[Plugin]SOLID QUANTIFY v2.5.1 (20131215)
SOLID MATERIAL CHANGER error
Error: #<NoMethodError: undefined method `entities' for #<Sketchup::Edge:0x5f77d44>> E:/Google SketchUp 8/Plugins/solid_quantify2/main.rb:2141:in `selectVolumetrics2' E:/Google SketchUp 8/Plugins/solid_quantify2/main.rb:2130:in `each' E:/Google SketchUp 8/Plugins/solid_quantify2/main.rb:2130:in `selectVolumetrics2' E:/Google SketchUp 8/Plugins/solid_quantify2/main.rb:2141:in `selectVolumetrics2' E:/Google SketchUp 8/Plugins/solid_quantify2/main.rb:2130:in `each' E:/Google SketchUp 8/Plugins/solid_quantify2/main.rb:2130:in `selectVolumetrics2' E:/Google SketchUp 8/Plugins/solid_quantify2/main.rb:2094:in `select_bySOLIDMAT' E:/Google SketchUp 8/Plugins/solid_quantify2/main.rb:2009:in `wd_solid_material_changer' E:/Google SketchUp 8/Plugins/solid_quantify2/main.rb:2141:in `call' E:/Google SketchUp 8/Plugins/solid_quantify2/main.rb:2141
Hi,hebeijianke.
I fix the problems in using Solid Material Changer.
Sorry for keep you waiting long time.
Thanks. -
IMPRESSIVE PLUGIN VERY USEFUL
Nice plugin ..I Like it a lot it will be nice to be able to use Tag and profile columns just like you do with Materials
Thanks -
It would be great if you could add the IFC classifier type to the quantities list.
For example IFC_footings = 300m3. -
is there a version compatible with sketchup 2015 x64?
tak2hata hasn't posted for a while now, I think he's really busy.
What makes you think it is not compatible ?
It has no compiled C add-ons so it should work with either bit-ness. -
Its show me only the total amount (m3). All components are with 0 value for all dimensions. I try to take off the quantity of components and groups made by housebuilder
PM the author...........
