by TIG » Thu Nov 06, 2014 12:22 am
Pherim wrote:Extrude Edges by Faces by Rails makes my SU2015 64bit always crash immediately after finishing - it works fine on the same model in SU2013. No error message, just crash and bug splat window the second I click yes or no to erasing the original curves.
All other tools work.
It's amazing though, how much faster this and many other operations are executed in the new 64bit version.
Looks like we ought to continue this issue in this 'Extrusion Tools' thread ? I'll investigate... PS: I see the issue too, trying to see its cause
- Global Moderator
- Name: TIG
- Operating system: Windows
- SketchUp version: 2021
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by Pherim » Thu Nov 06, 2014 12:26 am
Your recommendation in the other thread made me try out every tool in this set, and that's how I discovered this issue. Sorry for keeping you busy like this.
Pherim
- Name: Pherim
- SketchUp version: 2016
- License type: Free/Make
- SketchUp use: hobby
by TIG » Thu Nov 06, 2014 6:21 pm
Here's v2.7, now in the PluginStore Download The update covers ExtrudeEdgesByRailsByFace - it has been adjusted to work properly in v2015, which unexpectedly showed a glitch when calling another tool from within its mouse-click method... As a 'side-effect' it also has some improved graphics, prompting etc...
- Global Moderator
- Name: TIG
- License type: Pro
by Pherim » Thu Nov 06, 2014 6:29 pm
I confirm that it works now. Thanks!
Pherim
- Name: Pherim
by Hecky001 » Thu Jan 22, 2015 10:06 pm
Hello there i am here to report a crash of my sketchup 8 pro when using Extrude Edges by Rails by Face
it crashes only when the profile its segmented more than 12 times for example if a segment a circle 13 times it will crash the sketchup a bug splat but when i segment circles below 12 it does the job fine can someone please tell me whats going on
Hecky001
- Name: hekuran
- SketchUp version: 8
- License type: Pro
by Manijeh » Fri Feb 20, 2015 9:45 pm
I have just installed this plugin through plugin store tool bar's autoinstall. I watched the video on youtube and followed step by step. but the tools didn't work for me. Is there any way there could be a more detailed video tutorial preferably with audio? Also am I missing something in the operations and or installation of this tool? Thanks for your response.
Manijeh
Manijeh
- Name: Manijeh
by perper » Wed Apr 29, 2015 11:46 am
No toolbar
Can anyone assist me?
I have downloaded the TIG Extrude tools to SketchUp. Unfortunately I can not find the toolbar..
Pls help
Best regards Per
perper
- Name: Per Thornblom
- SketchUp version: 2015
- Level of SketchUp: Intermediate
by TIG » Wed Apr 29, 2015 6:52 pm
perper wrote:No toolbar. Can anyone assist me? I have downloaded the TIG Extrude tools to SketchUp. Unfortunately I can not find the toolbar..
You said you downloaded the RBZ. You have NOT said you have installed it ! So if you haven't... Window > Preferences > Extensions > Install... button... Choose the Plugin's RBZ and answer in the affirmative to any questions... NOTE: if you installed it with the SketchUcation PluginStore Toolset's dialog within SketchUp itself it should Auto-Install. Assuming it is installed... Look in the v2015 "Extensions" menu [called "Plugins" in ALL pre-v2015 SketchUps] for "Extrusion Tools..." submenu items... Are they there ? Also check that the "Extrusion Tools" Toolbar is activated... If none of this works come back.
- Global Moderator
- Name: TIG
- License type: Pro
by logan683 » Fri Jun 26, 2015 1:23 am
Sketchup 2015 Pro
Whenever I extrude an edge, by any means, and save, it undoes the extrusion and will continue to undo every time I save. It acts just like Ctrl-Z whenever I hit Ctrl-S, and it crashes occasionally. Thank you. It was working fine.
logan683
- Name: Logan Ball
by logan683 » Fri Jun 26, 2015 2:02 am
Ok, I figured it out. Extrude Tools have a conflict with SUSolid plugin. I really need both. I am emailing the dev of SUSolid now. Is there anything I can send you to check on your end? Thank you.
logan683
- Name: Logan Ball
by Fabtins » Fri Jun 26, 2015 9:35 am
I'm new to this tool. I was just using the 'Extrude edges by Rails by face' tool when i realised that the ribs produced in my model by selecting the Profiles and rails option were quite different from the one shown in the tutorial. They weren't so smooth or so detailed but rather plain and conflicting. I'm attaching the pictures of the required rib formation titled 'A' versus the ribs produced in my model titled 'B'. I know the two shapes are quite different but that doesn't explain why the rib designs are different.
Can anybody tell me what must've brought about this change? Is there some change in settings that you must do to change the rib type? My extrude tools version is extrude tools V2.7. Any help will be appreciated
Fabtins
- Name: Pranjal
- SketchUp version: 2014
- License type: Pro
- Level of SketchUp: Beginner
by Dave R » Sat Jun 27, 2015 11:28 pm
You could help us help you if you posted the SKP file you're working with. Otherwise we'll just be guessing.
- Global Moderator
- Name: Dave R
- License type: Pro
- SketchUp use: woodworking
by TIG » Sun Jun 28, 2015 11:15 am
Posting the SKPs would be a great help [purge first]. It's hard to tell what shape you have defined for the extrusion face[s]. the orientation of that face and the order you pick rails/profiles in the 'mesh' all affect the result...
- Global Moderator
- Name: TIG
- License type: Pro
by Fabtins » Tue Jun 30, 2015 2:47 pm
Here's my sketchup file in the attachment. As I said, i've used the 'extude edges by Rails by Face' tool here on the shape but the produced mesh doesn't quite resemble the one shown in tutorial. Please review and suggest what has gone wrong. Is it a different version of extrude tools than the one i've been using? P.S. the version i'm working with is v2.7
Fabtins
- Name: Pranjal
- License type: Pro
by TIG » Wed Jul 01, 2015 1:36 pm
The profile used in example 'A' was not a rectangle ? It looks like a '+' shape, or a 4-pointed star ?? The 'B' profile is a rectangle and it is sized quite near the curve segment size too, so there are much smaller 'gaps'. Try again with another size and/or shape for the profile face... Also perhaps scale the face and the four path curves x10, extrude. then scale down - otherwise you might get into the 'tiny geometry' issues - where some edges approach zero length and get ignored by SketchUp as its tolerance is 1/1000", and faces are missed out etc - even Bugsplatting...
- Global Moderator
- Name: TIG
- License type: Pro
by Fabtins » Fri Jul 03, 2015 7:19 am
I've used the '4-pointed star' shape in this sketchup file sir. This shape, i've scaled and there are adequate gaps but the results are drastically different. The mesh formed isn't at all the same. Also there is the persisting issue of mesh design. It's still rather plain compared to the elaborate and realistic design formed in your tutorial. Thanks
Fabtins
- Name: Pranjal
- License type: Pro
by TIG » Fri Jul 03, 2015 10:17 am
What is made is what's to be expected using the profile and paths in your example SKP. I still can't understand what you think it should do The shape of the face determines the extrusion's cross-section. The cpoint [guide-point] selected with the face determines its setting out relative to the path [if included, otherwise the face's bounds.center is used]. The number of segments in the curves forming the path determine the number of ribs etc... To change that... before 'welding the parts into a curve use 'divide' [context-menu] on selected edges to subdivide them, then weld all into a curve - that way a long straight run of edges can be split into several extrusions... Incidentally, I did not make the 'tutorial' video to which you keep referring - Rich did...
- Global Moderator
- Name: TIG
- License type: Pro
by AcesHigh » Fri Jul 03, 2015 6:42 pm
Fabtins wrote:I've used the '4-pointed star' shape in this sketchup file sir. This shape, i've scaled and there are adequate gaps but the results are drastically different. The mesh formed isn't at all the same. Also there is the persisting issue of mesh design. It's still rather plain compared to the elaborate and realistic design formed in your tutorial. Thanks
4 pointed star shape??? You mean, a RECTANGLE? Like you selected the Polygon Tool Shape and input 4 for four sides... which obviously results in a square? Then you scaled it so it became a RECTANGLE??? you know... I do not suppose is just a coincidence that the shape you used as a profile... the "4-pointed star" (also known in indo-european languages as rectangle) is the same shape actually used as a PROFILE in the rails, as shown in this image
AcesHigh
by AcesHigh » Fri Jul 03, 2015 6:54 pm
behold... using a different face shape... it resulted in different rails and profiles!
AcesHigh
by Dave R » Fri Jul 03, 2015 9:39 pm
AcesHigh wrote:Fabtins wrote:I've used the '4-pointed star' shape in this sketchup file sir.
Huh. You learn something every day. I never knew a rectangle could be called a 4-pointed star.
- Global Moderator
- Name: Dave R
- License type: Pro
by pbacot » Sat Jul 04, 2015 12:52 am
I think of this for "star".
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
- Top SketchUcator
- Name: pbacot
- Operating system: Mac
- License type: Pro
by Dave R » Sat Jul 04, 2015 1:02 am
That's what I thought, too. Hmmm....
- Global Moderator
- Name: Dave R
- License type: Pro
by AcesHigh » Sat Jul 04, 2015 2:06 am
Yes, that would be my guess too. However, there is no shape like that at all in the file he shared with us. He used the rectangle as the shape.
So I can only guess "four pointed star" is a weird Google Translation from "rectangle" in his original language, whatever language that is. (probably not indo-european)
I can´t think of another reason for him to say he wanted a four pointed star shape when there is none in his Sketchup file.
IF textures were not embedded on Sketchup files, I would think that he had a 4 Pointed Star texture on that rectangle, and expected the plugin to extrude the shape of the bitmap...
edit: hovering the mouse over his nickname, it shows his name (Pranjal) which I guess is from India. There shouldn´t be such difference from Hindi to english for his word for "rectangle" to be translated as "4 pointed star".
So I really do not know... maybe there was a four pointed star bitmap on that rectangle?
AcesHigh
by Fabtins » Sat Jul 04, 2015 7:51 am
Thank you gentlemen! I guess that answers my queries. As i said in my first post i m pretty much a newbee when it comes to extrude tools or for that matter sketchup in general. I hadn't known that the shape of the flat face had any bearing on the profile in the rails(Thought it was just supposed to be that i.e., a flat face nothing more) or that if we divide the number of segments of the curve edge then it affects the number of ribs as well. Thanks a lot. Incidentally, the 'four pointed star' thing wasn't my production. I was merely quoting what line of terms TIG had used previously referring to example 'A'. Note that y'all, if you will. As you deftly pointed out Aceshigh, the rectangle term is 'indo'-european AND assuming I am an Indian, i'm the last person to harbour any doubts about what a rectangle(a polygon enclosed by four sides at right angles to each other) or a star(a polygon with sides cutting each other so as to form a star shaped figure)mean.
Fabtins
- Name: Pranjal
- License type: Pro
by AcesHigh » Sat Jul 04, 2015 3:21 pm
Fabtins wrote:Thank you gentlemen! I guess that answers my queries. As i said in my first post i m pretty much a newbee when it comes to extrude tools or for that matter sketchup in general. I hadn't known that the shape of the flat face had any bearing on the profile in the rails(Thought it was just supposed to be that i.e., a flat face nothing more) or that if we divide the number of segments of the curve edge then it affects the number of ribs as well. Thanks a lot. Incidentally, the 'four pointed star' thing wasn't my production. I was merely quoting what line of terms TIG had used previously referring to example 'A'. Note that y'all, if you will. As you deftly pointed out Aceshigh, the rectangle term is 'indo'-european AND assuming I am an Indian, i'm the last person to harbour any doubts about what a rectangle(a polygon enclosed by four sides at right angles to each other) or a star(a polygon with sides cutting each other so as to form a star shaped figure)mean.
well, yes, it was just that we were all quite baffled since you were mentioning the 4 pointed star but all we saw on your SKP file was a rectangle I do not doubt for a second that Indians, who excell in mathematics since antiquity, can differentiate between a star shape and a rectangle. What I was wondering was if perhaps you were from some part of India where only some local dialect was spoken and not much english at all, so the TRANSLATION (via Google or something else) was problematic. But as you can see, later on I moved to the theory that you had used a star bitmap/texture on that rectangle face, and expected the extruded rails/profiles to have the shape of the texture. (this CAN actually be done, with a plugin that "cuts" a shape following the patterns it recognizes in the bitmap)
AcesHigh
by Fabtins » Sat Jul 04, 2015 6:37 pm
While we're at it, can you name this plugin you mentioned in the last para? The one that "cuts" a shape following the patterns it recognizes in the bitmap?
Fabtins
- Name: Pranjal
- License type: Pro
by TIG » Sat Jul 04, 2015 6:59 pm
Fabtins wrote:While we're at it, can you name this plugin you mentioned in the last para? The one that "cuts" a shape following the patterns it recognizes in the bitmap?
My ImageTrimmer, part of SKMtools...
- Global Moderator
- Name: TIG
- License type: Pro
by gonashvili » Thu Sep 03, 2015 11:32 am
How do you actually make these into a solid?
gonashvili
- Name: Hamlet G
- License type: Pro
by Dave R » Thu Sep 03, 2015 11:55 am
gonashvili wrote:How do you actually make these into a solid?
How do you make what into a solid? Please be specific.
- Global Moderator
- Name: Dave R
- License type: Pro
by JQL » Fri Oct 16, 2015 11:28 am
Hi Tig, I've just noticed that the icon for extrude edges by vector is replaced by the icon from extrude edges by lathe.
Thanks again for the wonderful plugin!
JQL
- Premium Member
- Name: JQL
- SketchUp version: 2017
- License type: Pro
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Plugins
