can someone help me with a keyboard shortcut that would toggle between line styles "all the Same" and "Color by Axis". I am not sure where that is found in the command menu to define a SC to it.
Thx in advance.
David
keyboard toggle for styles menus
• Page 1 of 1
keyboard toggle for styles menuscan someone help me with a keyboard shortcut that would toggle between line styles "all the Same" and "Color by Axis". I am not sure where that is found in the command menu to define a SC to it.
Thx in advance. David If I make it look easy. . .rest assured--it probably is.
Re: keyboard toggle for styles menusHi Dave,
If you want, I will write up a script that will toggle between the options. Then you can assign a shortcut to it.
Re: keyboard toggle for styles menusI'd be interested in this also, thanks for your offer to write small script, Jim!!
purpose/expression/purpose/....
Re: keyboard toggle for styles menusNo need for a script -- look at your shortcuts menu under "view/rendering/edge/all the same"
and "view/rendering/edge/by axis" then set up your shortcut key.
You are correct. I was thinking he wanted to toggle between Color By Axis and Color by Material.
Hi, I can see these items in Shortcuts but I can't see "Rendering" options under "View" in SketchUp. Missing something? Thank you Ignacio Arrúe
Arquitecto OpenCartis, S.L.
Re: keyboard toggle for styles menusIn Version 6 the edge styles you're looking for are under Window>Styles>Edit although the shortcuts are still assigned as if these things are under the View Menu.
Inspecting mirrors is a job I could easily see myself doing.
Bizarre. Thanks, I am missing nothing Ignacio Arrúe
Re: keyboard toggle for styles menusThanks. . .I appreciate it. I knew it was inthere, I just couldn't find it.
SketchUcation One-Liner AdvertsNeed Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
• Page 1 of 1
