[Plugin] s4u_LineTool
Postby hdpv » Wed Apr 22, 2015 5:28 am
S4u Line Tool v1.2.1
New feature : (request by Glro)
-Draw Construction Lines
-Fix bug for PC use Decimal Symbol ','
French by Pilou :
fr.zip
S4u Line Tool v1.0.0
Draw line from 2 points
Input length with Simple Function (+ ,-,*,/) ex: 2m*3 + 10m/4 + 3m
Snap points: 1/3 Line ,2/3 Line , Center Face...
http://extensions.sketchup.com/en/content/s4u-linetool
http://sketchucation.com/pluginstore?pln=s4u_LineTool
Video:
User avatar
hdpv
PluginStore Author
PluginStore Author
Re: [Plugin] s4u_LineTool
Postby pep75 » Thu Apr 23, 2015 8:07 am
S u p e r! I really mis these simple functions in SU!!
User avatar
pep75
Postby bsfranza » Wed May 27, 2015 8:42 am
hi there,
if you could make the axis constraints work like in the normal su line tool that would be cool. i mean if one hits the up arrow the line is constrained on the blue axis and so on..
also the "preview" (line gets thick) if i hit the shift key - like in the normal su line tool would be nice =)
other than that - great addition - a lovely thanks for giving it to us
bsfranza
Postby hdpv » Thu May 28, 2015 4:47 am
I had updated lock axis by Arrow ,try again!
User avatar
hdpv
PluginStore Author
PluginStore Author
Postby pilou » Thu May 28, 2015 9:43 am
What is the tool at 0.17 ? (video first post)
Speedy Galerie
User avatar
Top SketchUcator
Postby hdpv » Thu May 28, 2015 1:37 pm
User avatar
hdpv
PluginStore Author
PluginStore Author
Postby pilou » Fri May 29, 2015 12:31 am
Thx for the info! :fro:
It's always amazing to make fractal volumes in 3 seconds with your crazzy SU4 to Components! 8-)
Speedy Galerie
User avatar
Top SketchUcator
Postby hdpv » Fri May 29, 2015 2:11 am
imagine! like spaceship :)
User avatar
hdpv
PluginStore Author
PluginStore Author
Postby glro » Thu Jun 18, 2015 9:26 pm
hdpv wrote:S4u Line Tool v1.0.0
Video:
additions and other operations don't work when unit is meter?
glro
Postby hdpv » Fri Jun 19, 2015 3:09 am
It's work ok in meter units
User avatar
hdpv
PluginStore Author
PluginStore Author
Postby glro » Sat Jun 20, 2015 9:04 am
hdpv wrote:It's work ok in meter units
i notice on your video, that the unit (cm) follows the number; on my computer, no unit, only the number
i use meters
if i type a number in the VCB rectangle, sketchup understands it meters, OK
but if a type an addition of 2 numbers, the plugin undeerstands it in inches or something, because the distance is much smaller
maybe there is a parameter i missed...
glro
Postby hdpv » Sun Jun 21, 2015 5:37 am
Hi Glro!
This problem is decimal symbol in your PC.
I will fix it.
User avatar
hdpv
PluginStore Author
PluginStore Author
Postby glro » Sun Jun 21, 2015 8:38 am
hdpv wrote:Hi Glro!
I will fix it.
yes
you fixed it
thank you! big improvement for all french keyboard users...
you plugin is much better than the native line tool now...
glro
Postby cotty » Sun Jun 21, 2015 8:45 am
Nice plugin. Have you thought about adding more snap point, golden ratio for example?
User avatar
cotty
Top SketchUcator
Postby hdpv » Sun Jun 21, 2015 12:38 pm
@Cotty : It's possible.
User avatar
hdpv
PluginStore Author
PluginStore Author
Postby glro » Sun Jun 21, 2015 2:02 pm
hdpv wrote:@Cotty : It's possible.
snap to 1/4 would be nice too
glro
Postby hdpv » Mon Jun 22, 2015 3:23 am
Snap 1/4 nearby 1/3,it's not good for quick select.Other,1/4 same 2 times middle
User avatar
hdpv
PluginStore Author
PluginStore Author
Postby pilou » Wed Jul 08, 2015 12:48 am
French Version ;)
PS Another time, the Tool Bar don't appear after the translation! :shock:
(icon was present before the translation! Of course Tool Bar is enabled in the Tool bar Menu!)
Speedy Galerie
User avatar
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
cron
Who is online
Users browsing this forum: No registered users and 6 guests
Visit our sponsors:
