[Plugin] Position_shadows_v1.2 112610
Postby honoluludesktop » Sun Nov 28, 2010 8:14 pm
position_shadows_v1.2.zip
Unzip files. Place "hdt_folder" and "Position_shadows.rb" in the Sketchup "plugins folder".
From the Sketchup menu, select View > Toolbar, and check "Position Shadows" to turn on the plugin's toolbar icons. Please note the menu bar location is moved from "File" to "Tools".
The sun shadows resulting from this application, may be placed anywhere on the model for presentation purposes. The menu's arrow icons move the shadows in gross increments. Although sketchup's date, time shadow control data have no meaning with this application, use these controls to fine tune the shadow's positions.
If necessary, go to Window > Model Info, select Geo-location, and select your model's location to return the shadow's behavior to the model's selected location. If you require accurately placed shadows, geo-locate the model, and use the native Sketchup shadow controls.
11/28/2010 - v 0.1 Beta release
11/30/2010 - v 1.0 More elegant math, and removes views with sun below horizon.
12/19/2010 - v 1.2 Move menus to tools, and other small improvements.
Last edited by honoluludesktop on Wed Dec 22, 2010 1:42 am, edited 8 times in total.
User avatar
honoluludesktop
In Remembrance
Re: [Plugin] Position_shadows_v0.1 Beta 112610
Postby baldaman » Mon Nov 29, 2010 10:44 pm
Good idea,
Thank you for your contribution.
baldaman
Re: [Plugin] Position_shadows_v1.0 112610
Postby honoluludesktop » Tue Nov 30, 2010 3:56 pm
Release V1.0 Couldn't resist removing the views with the sun below the horizon, and in the process improved the math.
User avatar
honoluludesktop
In Remembrance
Re: [Plugin] Position_shadows_v1.2 112610
Postby honoluludesktop » Tue Dec 21, 2010 4:08 pm
Current release including relocated menus, and minor updates. No significant functional improvements.
User avatar
honoluludesktop
In Remembrance
Postby CadFather » Tue Dec 21, 2010 4:24 pm
Thanks Honolulu,
very useful for those pesky moments in which the sliders slide too fast.. :thumb:
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby honoluludesktop » Fri Dec 24, 2010 3:22 pm
In my part of the world, there are some model elevations that are always shaded, therefor no shadows. I used to rotate the model, in order to present shadows. This application generates shadows on any elevation without rotating the model.
User avatar
honoluludesktop
In Remembrance
Postby minguinhirigue » Thu May 14, 2015 6:33 pm
Quite cool.
Is it possible to use it with the SKP2015 ?
minguinhirigue
Postby TIG » Thu May 14, 2015 6:48 pm
This is a veeeery old plugin.
BUT you can be a guinea-pig...
Install it and try it in v2015...
If it succeeds tell us. :D
If it fails please post the error messages... :(
If they are easy to fix, then I'll look at them myself...
Sadly the author died some years ago, but I'm sure he'd be happy to make his works available in newer versions too... :ugeek:
User avatar
Global Moderator
Postby wozabee » Fri Sep 23, 2016 12:53 pm
Well Tig, took the plunge.
I just installed this on SketchUp 2016.
Works as perfect as ever! :D
Just renamed the .zip file to .rbz.
I used to use this one a lot for renders.
HonoluluDesktop would be very happy this lives on♫♪♫♪... .. .
wozabee
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: Google Bot and 4 guests
Visit our sponsors:
