[Plugin] JointPushPull Interactive - v4.4e - 02 Jun 19Re: [Plugin] JointPushPull Interactive - v3.3b - 09 Jan 15It's poorly drawn at the end near the red axis. If you did a better job of drawing it, Joint Push/Pull wouldn't fail.
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: [Plugin] JointPushPull Interactive - v3.3b - 09 Jan 15HI Dave
I had not checked the lines For this reason,The main tool push&pull was not any problem. I did not know that fredo plugin is more sensitive. thank you ... Re: [Plugin] JointPushPull Interactive - v3.3b - 09 Jan 15I don't know that it's more sensitive but since you have that little triangular loop with no face in it, i'd guess that causes problems. Try this: Scale the entire geometry up by a factor of 1000. make a face on that triangle by tracing one edge of it with the Line tool. Then trying running Joint Push/Pull on the result.
Re: [Plugin] JointPushPull Interactive - v3.3b - 09 Jan 15Hy, I am a bit confused on how to PROPERLY use this plugin... Ok, I understood that I should keep the mouse button pressed while pulling the face, because click will only select/deselect (which is a bit annoying, honestly). But there is a funny behavior AFTER I do the push pull... sometimes (couldn't figure out in which conditions), when I press ENTER it actually CANCEL my pushpull.
Until now, every successful pushpull i did was out of luck... I have no idea how I confirmed the operation, because apparently I do the same thing like when it's canceled. In my opinion it should do better use of ESC and ENTER keys (first to cancel, second to confirm). Also, selection of faces would be best to be key-assisted, as in regular SU behavior. Is very confusing when plugins ask for different commands to do similar SU actions... is like two different programs. Select should be performed the same in native Su and under plugins (same key+mouse combinations), other operations should be similar. Wish you best. DESIGNER AND ARTIST DEREI.UK
I know it is a change of habit, but JPP is not designed to replace the native SU Pushpull either. SU PushPull only acts on a single face. So when you click, the next action is PushPull. In multiface seelction, you cannot do the same, because when you click on the first face, then this face would move / pushpull with the mouse when you will try to select a second face. The only possibility remain is to select with NO click: - if the mouse if over a face and you click, this face is PushPulled - if you press CTRL why hovering over faces (.ie. no click), then these faces are added to the selection. If you then click, the Push Pull applies to all faces selected. This method is also different from Sketchup, which does not have a multi-element selection capability in implicit selection (i.e. just hovering the mouse). Note that I use this method in FredoScale, but I am pretty sure few users noticed or use it. I'll have anyway another look and reflection to see if I can improve the face selection process (the best, when applicable, is to select the faces and then just type the offset, if you don't need a placement by target). Fredo
Re: [Plugin] JointPushPull Interactive - v3.3b - 09 Jan 15I completely understand that this tool is not meant to replace a native SU tool. I was merely talking about the way of use of the similar commands (eg. selecting faces).
But this is not the biggest problem I got into. I could accommodate to it. The problem is that ENTER cancels the push-pull. I do it, i set custom value in VCB, then i press ENTER. And voila: no pushhpull. ![]() Unless there is any reason to assign a canceling to ENTER key. By the way... "before" JPP wasn't behaving like this. It's like this change was introduced recently...couldn't tell which release. Thank you very much, Fredo DESIGNER AND ARTIST DEREI.UK
Re: [Plugin] JointPushPull Interactive - v3.3b - 09 Jan 15I will have a look.
The latest version of JPP is dated 9 Jan 15, so it's not recent, unless there is a side effect from LibFredo6. Did the problem happens when you are extruding a few faces or a lot of faces (with many faces, you have a preview mode)? Fredo
Re: [Plugin] JointPushPull Interactive - v3.3b - 09 Jan 15I just did some quick testing and I'm not seeing any weird behavior with the Enter key. When I type a JPP distance and hit Enter, it makes the adjustment just like the native Push/Pull tool does. Maybe there's something else causing a conflict?
FWIW, I updated LibFredo and the other extensions that got recent updates and according to the Plugin Store and LibFredo, everything is up to date. Etaoin Shrdlu
Re: [Plugin] JointPushPull Interactive - v3.3b - 09 Jan 15I tried to reproduce it now, Couldn't. Will keep an eye on it, as it happened many times while working.
Re: [Plugin] JointPushPull Interactive - v3.3b - 09 Jan 15UNDO issue ...
sometimes when I cancel JPP it lets the geometry with missing faces. Then I undo to get it back to its previous state...the problem is that i have to hit A LOT of UNDOs. Maybe the undo function should be reviewed and pack multiple phases in a single undo command. DESIGNER AND ARTIST DEREI.UK
Re: [Plugin] JointPushPull Interactive - v3.3b - 09 Jan 15Hi, I tried to install it on my PC, and I think it doesn't work on Windows 8.1.
Are you gonna make it work on Windows 8.1 too? Really wanna try your plugin! ![]() Re: [Plugin] JointPushPull Interactive - v3.3b - 09 Jan 15Hail to a very reliable extension which I have used countless times so far to give thickness to my sheets! Good Job!
Today is the first time that I found an error with it. For some reason I cannot give this form a thickness. The ruby error I get is the following: Date: 07-Aug-15 19:49:31 An error occurred in Joint Push Pull Error in generation of the geometry reference to deleted Entity JointPushPullGeometry.rb: 1027 -- entityID JointPushPullGeometry.rb: 1027 -- block in geometry_coplanar_edges_overhang JointPushPullGeometry.rb: 1025 -- each JointPushPullGeometry.rb: 1025 -- geometry_coplanar_edges_overhang JointPushPullGeometry.rb: 354 -- block in geometry_robot_erase_coplanar_edges JointPushPullGeometry.rb: 352 -- each JointPushPullGeometry.rb: 352 -- geometry_robot_erase_coplanar_edges JointPushPullGeometry.rb: 214 -- robot_call_action JointPushPullGeometry.rb: 177 -- geometry_robot_exec JointPushPullGeometry.rb: 160 -- geometry_robot JointPushPullGeometry.rb: 75 -- block in geometry_execute Lib6Operation.rb: 325 -- call Lib6Operation.rb: 325 -- step_geometry Lib6Operation.rb: 367 -- start_execution JointPushPullGeometry.rb: 75 -- geometry_execute JointPushPullTool.rb: 891 -- go_preview_or_geom JointPushPullTool.rb: 697 -- dragging_stop JointPushPullTool.rb: 1319 -- onLButtonUp I have attached the object. Re: [Plugin] JointPushPull Interactive - v3.3b - 09 Jan 15If you JPP OUTWARDS it works OK.
Extruding INWARDS will fail. This is because you have some tiny geometry in the surface - e.g. the segmented edges around the slotted holes semi-circular ends. When extruding 'inwards', SketchUp's tolerance of 1/1000" can cause some tiny edges to be omitted - their start/end points are deemed coincident - then the faces relying on those also fail to be created. But all is not lost... You can JPP INWARDS if you do the following... Make your group into a component. Make a copy of it and Scale that x100. Edit that instance and Preselect its surface. Activate JPP - making x100 allowance in the offset value. It will now extrude successfully. Exit the edit and delete the scaled version. The real size version will also show the JPP changes. Tiny geometry can exist but it cannot be created directly in SketchUp. The "Scale up a copy of a component" trick is a well known workaround for these kinds of issues... TIG
Re: [Plugin] JointPushPull Interactive - v3.3b - 09 Jan 15Hello TIG,
Awesome!!!! That was an excellent reply. It worked. Thanks for the heads up. I recall doing something of the sort in the very distant past but if it weren't for your reminder I would have never gotten there! Thanks again! Peter Re: [Plugin] JointPushPull Interactive - v3.3b - 09 Jan 15Fredo,
We are able to push pull by vector keeping original face orientation or by creating the ending faces as normal to the push pull vector. This is great! Do you think it would be possible to pick any face in the project as the ending faces plane? Thanks and best regards, João
Re: [Plugin] JointPushPull Interactive - v3.3b - 09 Jan 15Joao,
This is technically feasible, but more a matter of UI, which is already complex for users, as you know. I'll see what I can do when I refresh the plugin. Fredo
I understand perfectly. It's also something that would be good to have but that can be achieved manually. I hope you find the time to include it someday. Thanks again, João
Re: [Plugin] JointPushPull Interactive - v3.5a - 13 Nov 15Two changes would be great for this plugin, as it works somehow against "intuition":
-first would be Press RETURN to exit (that's the ENTER key, and usually is used to CONFIRM a action, not to cancel it) - best would be to use ESC Key -second would be the obligation of inserting push value with (-) AFTER the push action was initialized. It is great to let the option there, in case the user really needs to revert the direction, but it would be better that once a number was introduced, to take "by default" the pushing direction already initialized by the user. Another thing is that AFTER doing a JPP operation, I must be very careful what tool or key I press, or I risk to have my operation canceled... this is extremely frustrating, as there is no intuitive action. As I said before, I am tempted to press ENTER - but guess what? I cancel my work. If I press Space Bar (to go to select tool) it happens the same, if I click on screen I also cancel the operation... every time is "lucky guess". In my opinion should be clear: ESC= Abort, ENTER=Commit. Nothing around. To not exit from operation until ESC or ENTER was pressed. This way there is no chance of mistake. I hope this suggestions make sense. Thank you. DESIGNER AND ARTIST DEREI.UK
Re: [Plugin] JointPushPull Interactive - v3.5a - 13 Nov 15Do you have a model where this happens? It must be related to the Preview mode, when you have a lot of faces.
- Enter / Return is used to perform the Push Pull, so that you don't even need to drag the faces. The cursor must be still on one face, since when the cursor is in the empty space, it is used to exit the tool. - Escape does Abort when in interactive mode - Spacebar functions as in any Sketchup tool. If you did not commit beforehands, it simply exits with doing nothing. Fredo
Re: [Plugin] JointPushPull Interactive - v3.5a - 13 Nov 15yes, I had many faces in the model (organic modelling)...
But why there are 2 different uses for ENTER (when cursor on face, or not on face?) Is possible that is why I miss it many times... because i move the cursor around. I am not used to pay attention to it when i don't actively use it to manipulate geometry. Do you think this behavior is actually useful? Thanks for all explanations ![]() DESIGNER AND ARTIST DEREI.UK
Re: [Plugin] JointPushPull Interactive - v3.5a - 13 Nov 15Fredo,
Would it be easy to have normal push pull Taper with an angle or a offset distance instead of exclusivelly by ratio? It would be a nice feature to have for chanfering faces outside their plane with a double click. (I love this double click through groups/components)
See the first post of this thread. It is clearly spelled out with bold type and links. Etaoin Shrdlu
Re: [Plugin] JointPushPull Interactive - v3.5a - 13 Nov 15Hi I'm having a small issue that I can't for the life of me understand.
I'm extruding the wall of a truncated cone, or more like a rounded plate that along with 11 other identical plates will make up the cone. I'm trying to make flanges around the sides of one plate to then instance it, but the sides keep intersecting and I can't seem to control them! ![]() I did manage to get it right at first, but there were some other issues with the model so I have restarted and this time around I can't get it to work. I'm using Joint Push Pull and Round Push Pull. Re: [Plugin] JointPushPull Interactive - v3.5a - 13 Nov 15I'm getting this error message when trying to Joint Push pull:
[/Date: 21-Sep-16 09:11:28 An error occurred in Joint Push Pull Error in generation of the geometry undefined method `smooth?' for nil:NilClass JointPushPullGeometry.rb: 1107 -- block in geometry_coplanar_edges_overhang JointPushPullGeometry.rb: 1105 -- each JointPushPullGeometry.rb: 1105 -- each_with_index JointPushPullGeometry.rb: 1105 -- geometry_coplanar_edges_overhang JointPushPullGeometry.rb: 354 -- block in geometry_robot_erase_coplanar_edges JointPushPullGeometry.rb: 352 -- each JointPushPullGeometry.rb: 352 -- geometry_robot_erase_coplanar_edges JointPushPullGeometry.rb: 214 -- robot_call_action JointPushPullGeometry.rb: 177 -- geometry_robot_exec JointPushPullGeometry.rb: 160 -- geometry_robot JointPushPullGeometry.rb: 75 -- block in geometry_execute Lib6Operation.rb: 332 -- call Lib6Operation.rb: 332 -- step_geometry Lib6Operation.rb: 374 -- start_execution JointPushPullGeometry.rb: 75 -- geometry_execute JointPushPullTool.rb: 892 -- go_preview_or_geom JointPushPullTool.rb: 698 -- dragging_stop JointPushPullTool.rb: 1320 -- onLButtonUp Re: [Plugin] JointPushPull Interactive - v3.5a - 13 Nov 15@pixero
Thanks for signaling. This seems to be an unusual case. Anyway, I have fixed the problem and will re-release soon. Fredo
Re: [Plugin] JointPushPull Interactive - v3.5a - 13 Nov 15Hi. I'm having a problem with the plugin gui showing up really small in SU. See attached picture.
I'm on SU2016, OS X 10.9.5. How can I make it bigger? //Mike Re: [Plugin] JointPushPull Interactive - v3.5a - 13 Nov 15
Mike, If you go to Windows > libFredo6 Settings... > Default Parameters..., you will find an option "Retina Screen" in the section "Palette Configuration". If you check the option, you should get the palette buttons bigger (x 2). However, the text may remain small. If you are OK, and since you are on SU2016, you can help me to see if we can resolve the issue, if you are OK to test some changes in the LibFredo6 library. I was hoping that it would be solved by Sketchup 2017, but that's not the case! Otherwise, other high-dpi screen users have discussed some ways to avoid the issue by system set up. See discussion here. Fredo6
Re: [Plugin] JointPushPull Interactive - v3.5a - 13 Nov 15What may I be doing wrong. Trying to pull up three surfaces sharing three edges.
ate: 30-Nov-16 08:55:30 An error occurred in Joint Push Pull Error in generation of the geometry Could not compute valid matrix from points JointPushPullGeometry.rb:: 1169 -- position_material JointPushPullGeometry.rb:: 1169 -- block in geometry_transfer_material_top JointPushPullGeometry.rb:: 1145 -- each JointPushPullGeometry.rb:: 1145 -- geometry_transfer_material_top JointPushPullGeometry.rb:: 337 -- block in geometry_robot_transfer_material JointPushPullGeometry.rb:: 337 -- each JointPushPullGeometry.rb:: 337 -- geometry_robot_transfer_material JointPushPullGeometry.rb:: 212 -- robot_call_action JointPushPullGeometry.rb:: 177 -- geometry_robot_exec JointPushPullGeometry.rb:: 160 -- geometry_robot JointPushPullGeometry.rb:: 75 -- block in geometry_execute Lib6Operation.rb:: 332 -- call Lib6Operation.rb:: 332 -- step_geometry Lib6Operation.rb:: 374 -- start_execution JointPushPullGeometry.rb:: 75 -- geometry_execute JointPushPullTool.rb:: 890 -- go_preview_or_geom JointPushPullTool.rb:: 696 -- dragging_stop JointPushPullTool.rb:: 1318 -- onLButtonUp MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
Re: [Plugin] JointPushPull Interactive - v3.5a - 13 Nov 15I guessed that although it looked simple, there might be some errant geometry from making the faces. I grouped the faces and ran TT Cleanup3 and that fixed it.
Who is online
Users browsing this forum: Grauer, Marcia Kautz and 19 guests
