[Plugin] jf_get_dimensions.rb
Re: [Plugin] jf_get_dimensions.rb
Postby Humpmetwice » Thu Apr 03, 2014 2:24 am
New computer and new sketchup8 with all maintenance updates installed but Get dimension, trim & keep no longer work for groups only components. Two of my favorites. Please help
User avatar
Humpmetwice
Postby Jim » Thu Apr 03, 2014 2:41 am
I made a minor update to version 1.1 for SketchUp 2014, but didn't really see why it didn't work. See 1st post.
Jim
Global Moderator
Postby Dave R » Thu Apr 03, 2014 2:46 am
Hi Kurt, as you know I don't use groups but I just made a couple and tested Get Dimension and it works just fine on them. According to the description for Trim and Keep, the thing that gets trimmed must be a component. The idea for that plugin was to have a tool similar to the Solid Tools Trim tool which didn't result in components being converted to groups. For me that conversion of components to groups is a big down side to using the Solid Tools. I'd love to see Jim create new versions of the other Solid tools that keep the components like Trim and Keep does.
User avatar
Global Moderator
Postby Zacchia » Wed Aug 20, 2014 11:43 am
Is there in the newest Version not a small Icon for that plugin? I have to go to Plugins/get dimensions?
Zacchia
Postby Dave R » Wed Aug 20, 2014 11:48 am
No. There is no toolbar for this and it isn't needed. Just assign it a keyboard shortcut.
User avatar
Global Moderator
Postby Zacchia » Thu Aug 21, 2014 10:57 am
Thanks for Feedback. Previous Version had a Icon and i liked it but... Btw. many thanks for it!!
Zacchia
Postby Dave R » Thu Aug 21, 2014 11:10 am
I tested the plugin before it was released. Don't remember it having a toolbar. Have always had a keyboard shortcut set up for it. Jim's original post from 2010 doesn't mention a toolbar button.
User avatar
Global Moderator
Postby Zacchia » Thu Aug 21, 2014 12:18 pm
Dave R wrote: Have always had a keyboard shortcut set up for it. Jim's original post from 2010 doesn't mention a toolbar button.
It had before... How do I set a keyvboard shortcut? Sorry for not knowing :oops:
Zacchia
Postby Dave R » Thu Aug 21, 2014 12:25 pm
Go to Preferences>Shortcuts. Search for Plugins/Get Dimensions. Add the keyboard shortcut and click on the +.
Please complete your profile.
User avatar
Global Moderator
Postby Zacchia » Thu Aug 21, 2014 12:36 pm
Many thanks!!
Zacchia
Postby Zacchia » Mon Aug 25, 2014 9:35 am
About the Icon: I found out that I muddle up the get dimensions plugin with the resizer plugin from Sahi... this one has Icon...
Zacchia
Postby bleiente » Thu Dec 11, 2014 6:00 pm
@ll: wow ... nice features, but in the old get_dimensions.rb by 'CptanPanic' its possible to get the area in m² and the volume m³.
area = dims[2].to_m * dims[1].to_m
volume = dims[2].to_m * dims[1].to_m * dims[0].to_m
does anyone put that feature in rb-scripts here?
sorry for the bad english.
thx so far and best regards
a.
bleiente
Postby Boiseux » Wed Apr 15, 2015 1:59 pm
Original plugin from first post works just fine for me !
Very, very usefull to rapidly check if everything's OK after resizing, fredoscale, or yust quickly see the dimensions of a particular piece of "wood".
Thanks so much !
Boiseux
Postby TIG » Wed Apr 15, 2015 2:07 pm
Boiseux wrote:Original plugin from first post works just fine for me !
Thanks so much !
It has an entry in the PluginStore http://sketchucation.com/pluginstore?pl ... dimensions
So you can get it as an RBZ archive for auto-installation.
Manually installing RB files can be risky.
Also note that this script is five years old and much has changed in SketchUp since then - however, simple well written older scripts like this can often work across many versions...
Almost all scripts are now available in RBZ format making installation less fraught if you have >= v8M2...
User avatar
Global Moderator
Postby moabie » Thu May 28, 2015 9:57 am
Is it possible to rewrite the plugin to make it installable from sketchup plugin center?
Is it possible to make it look different - more modern, not as ugly popup window,
for example: show in window dimensions (as we made height depth lenght measurement tool) and make the plugin 'active' or 'not active' so that every model i click shows its dimensions?
Anyway, great tool, grats!
moabie
Postby Dave R » Fri May 29, 2015 1:45 pm
It's already available in the Sketchucation Plugin Store. What more do you need? :roll:
Get the SCF Plugin Store extension and use it to install this plugin or just download the .rbz file and use Install Extension.
User avatar
Global Moderator
Postby ritchey » Tue Jul 12, 2016 7:48 am
This is the best extension ever. Thumbs up thousand times.
ritchey
Postby yossku » Tue Aug 23, 2016 3:31 pm
Thank you very much! Extremely helpful plugin! :)
yossku
Postby pipinek » Thu Mar 16, 2017 3:25 pm
dedmin wrote:Here is a new version that displays the dimensions on the status bar
Made by a russian guy called 'newsposting'
GetDimensions.rb
Greetings.
Alas it does not work with SU 2017 as far as I experience.
Should it be any equivalent or a version of that plugin for 2017 release?
Thank t=you in advance
pipinek
Premium Member
Premium Member
Postby Dave R » Thu Mar 16, 2017 3:40 pm
pipinek wrote:Alas it does not work with SU 2017 as far as I experience.
What do you mean it doesn't work? I've been using Jim's Get Dimensions all along and it works just fine for me.
In fact, here's an example I made just now with SketchUp 2017.
User avatar
Global Moderator
Postby Laurenceau » Tue Dec 05, 2017 9:35 am
it doesn't work with 2018 version
plugin .rb instead of .rbz
Laurenceau
Postby Dave R » Tue Dec 05, 2017 11:15 am
Laurenceau wrote:it doesn't work with 2018 version
It works just fine in SketchUp 2018.
You can either install the RB file manually or get the RBZ version here and use Install Extension or better, install the Sketchucation Extension Store tool and use it to automatically install the plugins and extensions host here on Sketchucation.
User avatar
Global Moderator
Postby derei » Sat Apr 14, 2018 1:44 pm
Can't seem to find the plugin in Extension Store... is still available, or was removed?
DESIGNER AND ARTIST DEREI.UK
User avatar
derei
Postby Dave R » Sat Apr 14, 2018 2:09 pm
It seems that Jim has removed most if not all of his plugins.
User avatar
Global Moderator
Postby bsfranza » Wed Sep 04, 2019 12:50 pm
hi there together,
is there a working version of the plugin? or any alternative? because it seems its still gone from the extension store and sketchucation store :/
bsfranza
Postby Dave R » Wed Sep 04, 2019 12:58 pm
As I wrote back in April of last year, Jim has withdrawn his extensions and plugins and they aren't available anymore. Get Dimensions was a useful one for me but I've not seen a similar one by any other author.
User avatar
Global Moderator
Postby dedmin » Wed Sep 04, 2019 3:56 pm
Here we go:
Edited to remove the file. It is up to the original author to share their plugins and extensions.
dedmin
Postby iamblindtoo » Tue Nov 05, 2019 9:06 pm
Any upgrade on this?
iamblindtoo
Postby Dave R » Wed Nov 06, 2019 1:49 pm
What sort of upgrade are you wanting for a plugin that has been withdrawn and is not available?
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: fred.dy, kafranzita, Majestic-12 Bot, matgarro, olatzrazquin, rparsons and 13 guests
Visit our sponsors:
