[RELEASE] Beta 0.1.2
General discusson for Skatter for SketchUp
Moderator: jiminy-billy-bob
Postby jiminy-billy-bob » Thu Oct 22, 2015 6:13 pm
Nothing very interesting. This update is just needed for Thea Beta Testers, otherwise Skatter won't work with the latest Thea Beta.
If needed, same serial as before : 6sblp-7GdCN-Z1Y3X-E0O4a
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
Re: [RELEASE] Beta 0.1.2
Postby solo » Thu Oct 22, 2015 6:18 pm
:thumb:
User avatar
Global Moderator
Postby solo » Thu Oct 22, 2015 8:20 pm
Curious, is this version compatible with say there may or may not be a beta version of a new SU?
User avatar
Global Moderator
Postby jiminy-billy-bob » Thu Oct 22, 2015 8:24 pm
Yes ;) (as were previous versions)
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Pixero » Thu Oct 22, 2015 8:42 pm
Now I'm jealous.
User avatar
Pixero
Postby JQL » Thu Oct 22, 2015 9:27 pm
User avatar
JQL
Premium Member
Premium Member
Postby Pixero » Fri Oct 23, 2015 7:52 am
Thanks, Just for information.
After download I got a Windows warning about the zip file may contain malware.
Most probably a false positive but I thought I'd let you know.
Haven't had this with any of the previous versions.
User avatar
Pixero
Postby Pixero » Fri Oct 23, 2015 8:21 am
Hmm... I' having some problems with this version.
All I get when scattering is just one object at origo. :?
User avatar
Pixero
Postby Pixero » Fri Oct 23, 2015 8:28 am
Tried again with a new scene and it was the same. Just one object positioned at origo.
User avatar
Pixero
Postby jiminy-billy-bob » Fri Oct 23, 2015 8:33 am
Are you using the latest Thea beta version? If not, you should go back to the previous Skatter version :-)
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Pixero » Fri Oct 23, 2015 8:38 am
The latest Thea for SketchUp Beta. Yes.
User avatar
Pixero
Postby jiminy-billy-bob » Fri Oct 23, 2015 8:41 am
When was it released?
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Pixero » Fri Oct 23, 2015 8:50 am
RV 335.1387 october 22
User avatar
Pixero
Postby jiminy-billy-bob » Fri Oct 23, 2015 11:46 am
I'm not a Thea Beta Tester myself, so I can't test. I'll check with Tomasz.
In the meantime, can you delete Skatter in your plugins folder and reinstall?
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Pixero » Fri Oct 23, 2015 12:11 pm
Reinstalled and now it seem to work. Could there have been some old files left in the folder that wasnt overwritten?
User avatar
Pixero
Postby jiminy-billy-bob » Fri Oct 23, 2015 12:17 pm
That's possible, although strange.
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby NigeC » Sat Oct 24, 2015 12:37 pm
I get the same as Pixero with the library item at origin, but cleaning out the files didn't help unless I need to remove the loader as well, I'll try that next... nope that didn't work
2014 I can't load library items at all, in theory Skatter should work as its never been installed until today.. its also rendering only at origin
“It’s only impossible if you stop and think about it!”
User avatar
NigeC
Postby NigeC » Sat Oct 24, 2015 2:44 pm
this is what I get:
User avatar
NigeC
Postby jiminy-billy-bob » Sat Oct 24, 2015 4:35 pm
I guess you already tried to delete Skatter files and reinstall?
And reinstall the latest Thea Beta?
This issue can occurs when Thea cannot get the transformations data that Skatter generates. This is a compatibility issue between versions.
That's why Tomasz and I released our latest versions at the same time.
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby NigeC » Sat Oct 24, 2015 6:07 pm
I've had the new version of Thea4SU since the 22nd, its definitely the right one as it has Sketchy Physics support but just to be sure I uninstalled everything including deleting whatever is left over and its just the same, however if I un check "Render Only" then they appear although there is still the stray proxy at the planes origin
Its def the right T4SU version, its Skatter 0.1.2 now installed on 2015 only, I'm running Win10 on a 3770k i7, no extra drives, everything is in the default locations
User avatar
NigeC
Postby jiminy-billy-bob » Sat Oct 24, 2015 6:09 pm
OK thanks I'll check with Tomasz.
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby NigeC » Sat Oct 24, 2015 6:15 pm
The stray proxy was on another skatter list item I thought I deleted .. sorry about that one
User avatar
NigeC
Postby NigeC » Mon Oct 26, 2015 3:51 pm
Tomasz has now fixed the problem :)
User avatar
NigeC
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Skatter
Who is online
Users browsing this forum: No registered users and 0 guests
Visit our sponsors:
