by bonzi_ses » Mon May 14, 2012 11:03 am
Thank you very mauch
bonzi_ses
- Name: bonzi
by ZyberCool » Sun Sep 30, 2012 6:31 am
thanks bro..
ZyberCool
- Name: Jan
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: other
- Level of SketchUp: Beginner
by redgray » Wed Dec 12, 2012 7:23 am
i like align tool just like in autocad command, thanks a lot for this tool.
redgray
- Name: redber de pascua
- License type: Free/Make
- SketchUp use: architecture
- Level of SketchUp: Intermediate
by desunvn » Wed May 08, 2013 3:37 am
Didier Bur wrote:Hi, Here is an updated version of my align tool with a bug fix (components were deformed when non orthogonal axis were clicked). User guide also added. Regards,
thank for sharing
desunvn
- Name: dess
- SketchUp use: education
by rv1974 » Tue May 21, 2013 12:43 pm
Didier, could you please add 'multiple copy' and 'preserve original instance' options (may be with say CNTRL key pressed once)? P.S. I hope I post in the right topic: is it Tools\Align command? (Align, align tool, align 2D, align 3D.. I'm confused a bit).
rv1974
- Name: rv1974
- SketchUp version: 2017
- License type: Pro
- Level of SketchUp: Advanced
by irwanwr » Thu Oct 10, 2013 11:24 pm
Anyone experienced groups/components axes that cannot be hidden or erased? I've this plugin for quite long. But lately just realise that axes cannot be hidden or removed from the groups/components on the screen. How should i clear those axes after aligning groups/components? Thank you.
irwanwr
- Name: irwanwr
- SketchUp use: hobby
by cotty » Fri Oct 11, 2013 6:24 am
You can change the visibility of the component axes here:
cotty
- Top SketchUcator
- Name: Carsten
- SketchUp version: 2019
- License type: Pro
by irwanwr » Fri Oct 11, 2013 6:56 pm
I forgot to check that Checked Window - Preference only several times. Seems that I forgot how to read and use SketchUp. Thanks a lot, Cotty.
irwanwr
- Name: irwanwr
by JPC2j3 » Wed Jan 22, 2014 12:52 am
I recently down loaded and installed the plug-in in the zip file. I have been experimenting with the plug-in to learn how it works. When I try to use the tool, my SketchUp crashes every time. Let me explain as best as I can what happens. I create two objects (usually two cubes or rectangles; I’m just experimenting). I pick a corner of one object and create an X and Y axis (should there be a Z axis showing at this point?). When I try to connect the origin point of the first object to the corner of the second object, I get a crash. I have viewed the training video numerous times so I believe I am using the plug-in correctly. I’m seeking some help in understanding what I am doing wrong. Thanks
JPC2j3
- Name: John Payne
- SketchUp version: 2013
- SketchUp use: product design
by robertWan » Thu Feb 06, 2014 6:52 pm
Could you add an option to copy (Ctrl) for plugin ALIGN 3D? Now objects are moved.
Robert
robertWan
- Name: RobertWan
- SketchUp use: woodworking
by kupono » Sun Mar 23, 2014 1:42 am
Align tool 3D doesn't want to work with SU 2014. Is this a ruby version thing? I miss being able to use it.
kupono
- Name: Kupono
- SketchUp version: 2014
- License type: Pro
by otb designworks » Fri Mar 28, 2014 12:19 am
Can anyone confirm that this is not working in Su14 on a mac mavericks?
I installed the plugin both through the sketchucation plugin store and also through Didier's thread here.
Neither plugin appears in TOOLS and there is no align choice in the context menu when something is selected.
It's like the plugin doesn't exist, though it shows up in the plugin manager, and is in the user/library.../plugins location.
Thoughts?
Cheers, Chuck OTB Designworks is on Youtube6 core nMP, 32 gig RAM, (2) D700 GPU's, dual monitors
otb designworks
- Name: OTB Designworks
- Operating system: Mac
- SketchUp version: 2015
- License type: Pro
by Box » Fri Mar 28, 2014 12:48 am
This might get it going for you. On the appropriate file, this is copied from the lines to tubes thread. TIG wrote:Didier needs to rework his rb file for v2014 compatibility and republish it... BUT you can do it temporarily for your own use, even though his script is 'packed'. Open the file lines2tubes.rb in Notepad, and go to the end: Change ...}.unpack("m").to_sto read ...}.unpack("m")[0]Save the changes. Restart SketchUp. The script will then load and work in v2014 ! This simple fix can be applied to any of Didier's 'packed' scripts that aren't working in v2014. These edited scripts will also load and work in earlier SketchUp versions too...
- Name: Box
- License type: Pro
by kupono » Fri Mar 28, 2014 9:54 am
This is what I get when opening align_tool.rb in notepad.Bytecode? Capture.PNG
kupono
- Name: Kupono
- License type: Pro
by Box » Fri Mar 28, 2014 12:04 pm
And if you scroll to the end as Tig says do you not see the bit that needs to be changed.
- Name: Box
- License type: Pro
by otb designworks » Fri Mar 28, 2014 1:53 pm
Thanks for the response!
I changed the code to read as TIG said it should (image 1). I also tried it with a space between the ) and the [ with no difference
Now, when I start SU, I get this error message (image 2)
thoughts?
otb designworks
- License type: Pro
by Box » Fri Mar 28, 2014 2:16 pm
Sorry, I only know it works on windows.
- Name: Box
- License type: Pro
by otb designworks » Fri Mar 28, 2014 3:42 pm
Weird...
While I understand the drive to "upgrade" to Ruby 2.0, it is pretty frustrating that many old plugins don't work any more.
otb designworks
- License type: Pro
by nagrom345 » Thu Apr 24, 2014 8:19 pm
I can't get this plugin to work with Sketchup 2014. Does anyone have and ideas about this. Thanks.
nagrom345
- Name: Scott
- License type: Pro
- SketchUp use: landscape architecture
by agrazdi » Wed May 14, 2014 3:17 pm
Is it posible to update it for SU 2014 ?
agrazdi
by agrazdi » Wed May 14, 2014 11:57 pm
agrazdi wrote:Is it posible to update it for SU 2014 ?
I didn`t read TIG's post. I followed his instructions and it works fine in su 14. Thanks TIG
agrazdi
by TIG » Tue Nov 04, 2014 5:01 pm
Didier has agreed that I might update some of his Plugins in the PluginStore so they are v2014/2015 compatible. This is the latest version Download
- Global Moderator
- Name: TIG
- SketchUp version: 2018
- License type: Pro
by kupono » Tue Nov 04, 2014 11:59 pm
Thanks for the updates Tig. I was missing Align 3D.
kupono
- Name: Kupono
- License type: Pro
by john2 » Sun Mar 01, 2015 7:41 am
this tool is not showing up in context menu. I am using version 2014 make
Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
john2
- Name: john2
- License type: Pro
by TIG » Sun Mar 01, 2015 11:45 am
It works fine in v2014 and v2015. It appears near the end of the Context menu as 'Align' - you must have something Selected... What happens if you copy+paste this command into the Ruby Console + <enter> ? load 'align_tool.rb'The older versions <=v1.1 are NOT compatible beyond v2013, because of the Ruby upgrade. So, are you using the very latest version [v1.1x] available from the PluginStore which was made compatible with all SketchUp versions [sorry but it's in ENglish only]... viewtopic.php?p=76774#p76774http://sketchucation.com/pluginstore?pln=align_toolIf NOT then please get the latest version's RBZ installed... Report back if there are continuing issues...
- Global Moderator
- Name: TIG
- License type: Pro
by john2 » Sun Mar 01, 2015 1:45 pm
TIG wrote:It works fine in v2014 and v2015. It appears near the end of the Context menu as 'Align' - you must have something Selected... What happens if you copy+paste this command into the Ruby Console + <enter> ? load 'align_tool.rb'The older versions <=v1.1 are NOT compatible beyond v2013, because of the Ruby upgrade. So, are you using the very latest version [v1.1x] available from the PluginStore which was made compatible with all SketchUp versions [sorry but it's in ENglish only]... viewtopic.php?p=76774#p76774http://sketchucation.com/pluginstore?pln=align_toolIf NOT then please get the latest version's RBZ installed... Report back if there are continuing issues...
I get this load 'align_tool.rb' true That's really weird. I am getting this option align in my right click menu. Restarted sketchup and wow! my option is coming. This problem was occuring in both my PC and laptop. I am sitting on my laptop currently and the problem is gone. Didn't know what created it. Moreover on both my machines, I installed the latest version straightaway by accessing the plugin store inside sketchup via SCF plugin. Thanks for replying.  Maybe this ruby console has healed my problem, dont know.
john2
- Name: john2
- License type: Pro
by TIG » Sun Mar 01, 2015 1:58 pm
If it recurs see if there are any Ruby Console messages and post them. Maybe it was just a general glitch that needed a SketchUp restart to fix it ?
- Global Moderator
- Name: TIG
- License type: Pro
by rv1974 » Mon Feb 19, 2018 1:41 pm
There's a huge issue with this tool (I noticed it after dekade of using  ) - it distorts objects. Additional operation needed (reset skew, rotation) afterwards. Any chance to to fix it please?
rv1974
- Name: rv1974
- License type: Pro
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Plugins
