SketchUcation Plugin Store
[Plugin] SketchyBevel 0.1(Updated May 11)
Postby CPhillips » Fri May 02, 2008 3:18 am
This plugin is not nearly finished yet. But it will be a little while before I am able to come back to it. So here is an early release, warts and all.
Install
-Put SketchyBevel.rb in your plugins directory.
-Select the faces you want to bevel.
-Right click and select Bevel.
-A dialog will appear.
-Amount is how far to inset the faces in decimal inches.
-Cap holes will attempt to fill in the corners of the bevel with faces. Capping holes is still buggy so you may want to do it yourself.
-Click "Ok" and it should bevel the geometry.
Known bugs
-Works by "shrinking faces" similar to the Outliner tool. If the face shrinks too much it will flip causing the geometry to be incorrect.
-I haven't figured out how to cap the holes in the end of a bevel yet. It works ok for simple shapes but more complex ones are tricky. So there is an option to cap holes or not. If you cap holes you may wind up with some extra faces that are not needed. If not you will have to cap them yourself (not too hard).
-Sometimes faces are backwards and grow rather than shrink. Delete the face and rebuild it by drawing a clockwise line.
-It doesn't yet handle the case where some of the faces in a mesh are beveled and others not.
May 11 update.
-Fixed hang bug if input box canceled.
-Beveling now works inside of groups and components.
-Bevel amount should now be in the set unit format (meters, cm, feet, etc)
-Somewhat better capping of holes. Still far from perfect. Sometimes it still leaves holes so there is a "Cap Holes" right click option.
CPhillips
Re: SketchyBevel 0.1
Postby CadFather » Fri May 02, 2008 5:03 am
Chris, your genius and generosity are very appreciated - Thank you! :enlight:
Quarr-IT - SketchUp Training from the Master.. . ;) .
User avatar
CadFather
Name: Max Coppoletta
Postby TomDC » Fri May 02, 2008 6:03 am
Thank you. :ecstatic:
Bill Maher on the French: "They invented sex during the day, lingerie and the tongue."
TomDC
Postby Jean-Franco » Fri May 02, 2008 6:19 am
Thanks so much Chris. Your'e really GREAT !
Jean-Franco
User avatar
Jean-Franco
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Level of SketchUp: Intermediate
Postby remus » Fri May 02, 2008 6:39 am
Cheers chris, for its current foibles this is still a wicked script.
remus
Postby a4chitect » Fri May 02, 2008 7:46 am
thanks chris, nice little script - great idea with the face shrinking
a4chitect
Postby ilay7k » Fri May 02, 2008 8:32 am
Thank you for this! :ecstatic: :thumb:
Let's assemble own 7 version! :shock: :lol:
ilay7k
SketchUp version: 8
License type: Free/Make
SketchUp use: architecture
Level of SketchUp: Advanced
Re: [Plugin] SketchyBevel 0.1
Postby Daniel S » Fri May 02, 2008 12:42 pm
Thank you Chris!!! :ecstatic: :ecstatic: :ecstatic:
Daniel S
Daniel S
Postby Ben Ritter » Fri May 02, 2008 3:15 pm
Chris, your generosity and talent are appreciated.
Thank you for sharing this.
Ben
Ben Ritter
Postby OTB Designworks » Fri May 02, 2008 4:46 pm
Thanks for this Chris! It is guys like you who keep me from getting too upset about the lack of official SU updates.
Cheers, Chuck
MY BLOG
Become a fan of OTB Designworks on Facebook, we'd love to have you!
3.2ghz 8 core Mac Pro. 10 gig RAM, 8800 GT GPU, dual monitors
OTB Designworks
Postby Pilou » Fri May 02, 2008 5:32 pm
Using seems some easy :fro:
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby craftycurate » Fri May 02, 2008 7:49 pm
AT LAST! Can finally bevel objects which cannot be bevelled using FollowMe.
Cheers
Richard
craftycurate
Postby modelhead » Fri May 02, 2008 7:58 pm
Thanks very much!!....works like a charm!!
modelhead
Postby Marian » Fri May 02, 2008 9:36 pm
THANK YOU!!!!THANK YOU!!!!THANK YOU!!!!THANK YOU!!!!THANK YOU!!!!THANK YOU!!!! :ecstatic: :enlight:
User avatar
Marian
Postby Jon » Fri May 02, 2008 9:48 pm
THAAANK YOU!!! :ecstatic: :ecstatic: :ecstatic:
Jon
KT Team member
Jon
Postby 3eighty » Fri May 02, 2008 9:50 pm
Whats left to say......... :ecstatic:
3eighty
Postby Mike Lucey » Fri May 02, 2008 11:31 pm
....except THANK YOU again :thumb:
User avatar
Mike Lucey
Mayor
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby ely862me » Fri May 02, 2008 11:36 pm
i was waiting for something like this
thx
Elisei (sketchupper)
____________________________________________________________
Come and See EliseiDesign
User avatar
ely862me
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby chippwalters » Sat May 03, 2008 2:26 am
Very much appreciated!
chippwalters
Postby CPhillips » Sat May 03, 2008 4:24 am
You're welcome. :)
Now back to GTA....
CPhillips
Postby lapx » Sat May 03, 2008 6:52 am
Chris you da man! :fro:
Thank you kindly!
lapx
Postby sepo » Sat May 03, 2008 10:33 am
Nifty and very useful script. Thank you for your kindness.
sepo
SketchUp version: 8
License type: Pro
Postby philem » Sat May 03, 2008 10:58 am
From Adelalide, South Australia...
ONYA MATE !!! :)
Just do it, it might be fun.
philem
SketchUp version: 8
SketchUp use: hobby
Level of SketchUp: Beginner
Postby erikB » Sat May 03, 2008 11:47 am
Chris, thank you for this very usefull script !!! :ecstatic: Works as far as I can tell (only tried some simple forms) like a charme. Only, one question would it be difficult to implement a choice between inches and cm for the bevel width ?
erikB
User avatar
erikB
Postby remus » Sat May 03, 2008 10:16 pm
I've found a bug: i tried just beveling a face (should have read the instructions...) and it gives me a dialog saying 'wrong arguement type false (expected array)', the problem is it is impossible to get this dialog to go away, you have to shut SU down form the task manager before you can use SU again.
remus
Postby CPhillips » Sat May 03, 2008 11:29 pm
remus wrote:I've found a bug: i tried just beveling a face (should have read the instructions...) and it gives me a dialog saying 'wrong arguement type false (expected array)', the problem is it is impossible to get this dialog to go away, you have to shut SU down form the task manager before you can use SU again.
Thats too bad. Do you have any idea how to reproduce it? When I try it with a single face it doesn't do that.
CPhillips
Postby remus » Sat May 03, 2008 11:49 pm
heres a quick mock up of the thing that made it crash. I was trying to bevel the top surface, but without hidden geometry turned on.
remus
Postby Jorgensen » Sun May 04, 2008 9:51 pm
Hi Chris
Thanks for this very usefull tool. I one question though, would it be possible to use it in Decimal/millimeters ? It seems to use inches, even if my drawing is set to use millimeters :-(
Jorgensen
Jorgensen
Name: Bo Jorgensen
Postby kwistenbiebel » Sun May 04, 2008 10:40 pm
I just returned from a few days off at sea. Coming home is a delight :), finding this new plugin.
Thank you very much Chris. I'll be trying the script when working on a model for work tomorrow.
Kudos for these nice contributions to the SU community. Appreciated!
Regards,
Kwistenbiebel
kwistenbiebel
Postby spc » Mon May 05, 2008 12:59 am
Thanks Chris for share your talent, :ecstatic:
spc
by Ad Machine » 5 minutes ago
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Premium Members get 20% discount!
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: CadFather, jemoto, r3m, tinnhan333 and 6 guests
