[Plugin] Random Select
Postby TIG » Fri Feb 29, 2008 11:12 am
I uploaded a duff file for RandomSelect BUT because the regime is to make posts in the depository locked (?) I can't edit it or correct it. I've asked for it to be removed... and it's gone !
Here's the correct file.
It is a variant of RandomDelete.rb. It takes the selection and randomly samples the selection to the % entered in the dialog - e.g. 10%.
You can then do what you want with the now selected items - such as colour, copy, cut, move etc...
(If you downloaded yesterday's duff one please accept my apologies and get this new one...)
Please get the latest version of 'Random Select' from the PluginStore
Download
4
User avatar
Global Moderator
Re: [Plugin] RandomSelect.rb - Corrected
Postby plot-paris » Tue Jul 15, 2008 10:22 am
as simple as it works - this is a deadly useful script, TIG.
thank you very much for sharing :thumb:
User avatar
plot-paris
Postby pav_3j » Tue Jul 15, 2008 10:37 am
tasty
thank you
pav
Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
pav_3j
Postby troyhome » Wed Nov 11, 2009 3:21 am
I just downloaded this and used it and it is great!! Thanks very much for this script!!!
IOviz.com
SU Pro 2017 PC
Thea: latest
vray4SU latest
User avatar
troyhome
Postby plot-paris » Wed Nov 11, 2009 11:18 am
really a great script.
just in case you get bored, TIG :D some suggestions for a RandomSelect 2.0:
- some sort of soft selection (selection of nearly 100% at the centre and 0% at the outer areas of a circle... or selection density gradually fading from one side to the other).
- or bitmap selection: load a bitmap file and use the grey values for selection density...
- several selection sets out of one selection: you select all the entities and then, using the script, select only lets say 25% of them. now you transform/move/paint them. then you click the selection button again and get the next 25% of the initial selection... and then the next 25%... and finally the remaining 25%...
(at the moment I am using a hidden layer, moving the transformed entities to that layer after each step)
what do you think? usefull ideas?
User avatar
plot-paris
Postby kwistenbiebel » Wed Nov 11, 2009 12:26 pm
plot-paris wrote:what do you think? usefull ideas?
Very!
kwistenbiebel
Postby AcesHigh » Tue Dec 15, 2009 2:54 pm
hey Tig, you could implement Plot Paris ideas... as well as including an option for the automatic Component Swap thing I talked on the other thead :)
AcesHigh
Postby rami.derbel » Thu Mar 21, 2013 12:12 pm
thank you very much, your plug-in is very useful ^^
rami.derbel
Postby skeletor » Wed Apr 24, 2013 3:16 am
Thank you thank you thank you! I've been trying to find a work around for applying random colors to like components in a group. I have about 28,500 of these individual components all needing to be more or less randomly colored from a 6 color palette, this has saved me days of clicking, wonderful plugin!
skeletor
Postby Krisidious » Sun Nov 09, 2014 7:39 am
And it's companion random delete... thanks Tig. There's treasure in this forum. Is this not in the store? Searched in the store plugin and couldn't find it.
By: Kristoff Rand
Home Designer
Unique House Plans
User avatar
Krisidious
Postby Box » Sun Nov 09, 2014 9:03 am
How about search for random.
I'm not sure if searches copy and paste but you can try the link.
http://sketchucation.com/pluginstore?li ... submit=%3F
User avatar
Postby Krisidious » Sun Nov 09, 2014 9:09 am
I'm talking about in the plugin for the plugin store. the installer.
When I search for RandomSelect.rb or RandomSelect I get this.
When I search for just the word random I find it.
By: Kristoff Rand
Home Designer
Unique House Plans
User avatar
Krisidious
Postby Box » Sun Nov 09, 2014 9:16 am
They are one and the same thing.
Just type Random in the search box and it will find anything with the word Random used in it.
If you were scrolling through Tigs looking for it perhaps you didn't have his filter set to full list.
I see you added more while I was posting, but I'll leave this as is.
User avatar
Postby Krisidious » Sun Nov 09, 2014 9:28 am
The point isn't really this plugin alone. some plugins are named something different for the .rb file than the actual name, like an acronym, an author name with abbreviation etc.. Searching for the actual ruby name should find a plugin, no? While scanning my change over installation I look at the folder to see the names and compare with the new installation. I find these and have to try and play Sherlock Holmes to figure out which plugin it was and if I want to bring it over. Some are easier to figure out than others. I would think that file name could or should be part of the searchable database.
I might add I had the same issue in Sketchup's Extension installer. just having the twowords stuck together without a space was enough to bring up a negative result.
By: Kristoff Rand
Home Designer
Unique House Plans
User avatar
Krisidious
Postby Box » Sun Nov 09, 2014 9:44 am
All search engines have their idiosyncrasies. I find less is more in this instance.
I'd search for full names with .rb etc in the forum search first so I have a better idea what I'm looking for.
User avatar
Re: [Plugin] Random Select
Postby TIG » Sun Nov 09, 2014 5:06 pm
There's now a link to the PluginStore entry in the first post ! :roll:
User avatar
Global Moderator
Postby timelessnomad » Tue Jul 25, 2017 3:10 pm
This plugin just saved me so much time! Thank you!
timelessnomad
Postby Einstein » Tue Dec 26, 2017 12:36 am
Thank you, TIG, for such good understanding needs of every 3D modelling guy! In my opinion 3D modelling software should focus on improving selection because it is one of the most important steps in computer graphics - when you already have selected exactly what you needed, you can already make almost everything easily. Selecting is such a basic action but sometimes it takes sooo much time that it's vital to speed it up.
Einstein
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: hyodoarch, ohizumi and 9 guests
Visit our sponsors:
