[Plugin] Simple Plugin Installer
Re: [Plugin] Simple Plugin Installer (1.1.0) — 03 December 2
Postby architex » Mon Apr 29, 2013 7:22 pm
sorry mate.
I am Portuguese. can you tell me were i can find ruby console+ in the preference tab.
I have SU 8pro installed and it is not there.
How can i install cleanup3 plugin?
teach me please.
User avatar
architex
Postby Dave R » Mon Apr 29, 2013 8:01 pm
The Ruby Console is under the Window menu.
User avatar
Global Moderator
Postby sketch-gary » Mon May 06, 2013 6:04 pm
WOW!
I just installed your installer and I can now load all the .rb scripts that I couldn't before. I'm new to Sketchup and the ruby script thing was crazy - can't load .rb files - now I can.
Wonderful, thanks so much!
Gary
sketch-gary
Postby mvdberg » Thu May 09, 2013 1:18 pm
Thanks for this great plugin!! It helped me saving a lot of work just when I needed it.
Great job!
Marlon
mvdberg
Postby TattanDee » Fri May 31, 2013 2:01 pm
My sketchup doesnt have an " install extension" button .. any explanations ?
TattanDee
Postby Gaieus » Fri May 31, 2013 4:28 pm
Hi Dima,
Have you got the latest version of SketchUp 8? This feature was introduced in Maintenance release 2 only.
User avatar
Postby kungfu » Sat Jul 27, 2013 2:09 am
why does i dont have install extension?
kungfu
Postby massimo » Sat Jul 27, 2013 7:48 am
Look at the post above yours.
User avatar
massimo
Postby thomthom » Sat Jul 27, 2013 3:07 pm
kungfu wrote:why does i dont have install extension?
Because you need SketchUp 8M2 or newer. :roll:
User avatar
PluginStore Author
PluginStore Author
Postby filipeefilipe » Fri Aug 09, 2013 4:04 pm
I dont find the button "install extension". Could somebody help me? Is there another way to install rbz files? thank you.
filipeefilipe
Postby massimo » Fri Aug 09, 2013 4:50 pm
User avatar
massimo
Postby filipeefilipe » Sun Aug 11, 2013 6:55 am
Massimo, i had seen that post. I've asked if there is another way to instal rbz files. I dont want change my sketchup version. thank you.
filipeefilipe
Postby Gaieus » Sun Aug 11, 2013 7:34 am
In that case, simply change the *rbz extension to *.zip, open the archive and copy the content into the plugins folder of your SketchUp application.
User avatar
Postby filipeefilipe » Mon Aug 12, 2013 4:14 am
It worked! thank you, Gaieus!
filipeefilipe
Postby SKYNET-71 » Wed Aug 21, 2013 10:00 am
Hi to all, i have a problem with sk 8 pro, do not upload it to m2. It's possible a manual installation? How can I use the plugins with the extension rbz without the button "install extensions" or without the Maintenance Release 2? What's the difference between "VERTEX TOOLS v 1.1 and BEZIER SURFACE? What's the best? Thanks for help. Greetings to all.
User avatar
SKYNET-71
Postby Dave R » Wed Aug 21, 2013 12:07 pm
Why wouldn't you upgrade to at least the last maintenance release of SU8? If you really aren't going to do that, change the .RBZ extension to .ZIP. Then you can extract and manually install the files within. Make sure you maintain the file structure within the downloaded file. Also make sure you read the thread from which you download the file and be sure you get any required supporting files and install them correctly, too.
User avatar
Global Moderator
Postby SKYNET-71 » Fri Aug 23, 2013 5:28 pm
Hi.I have a problem for installing the "rbz" files. I just updated SU 8 pro, BUT I CAN NOT INSTALL PLUGINS rbz! I followed all the explanations, but without solving the problem. In my System Preferences window, there is no "Ruby Console+" (why?)but in Windows <Ruby Console, yes. The file to be loaded with rbz system preferenes <install extensions or Plugins<Install, must stay in the plugins folder or can stand even in the desktop? Messages SKETCHUP when I install the plugins rbz are ok, Quadface Tools STAY in the System preferences Window but I can not find it in tools / plugins ! Can anyone help me please? Thanks.
SKYNET-71
User avatar
SKYNET-71
Postby tt_su » Sun Aug 25, 2013 7:58 pm
Do not place RBZ files in your plugins folder. You can download them to anywhere else on your computer. Then use SketchUp.. Window > Preferences > Extensions > Install Extension and select the RBZ file.
Also not that some plugins require additional files.
User avatar
tt_su
SketchUp Team
SketchUp Team
Postby paulwolf » Mon May 12, 2014 10:55 pm
So I installed the plugin and it helped greatly. The problem I am having now is that it moved my plugins folder and I cant find it anywhere. It has messed up my Vray and when I try uninstalling and then reinstalling all of the plugins are still attached to the new download. Does anyone have any experience with this problem or advice. Much appreciated.
-Paul
paulwolf
Postby BeePee » Thu Sep 04, 2014 9:42 am
Your SU Plugins are excellent! Clean-up is especially brilliant, I use it all the time. One query though:
I'm having trouble importing complex STL files into Skethcup using the usual STL Import and Export plugin, so I searched and found su2stl to see if it would work better. I downloaded it and it's in my Loaded Plugins list.
However, there is no menu button to open it, and it's not in my Loaded Exrensions list. I downloaded your Simple Plugin Installer in the hopes it would do the trick, but no luck.
I know this isn't your program. but how do I get su2stl.rd working so I can use it to imp[ort STL files?
The STL files I'm trying to load (small complex models in mm) pop up instantly in Rhino, but Sketchup struggles. It will load simpler ones after quite a time, but not the more complex ones.
Final question: is there another STL importer that is worth trying for Skethup?
Thanks for your help,
BeePee
BeePee
Postby thomthom » Thu Sep 04, 2014 12:23 pm
BeePee wrote:I'm having trouble importing complex STL files into Skethcup using the usual STL Import and Export plugin,
What trouble? Might be worth addressing this first.
User avatar
PluginStore Author
PluginStore Author
Postby JMaults » Mon Oct 13, 2014 8:15 pm
So happy I found this!!! Im new to sketch up and I was having trouble installing the house builder extension which was a zipped file with .rb files. Was so lost! Time saver you are.
JMaults
Postby Box » Mon Oct 13, 2014 9:39 pm
You'll find the Sketchucation tools very handy for plugins too.
http://sketchucation.com/resources/plug ... e-download
User avatar
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: Arrahota, brufleck, goga63, Google Bot, Irina Petrova, qwesxqeliu, sihyeon0608, SuarmanGulo and 12 guests
Visit our sponsors:
