[Plugin] FredoTools - v4.5a - 02 Apr 24
NEW RELEASE: FredoTools v2.6a - 25 Feb 15
FredoTools 2.6a is a release for
- FredoTools::AutoReverseFaces, which automatically align the orientation of faces in pseudo-solids
- FredoTools::Convexify, which performs the Convex decomposition of 3D shapes
Note: it requires to install LibFredo6 v6.7a
hi how to fix the problem with thrupaint. its says more than 4 edges.
It would be helpful if you could give some useful information about your model. Perhaps you could post an example that shows the problem. Or at least some screen shots.
Most probably you've tried to apply a texture on surfaces which have more than 4 edges using the "Quadmesh UV" method. Try again by choosing a different method.
NEW RELEASE: FredoTools v2.7a - 26 Apr 15
FredoTools 2.7a is a release for FredoTools::SolidVolume, which computes the volume of solids in the selection. This is an initial rudimentary version.
Thanks Fredo
NEW RELEASE: FredoTools v2.7c - 27 Apr 15
FredoTools 2.7c is a release for FredoTools::SolidVolume v1.1b, which computes the volume and faces area of solids in the selection. In this second version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner.
Now it works perfect!
It seems not so perfect. There is a problem when dealing with small faces I guess. Here is the example. Group is a solid, lines are ortho. Geometry is OK. The only thing is there is a small misalignment between the faces. But it could be made on purpose...To fix it I just moved one of the faces to meet another and erased the line, which made volume ok.
Thanks for signaling.
This is actually not related to small faces.I will republsih soon with the fix
NEW RELEASE: FredoTools v2.7d - 28 Apr 15
FredoTools 2.7d is a release for FredoTools::SolidVolume v1.1c, which computes the volume and faces area of solids in the selection. In this third version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner. I also fixed bugs in the calculation of volumes.
Should this appear in your update log?
This should be OK now.
Looks to be operating properly now. Thank you.
NEW RELEASE: FredoTools v2.7e - 29 Apr 15
FredoTools 2.7e is a release for FredoTools::SolidVolume v1.1d, which computes the volume and faces area of solids in the selection. This fourth version includes a fix for the correct display of the main dialog box.
thank you -
great plugin, complete and really functional
NEW RELEASE: FredoTools v2.8a - 09 Jul 15
FredoTools 2.8a is a minor release for:
- SolidVolume, which now accepts solids with holes
- ReportLabelArea, which now computes the correct area removing the space taken by the glued componentss in cut opening mode.
Warning:
Please upgrade to LibFredo6 6.8c if you installed FredoTools v2.8.
There is a bug in FredoTools::Convexify, which is fixed in LibFredo6 v6.8c.
Sorry for inconvenience
Fred
Thanks Fredo!
