[Code] PCFileTools
I only works for UTF-8 [i.e. 'European' accented-characters etc] - the more complex Chinese/Japanese return false when it should be true
However, if we have a way of resolving one hopefully the other will follow... -
http://www.danielstutzman.com/2011/04/how-to-write-unicode-filenames-in-ruby-1-8-6 uses Win32API and iconv ...
BTW.. if interested:
This is the Extended lib module
FileUtils
from Ruby v1.8.6-p287
module FileUtils (Ruby v1.8.6-p287) -
from the old Pick-axe Book:
Strings are stored as sequences of 8-bit bytes,[For use in Japan, the jcode library supports a set of operations of strings written with EUC, SJIS, or UTF-8 encoding. The underlying string, however, is still accessed as a series of bytes.] and each byte may contain any of the 256 8-bit values, including null and newline. The substitution mechanisms in Table 18.2* on page 203 allow nonprinting characters to be inserted conveniently and portably.
- refers to the table of ** codes
So it seems that (in my mind,) since Sketchup sets
$KCODE
to UTF8 when it loads the interpreter, we may not actually have as much of a problem on the Rubyside as I thought.So we have a choice...
1) A pure-Ruby patch, that either accesses the system calls (for File functions,) via WIN32OLE or WIN32API (the so libraries.)
2) A compiled C patch, ie: "Cut out" the c code files that define classes
IO
,Dir
andFile
(perhaps alsoFileTest
,) and recompile with either UNICODE #defined, or change the C function calls explicitly to the wide versions. These would be ".so" files, and they would redefine the old methods. (What happens on the C-side when you re-define a C function that has already been defined? Do the C functions that the new Ruby wrappers call, need to be renamed as well?)
I was thinking that a C extension that did most of the functions used, like File.exist?, read, write, delete and list files in folders would go a long way. It wouldn't be as extensive as a complete rewrite - therefor more quicker to develop. Then off course not replacing the existing methods - as it'd just open up a vast pool of possible problems which would require even more testing and development.
Trying to rewrite the entire File, Dir and IO classes to call the W variant file function just seems like such a massive undertaking that it'd probably never be completed.
Does Sketchup set
$KCODE
to "UTF8" in all locales - I know it does in UK/US and probably European language locales BUT what about Chinese ? I'll ask someone...
If we get a consistent code for their locale can we modify the pack/join code to say use 'u' not 'U' and get an appropriate conversion in different $KCODE cases ? -
@thomthom said:
Then of course not replacing the existing methods - as it'd just open up a vast pool of possible problems which would require even more testing and development.
Well what I said before still goes... The new class(es) are in a Library namespace, need to be
require
(d), and then referenced within an author's namespace via an alias, (as I showed in the examples above.)I mispoke when I said redefine, they would have the same identifiers, but be within, say
SKX::WIN
I was hoping (without yet digging into the C source,) that it might be easy to use Notepad++ search and replace to stick "W" where they need to be.
Don't think it's that easy. I think there's a few type definitions that also needs to be adjusted. And then you need to ensure that there's no hard coded struct or data type sizes used...
Poking around, finding links to help Adam on his Hebrew webdialog problem, I ran across a link on the Wikipedia Windows Code Pages doc.
Down at the bottom:
See also
AppLocale — a utility to run non-Unicode (code page-based) applications in a locale of the user's choice.
BUMP
