the workflow!I does not how how to contact Maxwell developers. So today, it is not interfaced with it.
Nice animation. The sound affect adds a lot to it.
Made this animation to illustrate how an action figure of mine transforms. Haven't got it properly rendered yet, but it works.
For reference, the action figure is Trinity.
That's fab!
