[Plugin] Scaling to_cm (UPDATED 15/02/2016)
Postby sahi » Thu Jul 31, 2008 3:13 pm
Changes in the size of the selection or groups or components
mashtab_7.rbz
sahi
PluginStore Author
PluginStore Author
Re: Scaling to_cm
Postby pav_3j » Thu Jul 31, 2008 3:30 pm
sorry i'm confused, is this a scaling ruby?
pav
Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
pav_3j
Re: Scaling to_cm
Postby sahi » Thu Jul 31, 2008 3:38 pm
changes a model size.
sahi
PluginStore Author
PluginStore Author
Re: Scaling to_cm
Postby pav_3j » Thu Jul 31, 2008 3:41 pm
ah i see! i shall have a tinkle and see how i get on.
pav
pav_3j
Re: Scaling to_cm
Postby urgen » Thu Jul 31, 2008 3:53 pm
...it is "resize tool" more.. by axis... Useful idea,SAHI! :D
--pupil forever...------
User avatar
urgen
Re: Scaling to_cm
Postby stanmarsh » Thu Jul 31, 2008 4:34 pm
hi sahi thanks for this ruby! :ecstatic:
is there anyway to change it to meters?
stanmarsh
Re: Scaling to_cm
Postby sahi » Thu Jul 31, 2008 6:28 pm
stanmarsh wrote:is there anyway to change it to meters?
meters
mashtab.zip
sahi
PluginStore Author
PluginStore Author
Re: Scaling to_cm
Postby Didier Bur » Thu Jul 31, 2008 10:15 pm
This doesn't work here: it gives weird results, out of range, entities are moved elsewhere. If entities are not grouped at start, there are grouped at the end.
Am I missing something ???
Before/After a scale of 2:
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
User avatar
Didier Bur
Re: Scaling to_cm
Postby sahi » Fri Aug 01, 2008 7:50 am
changed the names in a script
Menu > Plugins > Resizer
sahi
PluginStore Author
PluginStore Author
Re: Scaling to_cm
Postby N Lindenthal » Fri Aug 01, 2008 12:08 pm
On Mac I did not see the scaling tool palette. Is it Menu > Plugins > Scale?
N Lindenthal
Re: Scaling to_cm
Postby Didier Bur » Fri Aug 01, 2008 12:35 pm
Dialog is ambiguous: "on all of axes" is not a target size but adds entered size to actual size. The final size would be better IMHO ?
Why choosing the bounds center as the center of transformation ?
I suggest not to use "to_cm" or "to_m" in the code, but to use only Length type variables. Thus you will suit everyone's unit, no matter what it is.
Useful script, though.
Didier Bur
User avatar
Didier Bur
Re: Scaling to_cm
Postby sahi » Fri Aug 01, 2008 1:27 pm
Didier Bur wrote:Hi,
"on all of axes" ---How to name???
corrected all of other as you specified
sahi
PluginStore Author
PluginStore Author
Re: Scaling to_cm
Postby Didier Bur » Fri Aug 01, 2008 3:37 pm
Correct me if I'm wrong, but the resize operation works only for faces in XY,XZ and YZ planes (red,green,blue) ?
"On all of axes" -> "In every direction" ? English speaking people please help !
Another enhancement is to encapsulate in an operation for one step undo:
Code: Select all
def mashtabirovanie_create
Sketchup.active_model.start_operation "Resize"
ss=Sketchup.active_model.selection
Sketchup.active_model.select_tool(nil)
Sketchup.active_model.commit_operation
Didier Bur
User avatar
Didier Bur
Re: Scaling to_cm
Postby sahi » Fri Aug 01, 2008 3:52 pm
Didier Bur wrote:
Code: Select all
Thank you! Corrected a code.
Added an icon.
mashtab_3.zip
sahi
PluginStore Author
PluginStore Author
Re: Scaling to_cm
Postby CadFather » Fri Aug 01, 2008 5:24 pm
..growing into a nice little ruby.
User avatar
CadFather
PluginStore Author
PluginStore Author
Re: Scaling to_cm
Postby ilay7k » Fri Aug 01, 2008 7:11 pm
Equal "In every direction" is global settings for object of selection(world scaling system in most graphic packages...in attached pic, like cinema4d)
or about directions of red,green,blue, Didier, you are right/something like object system/
ilay7k
Re: Scaling to_cm
Postby marcosrodrigues » Fri Aug 01, 2008 7:14 pm
Simple and very useful. Thank you!
| menos é mais
marcosrodrigues
Re: Scaling to_cm
Postby Fletch » Sat Aug 02, 2008 6:49 am
I would replace the "on all of axes" line with a checkbox called 'lock aspect ratio' as shown in attached. or just change the name to 'uniform scale'.
Fletch
Twilight Render
Re: Scaling to_cm
Postby sahi » Wed Aug 06, 2008 6:36 pm
Fletch wrote:I would replace the "on all of axes" line with a checkbox called 'lock aspect ratio' as shown in attached. or just change the name to 'uniform scale'.
mashtab_4.zip
sahi
PluginStore Author
PluginStore Author
Re: [Plugin] Scaling to_cm
Postby unclebim » Thu Jun 07, 2012 9:17 pm
I don't get what should I input in the Lock aspect ratio box in order to get the selection scaled proportionally to exact dimension input in one axis?
User avatar
unclebim
Postby Zacchia » Tue Jun 11, 2013 7:38 pm
I like it. Thanks!
Zacchia
Postby chialiang168 » Tue May 19, 2015 5:51 pm
尺寸不正確
Size is not correct
User avatar
chialiang168
Postby cotty » Tue May 19, 2015 5:56 pm
Perhaps your bounding box has a different orientation than the box itself?
User avatar
cotty
Top SketchUcator
Postby juju » Wed May 20, 2015 12:31 pm
cotty wrote:Perhaps your bounding box has a different orientation than the box itself?
that would no sense if the plugin measures the bounding box instead of the geometry
21 Sept. 2020. Please support this thread on the SketchUp forum to resolve Extension Warehouse problems. Faults being ignored is not an option.
User avatar
juju
Premium Member
Premium Member
Re: [Plugin] Scaling to_cm (UPDATED)
Postby sahi » Mon Feb 15, 2016 11:04 am
Updated the plug-in in the first message
sahi
PluginStore Author
PluginStore Author
Re: [Plugin] Scaling to_cm (UPDATED 15/02/2016)
Postby designerbursa » Tue May 21, 2019 10:54 am
alternative svg icon
User avatar
designerbursa
Postby TeamCVZ » Wed Sep 11, 2019 3:27 pm
Should it work with SU19 ?
TeamCVZ
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: Bing [Bot] and 16 guests
Visit our sponsors:
