[plugin] Clip or Trim Terrain Mesh (Update)
• Page 2 of 2 • 1, 2
Re: [plugin] Clip or Trim Terrain Mesh (Update)Works fine in v8
There's a frontroom and a backroom....reverse faces
Re: [plugin] Clip or Trim Terrain Mesh (Update)Sorry. I'm learning to use google/SU terrain tools as they are quite handy for making large terrains as opposed to Max.
Gaieus helped me out on the Lumion forum and I was able to get everything going. Re: [plugin] Clip or Trim Terrain Mesh (Update)sdmitch,
Thanks for sharing the terrain skirt plugin. Regards,
JGA Re: [plugin] Clip or Trim Terrain Mesh (Update)Hello Experts,
When I use this plugin it tells me to select a Google Terrain patch I have a trianglar mesh terrain file which is very big How can I add a skirt and also add a bottom make it into a solid? I have tried TIG's jointpush and pull tool, but I only manage to do the skirt and cannot manage to get a solid. (Unless manually....but thats too much work) Thanks Michiel Re: [plugin] Clip or Trim Terrain Mesh (Update)
The Add Terrain Skirt plugin on my blog page does not require the mesh to be a Google Earth Terrain.
- So why don't you post the improved plugin (that does not require the mesh to be a Google Earth Terrain) here at Sketchucation? It is a bit easier for people to install it using the Sketchucation Extension Store directly from within SU.
Re: [plugin] Clip or Trim Terrain Mesh (Update)Because I don't want to?
Download from the blog. Send to a compressed folder. change extension from zip to rbz. Install as usual.
Who is online
Users browsing this forum: blajnov and 10 guests
