by driven » Sun Jan 18, 2015 3:32 pm
I only use mac, but... you could, save each file to 'Trash', close it, then open a new for the next import? SU should then be starting fresh each time and you don't need to erase any entities? just a thought, I use the idea in a script... this is the an extract for Trash on a mac... - Code: Select all
def revert trash_copy = (File.expand_path("~/.Trash/" + "." + @orig.title + ".skp")).dup.freeze @orig.save(trash_copy) Sketchup.send_action("closeDocument:") Sketchup.send_action("newDocument:") end
driven
- PluginStore Author
- Name: driven
- Operating system: Mac
- SketchUp version: 2015
- License type: Pro
- SketchUp use: engineering and mechanical design
- Level of SketchUp: Intermediate
by TIG » Mon Jan 19, 2015 12:12 pm
@Young You code is overly complicated. It also has some odd working practices... I am sure I have answered this same query elsewhere... See the @yuyuwhy posts... Is it you, but with a different user-name ?? viewtopic.php?p=554042#p554042This thread explains how to setup an empty model SKP - the order of purging IS important - yours is wrong ! Do that BEFORE importing anything. It also suggests a sensible approach to the subsequent import, purge and export of each DAE in turn. If you enclose those actions within a ' model.start_operation(...)' block, BUT afterward each you ' model.abort_operation' it [NOT the usual ' model.commit_operation' it] then the imported data is simply forgotten, but the export is safe because the DAE file is now outside of the SKP's control... So there is no need to purge between each import/export at all. Recast your code thus... Make the host SKP empty. Process the list of DAE files in turn. Use a model.start_operation(...) block around each iterate step. Remember to use the model.abort_operation to undo the import etc, but leave the export intact. You should end up with an empty SKP and all of the DAE files processed. Incidentally, your code only works in v2015 as the UI folder selector is new in that version's API.
- Global Moderator
- Name: TIG
- Operating system: Windows
- SketchUp version: 2021
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by YoungOSG » Mon Jan 19, 2015 3:09 pm
driven wrote:I only use mac, but... you could, save each file to 'Trash', close it, then open a new for the next import? SU should then be starting fresh each time and you don't need to erase any entities? just a thought, I use the idea in a script... this is the an extract for Trash on a mac... - Code: Select all
Thanks! I tried it.It works fine on my PC,however it crashed on others.
YoungOSG
- Name: Young
- SketchUp version: 8
- License type: Free/Make
- SketchUp use: education
- Level of SketchUp: Beginner
by Rich O Brien » Fri Jan 23, 2015 10:55 pm
This is splatting for me?
No console message. Just splat!
I try nuke my plugins older to isolate
There's a frontroom and a backroom....reverse faces
Rich O Brien
- Administrator
- Name: Rich O'Brien
- SketchUp version: 2017
- License type: Pro
by driven » Fri Jan 23, 2015 11:07 pm
@rich,
maybe your need to watch the tutorial?
driven
- Name: driven
- License type: Pro
by Rich O Brien » Fri Jan 23, 2015 11:11 pm
@john
hahahaha
even that didn't help...
I'm trying to import 126 faceme .skp then run components to grid.
I ain't getting past the import all part as yet.
SU2015 64bit Pro in case that helps?
Rich O Brien
- Administrator
- License type: Pro
by driven » Fri Jan 23, 2015 11:11 pm
seriously now... I just tested it and had a splat as well, sent it to trimble... I'll have a look a the report
driven
- Name: driven
- License type: Pro
by Rich O Brien » Fri Jan 23, 2015 11:15 pm
na na nana na
Rich O Brien
- Administrator
- License type: Pro
by driven » Fri Jan 23, 2015 11:22 pm
@rich line 101 delete puts re-save, restart... worked for me
driven
- Name: driven
- License type: Pro
by Rich O Brien » Fri Jan 23, 2015 11:27 pm
nope! splat
Rich O Brien
- Administrator
- License type: Pro
by driven » Fri Jan 23, 2015 11:34 pm
keep the puts deleted, but on line 106 add an new line UI.messagebox(name) try on a small number of skps first just to see if slowing it down helps...
driven
- Name: driven
- License type: Pro
by TIG » Fri Jan 23, 2015 11:57 pm
That means you need to press OK 126 times ! Rich, why not ZIP and email me those 126 SKPs, explain [clearly] what you want to do...
- Global Moderator
- Name: TIG
- License type: Pro
by driven » Sat Jan 24, 2015 12:10 am
@Tig sorry, just trying to help out, thought you were at pub...
it's failing with only two models to import...
removing the puts helps sometimes, pre-saving the model helps sometimes, adding the UI.messagebox helps sometimes...
but if I try a larger folder it bugsplats again...
driven
- Name: driven
- License type: Pro
by TIG » Sat Jan 24, 2015 12:12 am
OK, I'll check it out - not a bug reports for years, then three come at once... Maybe it needs updating...
- Global Moderator
- Name: TIG
- License type: Pro
by TIG » Sat Jan 24, 2015 2:20 pm
I just revisited this Plugins code. As it was, it still worked fine for me on multiple SKP imports, but I have made some adjustments because the SKP import could now be more 'streamlined' > SUp v8... Here's the updated v1.4 RBZ in the PluginStore Download Please try it and feedback. PS: Rich - you can email me the 126 SKPs in a ZIP if you like ?
- Global Moderator
- Name: TIG
- License type: Pro
by driven » Sat Jan 24, 2015 2:35 pm
bug splat on mac... there are some weird names, but I import them as a test folder for my icon maker plugin, and they were importing then failing last night... john full folder content - Code: Select all
.DS_Store .png ¨„¶®™_·_Ë‚„‡¢†´Æ¨.skp ¨„¶®™_·_™†°•´•¨.skp ¨„¶®™_·_™†≠®·‚‡Æ©.skp ¨„¶®™_·_™‡†·™Æ©.skp ¨„¶®™_·Æ_·‚•‚Á®™Æ¨_£•©£•‡†.skp ¨„¶®™_®_™‡Î·†.skp ¨„¶®™_≠†_´•·‚≠®Ê•.skp ¨„¶®™_߆_·‚ƴƨ.skp ¨„¶®™®_·_°ÆÁ™†¨®.skp ¨„¶®™®_¢_™Æ´Æ§Ê•.skp £Æ´Î©_¨„¶®™.skp file_names from folder.scpt filenames.txt Ø®‡Æ‚•Â≠®™.skp ØÆ¶†‡≠Ε_·Æ_·‚¢Æ´Æ¨_1.skp ØÆ¶†‡≠Ε_·Æ_·‚¢Æ´Æ¨_2.skp ØÆ¶†‡≠Ε_·Æ_·‚¢Æ´Æ¨_3.png ØÆ¶†‡≠Ε_·Æ_·‚¢Æ´Æ¨_3.skp ØÆ¶†‡≠Ω_·_‚ÆØÆ‡Æ¨.skp ØÆ¶†‡≠Ω_·_Æ£≠•‚„Ë®‚•´•¨.skp ØÆ¶†‡≠Ω_≠†_Ë•·‚•.skp ØÆ¶†‡≠Ω_1.skp ØÆ¶†‡≠Ω_2.skp ØÆ¶†‡≠Ω_3.skp ØÆ¶†‡≠Ω_3~.skp ru_aviator.skp ru_blueSanta.skp ru_garbageCollect.skp ru_glassman.skp ru_jackHammer_male.skp ru_jackHammer.skp ru_leafBlower.skp ru_plumBob.skp ru_surveyor.skp ru_welder.skp ru_wheelBarrow.skp site_logo.png welder.png welder.skp
driven
- Name: driven
- License type: Pro
by TIG » Sat Jan 24, 2015 2:50 pm
They are weird SKP names ! What happens with a simpler set of 'sensible' names ?? Maybe I need to try and force the file path's encoding to UTF-8 if >=v2014 ?
Are they all real SKPs ? Is their version <= SUp version you are using ? If it's > then you will get an 'empty-skp' message for each one...
- Global Moderator
- Name: TIG
- License type: Pro
by TIG » Sat Jan 24, 2015 3:02 pm
Here's v1.5, it forces the file names to UTF-8 in >v2014 to see if that addresses file-type errors Download
- Global Moderator
- Name: TIG
- License type: Pro
by Rich O Brien » Sat Jan 24, 2015 3:07 pm
I'll email files later.
But no weird characters except _
Rich O Brien
- Administrator
- License type: Pro
by driven » Sat Jan 24, 2015 3:33 pm
@tig
no joy, it's failing on even a simple 2 skp, good filenames folder...
the other folder names are deliberately obnoxious to represent a 'user' folder, but the names all show in message bar as they are found...
driven
- Name: driven
- License type: Pro
by TIG » Sat Jan 24, 2015 5:11 pm
So this begs the question, "why does it work OK for me ?"
- Global Moderator
- Name: TIG
- License type: Pro
by Rich O Brien » Sat Jan 24, 2015 5:13 pm
You on Win8.1?
Rich O Brien
- Administrator
- License type: Pro
by driven » Sat Jan 24, 2015 5:14 pm
TIG wrote:So this begs the question, "why does it work OK for me ?" :roll:
have you run it on your mac?
driven
- Name: driven
- License type: Pro
by TIG » Sat Jan 24, 2015 5:15 pm
Win7 64bit, v2015 64bit... also works in v8 32bit etc...
- Global Moderator
- Name: TIG
- License type: Pro
by Rich O Brien » Sat Jan 24, 2015 5:28 pm
I won't get near laptop until 9pm.
But I will test then.
Rich O Brien
- Administrator
- License type: Pro
by TIG » Sat Jan 24, 2015 7:24 pm
No rush... I'm asleep right now
- Global Moderator
- Name: TIG
- License type: Pro
by Rich O Brien » Sat Jan 24, 2015 7:34 pm
Rich O Brien
- Administrator
- License type: Pro
by YoungOSG » Sat Jan 31, 2015 2:36 pm
TIG wrote:@Young You code is overly complicated. It also has some odd working practices... I am sure I have answered this same query elsewhere... See the @yuyuwhy posts... Is it you, but with a different user-name ?? viewtopic.php?p=554042#p554042This thread explains how to setup an empty model SKP - the order of purging IS important - yours is wrong ! Do that BEFORE importing anything. It also suggests a sensible approach to the subsequent import, purge and export of each DAE in turn. If you enclose those actions within a ' model.start_operation(...)' block, BUT afterward each you ' model.abort_operation' it [NOT the usual ' model.commit_operation' it] then the imported data is simply forgotten, but the export is safe because the DAE file is now outside of the SKP's control... So there is no need to purge between each import/export at all. Recast your code thus... Make the host SKP empty. Process the list of DAE files in turn. Use a model.start_operation(...) block around each iterate step. Remember to use the model.abort_operation to undo the import etc, but leave the export intact. You should end up with an empty SKP and all of the DAE files processed. Incidentally, your code only works in v2015 as the UI folder selector is new in that version's API.
Thanks!! I tried and it works! And I want to import *.dae file with 2000 jpg.However Sketchup stop at 10%. It do not warn me anything. could you help me ?
YoungOSG
- Name: Young
by TIG » Sun Feb 01, 2015 5:08 pm
Here's v1.6 Download It is overhauled to ensure that SKP file imports do not BugSplat - which was an unpredictable issue with multiple SKP files, especially those including un-purged dross. Rather than use 'import' for SKP files, it now uses 'load' on them, which adds their definitions to the model and depending on the user's choice, it either leaves them as unused Component-Browser definitions, or it also places an instance of each of them at [0,0,0]...
- Global Moderator
- Name: TIG
- License type: Pro
by McSquizzy » Wed Mar 23, 2016 7:44 pm
This tool is exactly what I am looking for but having problems with it. I am having some issues with collada (.dae) files. The tool seems to operate properly until it completes. Once it has stepped through all of the collada files, it says it has completed but does not render any of the data. I am left with an empty SketchUp model. I am using it with v2014. I have tried this plugin with .skp files and worked perfectly.
McSquizzy
- Name: Nick Piper
- SketchUp version: 2016
- License type: Pro
- SketchUp use: other
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Plugins
