[Plugin] Door-Lintel Update + Window-Sill
Re: [Plugin] Door-Lintel Update + Window-Sill
Postby Pixero » Sun May 18, 2008 5:19 pm
Thanks for this great script! :thumb:
User avatar
Pixero
Postby ilay7k » Sun May 18, 2008 5:58 pm
Didier thanks for fix :enlight:
it alive...works
Pixero
+7 ...sketchup...+7000
it closes to parametric... :shock:
multiple selections of sides will be wonderful for it and connection with multiwall tool :roll: :idea:
ilay7k
Postby erikB » Tue May 20, 2008 7:51 am
Thanks for the update. This is a very usefull tool !!!
erikB
User avatar
erikB
Postby pbacot » Fri Feb 10, 2012 9:08 pm
It's been a while since I used this tool and it looks like interest in it has dropped off judging by the activity here. What other methods have people been using? I have been working with solid groups more and components, but sometime I just want to use something like this. There are some drawbacks to the tool at present:
I cannot make a shortcut key command operate the tool. Nothing happens. So it is slow if you are doing a lot of doors, pulling down the menus each time. Also I have found if you preselect the embrasures, you can work them all one by one by selecting the tool over and over. I wonder if the tool could be set to work on multiple instances in one command.
The tool would also be enhanced by having an active phase, with a toolbar. Then just clicking on an embrasure would perform the preset lintel. That would be the quickest use.
I sometimes get an error message that the maximum door height is exceeded. It has no relationship to the drawing that I can see. Then I cannot use the tool until I reduce the door height then set it back up again where I want it. I thought I might look at adjusting the script, but it's encoded.
Windows are set by sill and window size. It seems to me that convention would make it appropriate to set window head height and window size instead. Then adjusting for a different window would usually take only one input as window heads are usually constant in a building.
This tool works well and cleanly. It's helpful if you have imported CAD wall lines that already have openings. Probably has other uses in joining shapes. Thanks, Peter
MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
User avatar
Top SketchUcator
Postby SUFractal » Wed Apr 11, 2012 4:31 pm
pbacot wrote:It's been a while since I used this tool and it looks like interest in it has dropped off judging by the activity here. What other methods have people been using? I have been working with solid groups more and components, but sometime I just want to use something like this. There are some drawbacks to the tool at present:
Just discovered this plugin this morning ... very handy when importing a plan drawing in CAD as you suggested. I agree with your comments about some minor tweaking.
SUFractal
Postby ArCAD-UK » Wed Apr 11, 2012 10:04 pm
I recently discovered TIG's Hole Punching tool...
viewtopic.php?t=30846
which could work as a more efficient alternative depending on your components and objectives.
ArCAD-UK
Postby pbacot » Thu Apr 12, 2012 5:25 am
Thanks for the note. I haven't been using that method, though I have looked at the plugin a few times. I'll look into it.
User avatar
Top SketchUcator
Postby TIG » Tue Nov 04, 2014 6:07 pm
Didier has agreed that I might update some of his Plugins in the PluginStore.
Please get the latest v2014/2015 compatible version from the PluginStore
Download
User avatar
Global Moderator
Postby juju » Wed Nov 05, 2014 12:21 pm
TIG wrote:Didier has agreed that I might update some of his Plugins in the PluginStore.
Please get the latest version from the PluginStore
following the download button doesn't take me to the correct page, also, if I search the pluginstore, either by author or by plugin name it does not show this plugin
is it an error there or on my machine somehow?
User avatar
juju
Premium Member
Premium Member
Postby Krisidious » Wed Nov 05, 2014 12:28 pm
thanks for doing this Tig...
By: Kristoff Rand
Home Designer
Unique House Plans
User avatar
Krisidious
Postby TIG » Wed Nov 05, 2014 12:59 pm
Sorry, but although I had updated the RBZ I forgot to click 'Publish' in the PluginStore Dev-page...
NOW its Download link should work !
:oops:
User avatar
Global Moderator
Postby Krisidious » Wed Nov 05, 2014 1:00 pm
It was gone when I went to look, but after a few seconds it was there.
By: Kristoff Rand
Home Designer
Unique House Plans
User avatar
Krisidious
Postby pankaj_tamore » Thu Nov 06, 2014 5:35 pm
Dear Didier Bur,
This so magical very easy to use and give incredible result. because it saves lot of time which is consumed by conventional method(which is very cumbersome) of putting doors And windows. your this plug-in has put an end on that ordeal of deleting every single vertical and horizontal line on faces of walls, which very irritating thank you very much and keep it up!
pankaj_tamore
Postby juju » Fri Nov 07, 2014 11:53 am
TIG wrote:Sorry, but although I had updated the RBZ I forgot to click 'Publish' in the PluginStore Dev-page...
:oops:
EXCELLENT! THX
User avatar
juju
Premium Member
Premium Member
Postby halroach » Tue Jun 07, 2016 7:00 pm
This plugin is wonderful!
Does it work within a component? It seems to work for me only when it's in the "open!?"
User avatar
halroach
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: fafou, nhamsobon, Nzerde, RossThompson87, tunguen120996, verauola, williamparker and 10 guests
Visit our sponsors:
