[Tutorial] Revit To SketchUp - How To
You can import a SKP directly into Revit - it should be imported as a 'massing element'; then you convert the various parts of it into walls, roof, floors, curtain-walling etc using Revit's tools so they can have the required 'intelligence' they need for later use... after that you can start looking at adding the secondary elements like doors etc and progress to your CDocs. If you don't import it as a massing element a SKP comes in as a 'block' that is relatively useless later - except for some fixed thing like a reception counter that doesn't need intelligence later...
SKP into Revit is therefore relatively straightforward BUT needs some work to meld the two together. In fact secondary building around your main building in Revit are more easily made as SKPs and imported.
If you export from Revit [as DWG/DXF] and thence into a SKP, you get a 'layered mess', with duplicated components that are actually identical - e.g. curtain-wall mullions. This makes the reverse process 'Revit into SKP' much more cumbersome, so much so it is not recommended except for very simple projects... -
Thanks TIG,
I have been watching many youtube videos and came to two conclusions so far..which one do you feel makes more sence? They both will work, just not sure which is more "practical".
1 - Draw each option in Revit, for rendering and presentation graphics only, export to SU for image creation. (Revit and Con. Docs will be required in either option).
2 - Do all design and change options in SU. When final design is approved either draw from scratch or import to Revit and do all the appropriate changes to make it construction Doc ready?
The videos show me that Revit is more capable then I originally thought it was?
Thanks for your advice,
Matte -
I'd have thought option 2 is the most applicable in your case...
Thanks TIG,
I think I'll follow that route. It's hard to shift away from SU as I allready known set most of the tools, but Revit seams like it will not be too bad and I can still import things from SU that I can not create in Revit. Thanks again! -
Be careful importing SU to Revit - it looks like it's in Revit - but it can not be rendered, and is fairly useless (at least it was until 2 years ago. I haven't used Revit in 2 years. I can build a curvy sink in 3D in SketchUp in a few minutes from a couple photos... takes hours in Revit.
If I try to bring the sink into a "family" in Revit it may show up on screen, but they deliberately do not allow you to render it.
Why? Well, I could be wrong, but as near as I can tell, they simply don't want Revit users to be able to use all the great free 3D models out there, but rather to have to pay for new unique content specifically made for Revit.
They will argue that you can't "flex" a 3D model from the warehouse, etc. But I will argue - since when do I need to "flex" a sink? A sink is a sink, and millions of models are like that - no reason I should have to create them especially in Revit for this.
Also, you can not smooth geometry (as of 2 years ago) in Revit (at least I never discovered a way). Segmented curves in your renders. Joy.
I just imported this sink/cabinet as wallbased normal cabinet, gave it new materials and render, so itยดs ok if you model curves if needed, the tap is lacking curvature, but so is the modeling.
I seem to keep coming back to this tutorial. Thanks for the tips here.
-Brodie
Just in case you guys hadn't come across this...here's the workflow that FormFonts uses to convert all of their Revit models into SketchUp.
http://formfonts3dmodels.com/2011/08/24/convert-a-sketchup-3d-model-to-revit/
Thanks mate, that helped me
This is SketchUp to Revit, not other way around...
