SketchUcation Premium Membership
keyboard toggle for styles menus
General discussion related to SketchUp. No off topic threads please.
Postby David_H » Mon Apr 21, 2008 8:58 pm
can someone help me with a keyboard shortcut that would toggle between line styles "all the Same" and "Color by Axis". I am not sure where that is found in the command menu to define a SC to it.
Thx in advance.
David
If I make it look easy. . .rest assured--it probably is.
User avatar
David_H
Top SketchUcator
Re: keyboard toggle for styles menus
Postby Jim » Mon Apr 21, 2008 11:42 pm
Hi Dave,
If you want, I will write up a script that will toggle between the options. Then you can assign a shortcut to it.
Jim
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
Postby utiler » Tue Apr 22, 2008 12:02 am
I'd be interested in this also, thanks for your offer to write small script, Jim!!
purpose/expression/purpose/....
User avatar
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby pmiller » Tue Apr 22, 2008 1:04 am
No need for a script -- look at your shortcuts menu under "view/rendering/edge/all the same"
and "view/rendering/edge/by axis" then set up your shortcut key.
pmiller
Postby Jim » Tue Apr 22, 2008 1:18 am
pmiller wrote:No need for a script -- look at your shortcuts menu under "view/rendering/edge/all the same"
You are correct. I was thinking he wanted to toggle between Color By Axis and Color by Material.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby utiler » Tue Apr 22, 2008 1:37 am
cool, cheers.......
User avatar
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby iam_doss » Tue Apr 22, 2008 8:52 am
Hi, I can see these items in Shortcuts but I can't see "Rendering" options under "View" in SketchUp. Missing something? Thank you
Ignacio Arrúe
Arquitecto
OpenCartis, S.L.
iam_doss
Postby Dave R » Tue Apr 22, 2008 10:43 am
In Version 6 the edge styles you're looking for are under Window>Styles>Edit although the shortcuts are still assigned as if these things are under the View Menu.
Inspecting mirrors is a job I could easily see myself doing.
User avatar
Global Moderator
SketchUp version: 2013
License type: Pro
SketchUp use: woodworking
Postby iam_doss » Tue Apr 22, 2008 1:35 pm
Dave R wrote:In Version 6 the edge styles you're looking for are under Window>Styles>Edit although the shortcuts are still assigned as if these things are under the View Menu.
Bizarre. Thanks, I am missing nothing :)
Ignacio Arrúe
Arquitecto
OpenCartis, S.L.
iam_doss
Postby David_H » Thu Apr 24, 2008 1:16 am
Thanks. . .I appreciate it. I knew it was inthere, I just couldn't find it.
:thumb:
User avatar
David_H
Top SketchUcator
by Ad Machine » 5 minutes ago
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Ad Machine
Robot
Return to SketchUp Discussions
Who is online
Users browsing this forum: ken28875, raineysky, RichH and 3 guests
