SketchyPhysics 3.3 (Unofficial Release)
I'll look into, but can't promise anything.
@anton_s said:
I need some people to test this on Mac OS X.
Hi, I would like to test on OSX.
Downloaded plugin, and copied to:
/Users/arturmaciag/Library/Application Support/SketchUp 2013/SketchUp/Plugins/
and
/Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/In Sketchup 2013 after start:
Error Loading File /Users/arturmaciag/Library/Application Support/SketchUp 2013/SketchUp/Plugins/SketchyPhysics/main.rb no such file to load -- /Users/arturmaciag/Library/Application Support/SketchUp 2013/SketchUp/Plugins/SketchyPhysics/lib/dl Error Loading File SketchyPhysics.rb no such file to load -- /Users/arturmaciag/Library/Application Support/SketchUp 2013/SketchUp/Plugins/SketchyPhysics/lib/dl
Ruby console is empty.
In Sketchup 2014 Make after start:
Error Loading File /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/main.rb Error; #<RuntimeError; An error occurred while trying to load Ruby FFI! cannot load such file -- /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/2.0/ffi_c.so /Applications/SketchUp 2014/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb;45;in `require' /Applications/SketchUp 2014/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb;45;in `require' /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb;7;in `<top (required)>'> /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb;10;in `rescue in <top (required)>' /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb;6;in `<top (required)>' /Applications/SketchUp 2014/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb;45;in `require' /Applications/SketchUp 2014/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb;45;in `require' /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/newton.rb;8;in `<top (required)>' /Applications/SketchUp 2014/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb;45;in `require' /Applications/SketchUp 2014/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb;45;in `require' /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/main.rb;23;in `<top (required)>' /Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `require' /Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `load' /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb;217;in `register_extension' /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb;217;in `<module;MSketchyPhysics3>' /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb;199;in `<top (required)>'
in Ruby console:
(eval);1; warning; already initialized constant Traductor;;SU_MAJOR_VERSION /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb;40; warning; previous definition of SU_MAJOR_VERSION was here (eval);1; warning; already initialized constant Traductor;;RUN_ON_MAC /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb;39; warning; previous definition of RUN_ON_MAC was here
MacBookPro 2013, OSX Yosemite (developer preview (i have also 10.9 Maverick on another machine - can test if that helps)).
Thank you
Hi, I'm on Win7 and have SketchUp 14 (free). I downloaded the SketchyPhysics_3.3.0.zip file, installed the files in C:\Users*UserName\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins* and can't get it to work
One reason - I think - is that I have no "Plugins" menu:but the main reason stems from the following Load Errors:
[pre:38j7kzib]Error Loading File C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/main.rb
Error: #<RuntimeError: An error occurred while trying to load Ruby FFI!
5: Access is denied. - C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/2.0/ffi_c.so
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:inrequire' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in
require'
C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb:7:in<top (required)>'> C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb:10:in
C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb:6:in<top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in
require'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:inrequire' C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/newton.rb:8:in
<top (required)>'
require'
C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/main.rb:23:in<top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in
require'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:inload' C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb:217:in
register_extension'
C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb:217:in<module:MSketchyPhysics3>' C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb:199:in
<top (required)>'[/pre:38j7kzib]can anybody shed some light on this?
Thanks -
Seems awkward that you’d start trying to update SP when you were working on a full rewrite…You must have hit a snag (or got bored). Tho I do see how working directly with SP would help, so no complaining here…But you should have posted you were going to do this on the other thread
New update will come today, and well see if it works. Sorry for inconvenience.
No inconvenience at all really glad that SP is being worked on for the newer SU versions.
Thank you. -
@RobiBlue According to your log, you have your name as 'UserName' but you should change it to your actual name. If you install SU2014 this path should be automatically created. SU2014 plugins are located in %appdata%
@Anton_S yeah, I changed the name when I posted the log. Assume that the UserName is correct.
I just realized the following entries in the log:
Error; #<RuntimeError; An error occurred while trying to load Ruby FFI! 5; Access is denied. - C;/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/2.0/ffi_c.so
and therein lied the problem Norton AV has some weird "insight WS.Reputation.1" score, which quarantines files it thinks are not safe because not many users have reported it as safe, or the developer didn't submit it to their safe-list https://submit.symantec.com/dispute/insight/ which I have done now.
Sometimes these AV are a PITA but more than that, they save one from a lot of troubleso far I got SP3.3 working now.
Thank you!
Very well, although you might want to transfer to SP3.4 : http://sketchucation.com/forums/viewtopic.php?f=61%26amp;t=58936
