[Plugin] RichSection V0.5.8 UPDATED march 2015
@krisidious said:
Ok... SO far I have narrowed it down to Artisan and EcoScorecard that are causing conflicts with Rich Section.
Thanks for testing and reporting this conflicts....
I will mention it in 'known issues' for this plugin -
Hi all
This version is for testing, and feedback please.
- on mac
- for those on Windows having problems to run this plugin
This test version has logging switched on by default.
A log-file is created, and can be opened.- Open the file (and save as) : Menu/Plugins/RichSection/Open logfile....
- Copy the file. The file location is shown at startup (panel opening)and in the Ruby panel.
Logging can be switched off in Menu/Plugins/RichSection/Settings.
If problems, i would be glad to receive the complete log file (RichSection_log.txt), not just the last lines.I also added the spanish translation made by Santiago Molina (caronte01). Thanks Santiago, also for the other corrections! Everything ok in the spanish dictionary?
Thanks.
%(#FF0000)[file updated, on
april 26, 2014]
this time after instal all looks like ready to work.
I started do same testing and learning how it works and ... crashed
however mac version is progress
logs attached
cheers
logs attached
cheersLooks promising .... i was almost losing hope ! This is big news for me . Thanks for testing and reporting bimbachi
Can you give me some more information : What did produce the crash? Can you reproduce it again? What is the output in the ruby console? -
logs attached
Can you give me some more information : What did produce the crash? Can you reproduce it again? What is the output in the ruby console?Yes it looks fine, give me some time to understand plugin functions, will keep you informed
Hi Piet,
Great news, it works on the mac!!!!
Well, most of it. The console still shows some errors, and it is very slow(core2duo macbook from mid 2010), compared to my work pc (Core I7). Probably has to do with logging.
I can update an existing rich section, and I am currently creating a new one, but it is veeery slow (projection depth default should not be no limit, it makes rs veeery slow). Also, parameter change sort of works, but it will not update changes directly. The section has to be manually updated after closing the dialog.
Legend creation works
Info, does not work, it stops expecting start, but no indication on how to (enter, double click, right click)
What else should I check?
Great work!!!!
S
I'll keep testing
Hi Piet,
I had a quick look at the translation. It needs some small adjustments. I'll fix it as soon as possible.
Cheers,
Santiago
@caronte01 said:
Hi Piet,
I can update an existing rich section, and I am currently creating a new one, but it is veeery slow (projection depth default should not be no limit, ....it makes rs veeery slow). Also, parameter change sort of works, but it will not update changes directly. The section has to be manually updated after closing the dialog.
Great work!!!!
S
[attachment=0:1sf5tz6w]<!-- ia0 -->log.txt<!-- ia0 -->[/attachment:1sf5tz6w]
I'll keep testing
You can try out without logging (RichSection/Settings >> file & console >> No), and switch only on for debugging if errors occure.
I still have to make some more videos:- projection : for most, it can be swiched of; it make sense for plan view (i use it to show the beams under the next floorslab in grey pointed lines)
- info : select the tool, a RichSection sectionplan (or the sectiongroup), and than (without shift) a group or componentinstance of your model. An info panel should explain which sectionmaterial was or will be applied, and why it was applied.
- update on/off : only for moving, turning the sectionplan; for model changes : still manual update
What else to test : use it and report what sequences don't work (error, crash, not as espected)
About the spanish translation : you can do it in the excel file (without testing, and send it to me) or the .rb file (notepad, you can test). Keep a copy of the original rb : a missing \ or " will prevent the plugin to start.
Thanks for reporting and translating
For some reason I'm not getting the faces of the section. The section cuts, it adds the projection but no faces.
@pgarmyn said:
What did produce the crash? .... What is the output in the ruby console?
crash probably related to complex "projection"
this is ruby just after new restart of skp:
RS0.4.3|0.567|Logging to RubyPanel : true
RS0.4.3|0.005|Logging to File : false
RS0.4.3|0.001|PiGaRSection.userFileLocations MAC : /Users/tignaciuk/Library/Application Support/SketchUp 8/Sketchup/Materials
RS0.4.3|0.001|RSdefaultRSMats /Users/tignaciuk/Library/Application Support/SketchUp 8/Sketchup/Materials/RichSection-v0.3/#default.mat.skp : true
RS0.4.3|0.001|Start loading lang files : /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/PiGa_RichSection/
RS0.4.3|0.001|proc loadlang :
RS0.4.3|0.001|loadlang EN : /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/PiGa_RichSection/RichSectionLangEN.rb
RS0.4.3|0.001|loadlang file exists : true
RS0.4.3|0.003|Nesting:[] :
RS0.4.3|0.001|Nesting:[PiGa::RSection] :
RS0.4.3|0.001|language loaded : EN
RS0.4.3|0.002|Define context menu :
RS0.4.3|0.001|Define toolbar + menu :
RS0.4.3|0.003|rsMenu.add_item(:RS_menu) : #<Sketchup::Menu:0x12402bb4>
RS0.4.3|0.001|rsMenu.add_item(cmdCreate) : 50346
(eval):2837: warning: parenthesize argument(s) for future version
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2.rb:19: warning: already initialized constant PLUGIN_ID
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2.rb:20: warning: already initialized constant PLUGIN_NAME
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2.rb:21: warning: already initialized constant PLUGIN_VERSION
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:16: warning: already initialized constant VERSION_PATTERN
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/sketchup.rb:21: warning: already initialized constant COLOR_GL_POLYGON
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/sketchup.rb:25: warning: already initialized constant COLOR_ALPHA
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/sketchup.rb:29: warning: already initialized constant RAYTEST_WYSIWYG
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb:16: warning: already initialized constant PLATFORM_IS_OSX
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb:19: warning: already initialized constant PLATFORM_IS_WINDOWS
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb:22: warning: already initialized constant TEMP_PATH
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:23: warning: already initialized constant THEME_DEFAULT
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:24: warning: already initialized constant THEME_GRAPHITE
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:31: warning: already initialized constant EVENT_WINDOW_READY
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:43: warning: already initialized constant EVENT_CALLBACK
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:70: warning: already initialized constant EVENT_OPEN_URL
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:27: warning: already initialized constant BB_LEFT_FRONT_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:28: warning: already initialized constant BB_RIGHT_FRONT_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:29: warning: already initialized constant BB_LEFT_BACK_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:30: warning: already initialized constant BB_RIGHT_BACK_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:31: warning: already initialized constant BB_LEFT_FRONT_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:32: warning: already initialized constant BB_RIGHT_FRONT_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:33: warning: already initialized constant BB_LEFT_BACK_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:34: warning: already initialized constant BB_RIGHT_BACK_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:36: warning: already initialized constant BB_CENTER_FRONT_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:37: warning: already initialized constant BB_CENTER_BACK_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:38: warning: already initialized constant BB_CENTER_FRONT_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:39: warning: already initialized constant BB_CENTER_BACK_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:41: warning: already initialized constant BB_LEFT_CENTER_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:42: warning: already initialized constant BB_LEFT_CENTER_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:43: warning: already initialized constant BB_RIGHT_CENTER_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:44: warning: already initialized constant BB_RIGHT_CENTER_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:46: warning: already initialized constant BB_LEFT_FRONT_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:47: warning: already initialized constant BB_RIGHT_FRONT_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:48: warning: already initialized constant BB_LEFT_BACK_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:49: warning: already initialized constant BB_RIGHT_BACK_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:51: warning: already initialized constant BB_LEFT_CENTER_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:52: warning: already initialized constant BB_RIGHT_CENTER_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:53: warning: already initialized constant BB_CENTER_FRONT_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:54: warning: already initialized constant BB_CENTER_BACK_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:55: warning: already initialized constant BB_CENTER_CENTER_TOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:56: warning: already initialized constant BB_CENTER_CENTER_BOTTOM
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:58: warning: already initialized constant BB_CENTER_CENTER_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:59: warning: already initialized constant BB_CENTER
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:64: warning: already initialized constant MB_ICONHAND
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:65: warning: already initialized constant MB_ICONSTOP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:66: warning: already initialized constant MB_ICONERROR
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:67: warning: already initialized constant MB_ICONQUESTION
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:68: warning: already initialized constant MB_ICONEXCLAMATION
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:69: warning: already initialized constant MB_ICONWARNING
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:70: warning: already initialized constant MB_ICONASTERISK
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:71: warning: already initialized constant MB_ICONINFORMATION
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:72: warning: already initialized constant MB_ICON_NONE
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:74: warning: already initialized constant MB_DEFBUTTON1
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:75: warning: already initialized constant MB_DEFBUTTON2
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:76: warning: already initialized constant MB_DEFBUTTON3
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:77: warning: already initialized constant MB_DEFBUTTON4
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:82: warning: already initialized constant MESH_SHARP
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:83: warning: already initialized constant MESH_SOFT
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:84: warning: already initialized constant MESH_SMOOTH
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:85: warning: already initialized constant MESH_SOFT_SMOOTH
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:90: warning: already initialized constant POINT_OPEN_SQUARE
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:91: warning: already initialized constant POINT_FILLED_SQUARE
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:92: warning: already initialized constant POINT_CROSS
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:93: warning: already initialized constant POINT_X
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:94: warning: already initialized constant POINT_STAR
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:95: warning: already initialized constant POINT_OPEN_TRIANGLE
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:96: warning: already initialized constant POINT_FILLED_TRIANGLE
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:114: warning: already initialized constant VERSION
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:118: warning: already initialized constant PREF_KEY
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:121: warning: already initialized constant PATH
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:122: warning: already initialized constant PATH_LIBS
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:125: warning: already initialized constant PATH_LIBS_CEXT
(eval):344: warning: don't put space before argument parentheses
(eval):444: warning: don't put space before argument parentheses
(eval):666: warning: don't put space before argument parentheses
(eval):1221: warning: don't put space before argument parentheses
(eval):1403: warning: don't put space before argument parentheses
(eval):1627: warning: don't put space before argument parentheses
(eval):2702: warning: don't put space before argument parentheses
(eval):2703: warning: don't put space before argument parentheses
(eval):2824: warning: don't put space before argument parentheses
(eval):2845: warning: don't put space before argument parentheses
(eval):935: warning: don't put space before argument parentheses
(eval):936: warning: don't put space before argument parentheses
(eval):939: warning: don't put space before argument parentheses
(eval):943: warning: don't put space before argument parentheses
(eval):1520: warning: don't put space before argument parentheses
(eval):2496: warning: don't put space before argument parentheses
(eval):2498: warning: don't put space before argument parentheses
(eval):2531: warning: don't put space before argument parentheses
(eval):2533: warning: don't put space before argument parentheses
(eval):2973: warning: don't put space before argument parentheses
(eval):2983: warning: don't put space before argument parentheses
(eval):2994: warning: don't put space before argument parentheses
(eval):3004: warning: don't put space before argument parentheses
(eval):3102: warning: don't put space before argument parentheses
(eval):3129: warning: don't put space before argument parentheses
(eval):3138: warning: don't put space before argument parentheses
(eval):3143: warning: don't put space before argument parentheses
(eval):3220: warning: don't put space before argument parentheses
(eval):3223: warning: don't put space before argument parentheses
(eval):3226: warning: don't put space before argument parentheses
(eval):3268: warning: don't put space before argument parentheses
(eval):3269: warning: don't put space before argument parentheses
(eval):3324: warning: don't put space before argument parentheses
(eval):3325: warning: don't put space before argument parentheses
(eval):3506: warning: don't put space before argument parentheses
(eval):4556: warning: don't put space before argument parentheses
(eval):4635: warning: don't put space before argument parentheses
(eval):4997: warning: don't put space before argument parentheses
(eval):5052: warning: don't put space before argument parentheses
(eval):5096: warning: don't put space before argument parentheses
(eval):5100: warning: don't put space before argument parentheses
(eval):9026: warning: don't put space before argument parentheses
(eval):9026: warning: parenthesize argument(s) for future version
(eval):191: warning: don't put space before argument parentheses
(eval):291: warning: don't put space before argument parentheses
(eval):758: warning: don't put space before argument parentheses
(eval):906: warning: don't put space before argument parentheses
(eval):692: warning: don't put space before argument parentheses
(eval):699: warning: don't put space before argument parentheses
(eval):719: warning: don't put space before argument parentheses
(eval):739: warning: don't put space before argument parentheses
(eval):746: warning: don't put space before argument parentheses
(eval):766: warning: don't put space before argument parentheses
(eval):786: warning: don't put space before argument parentheses
7
key = Units
value = 0.0
(mac) same for me, it apears only after manual update
For SU 8 and Mac, you need the last test version. It will become the next official version.
http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072%26amp;start=210#p522628
You can switch off logging in the settings.
Still problems? -
Yes, that's the version I'm on.
Can you send me the log file after ...
- In a NEW model.... (Not opening an existing model)
- create a closed box
- group it
- select the tool 'RichSection creation' ( the most left on the RichSection toolbox)
- create a section through the unique group (important : wait until the plugin has finished : see ruby console)
- copy and post the log file (when opening Sketchup, a panel tells you where the log file will be created )
actually that did produce a face with a material in the section.
is a "solid" required for sectioning?
here's the log file.
is a "solid" required for sectioning? ...
As explained in the first post :
Elements don't have to be solid, but only closed sections will generate section-materials.
( and solids alwys produce closed sections) -
This is what I get on a simple structure or complex for that matter.
HI Kristoff,
Can you post that model?
S
In your rs settings, section was off (the first item on the list). Also, some of the groups/components in your model were non solid.
From my experience, rs works better with solids. I use tt's solid inspector a lot. RS works well with nested solids, and even with multi mesh solids (something native su solid tools has problems with).
Things to avoid:
Ungrouped geometry.
Dividing lines on coplanar faces, except when they are used to separate different materials.Santiago
