[Plugin Beta] Animator - v4.0a - 02 Apr 24
Chri,
Thanks.
I fixed it and republish as LibFredo6 7.0x2 9 Jul 16 (Animator is unchanged)Fredo
Actually, the X2 is not good. Take the 7.0x3.
hi Fredo
the new release don't works for me
When i click on the icon ... nothing !(i use SKETCHUP PRO 2014 AND WINDOWS XP )
Chri
@fredo6 said:
chri,
Can you open the Ruby console to see what is going on
message in Ruby console
Error: #<NoMethodError: undefined method `definition' for #<Sketchup::Group:0x968a150>>
AmbientOcclusionEx v1.9.5. TheaRender v1.5 (from Animator and in Batch from Thea) SketchFX Ex v1.0.6 Twilight Render %(#FF0000)[Pro v3.5]
It's Twilight Render Pro v2.5! (and I suppose also Hobby Version ? )
What is the process for use it with Twilight Render ?
Hi Fredo
I have a problem to ROTATE.
Please , have a look on the next GIF ( clic to anim )Chri
It is my understanding that only the Pro version can be used with Animator. We will have to wait and see when they post the link today.
Idem! Seems there is blend of rotation / Object / General!
@chri said:
Hi Fredo
Thanks for signaling. Fixed.
I think this is just for Pro version.
[attachment=0:yeoqnx06]<!-- ia0 -->GIF_idem.gif<!-- ia0 -->[/attachment:yeoqnx06]Is there a bug there?
I have been rebuilding my Pendulum animation (preparing for Twilight Render) and I have not seen a problem. I thought I did once but went back and redid my sequence and all worked well for me.
Yes same than Chris!
Rotation must be from a point outside the object, but result gives from a point inside the object! -
Rotation must be from a point outside the object, but result gives from a point inside the object!OK - I understand. My rotations were from inside the object.
Rotation must be from a point outside the object, but result gives from a point inside the object!When you pick the pivot, the reference component containing the pivot is highlighted in orange. If you wish a pivot at top of model, then right click and select the option.
OK
Thanks Fredo
In the current version, there is a bug when you capture the Rotation movement, but the transformation is actually created correctly.
Better indeed!
The camera tracking is not working for me - in particular object selection and playback. I am running on a MAC. Video attached.
