[Plugin] Scale and Rotate Multiple (UPDATED Dec 22, 09)
Re: [Plugin] Scale and Rotate Multiple (UPDATED Dec 22, 09)
Postby irwanwr » Fri Jan 06, 2012 7:27 pm
hi Chris,
thank you for the plugin. don't know whether i am going to use it soon or not.
but this plugin obviously can help someone create a jungle with ease :D
User avatar
irwanwr
Postby vmoccia » Thu Jul 26, 2012 12:15 am
Chris,
3 years later, this is still an awesome find. So useful, thank you. In regards to using the tool to generate randomization of camera-facing components...If you make a group of components (say three copies of a tree, already randomly placed and scaled), you can then create an array of that group. Application of your tool to the array will randomly scale-rotate the group and create an even more random disposition.
You've cut my tree-planting workload by a third. thanks again.
vmoccia
Postby mgeras » Thu May 02, 2013 4:27 am
thanks a lot. you are great.
mgeras
Postby popfunky » Wed Sep 18, 2013 10:30 am
GREAT
popfunky
Postby popfunky » Wed Sep 18, 2013 10:59 am
THANK YOU
popfunky
Postby HornOxx » Wed Oct 16, 2013 5:38 pm
as always - a great tool again ! thank you
never trust a skinny cook
User avatar
HornOxx
Postby wat » Sun Nov 10, 2013 1:09 pm
thank sir
wat
Postby wat » Mon Nov 18, 2013 2:31 pm
wat
Postby HornOxx » Thu Jan 30, 2014 9:29 pm
once again THANK YOU! - A wonderful tool that I use almost daily
User avatar
HornOxx
Postby SUNutz » Sat Mar 01, 2014 8:01 pm
Wow! this is mind blowing. For its simplicity and effectiveness. Thanks!
SUNutz
Postby TommyK » Fri May 09, 2014 3:29 pm
I use this plugin almost everyday. Many thanks!
As a "power" user, I have noticed performance issues when applying the script to lots of components. In a model with hundreds of components, it gets very sluggish indeed, and the memory usage of Sketchup goes through the roof, and sometimes ends in a bugsplat.
I am happy to take a look and see what optimisations are possible in the ruby script, but before I do so, I should ask if you have had a go at optimisation already? Do let me know!
Tommy
User avatar
TommyK
PluginStore Author
PluginStore Author
Postby onzki » Wed Jun 11, 2014 10:18 am
Thanks for sharing this.. it will be very useful in my work. By the way, I have a similar need, this time multi-face scale plugin, to scale a multiple polygon/faces in one go. Is this possible? My screenshot:
Thanks a lot!
[/hr]Dell Precision T5600. SKU 2018 Pro. AutoCAD 2013. Landscape design firm. Hong Kong
onzki
Postby pilou » Wed Jun 11, 2014 11:50 am
Just transform all your faces in group or component then apply the Scale multiple! ;)
By Tig each face in Component
Code: Select all
m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|(g=n.add_group(e);g.to_component.definition.name="Face#1")if e.class==Sketchup::Face}
You have in the same spirit the Multiple face Offset by Remus! :)
Speedy Galerie
User avatar
Top SketchUcator
Postby potemutzu » Wed Jan 28, 2015 5:59 pm
Thank you for a very usefull plugin
potemutzu
Postby JQL » Sun May 21, 2017 4:15 pm
Hi Chris,
I know you've been busy with other things but I'd like to make a request on this plugin, if you wouldn't mind.
I'd like it to work on a choosen axis. Right now we can choose axis, center, base or world, but they all act acording to the Z axis. It would be cool to be able to choose the X or Y axis as a base too.
Thanks in advance,
João
User avatar
JQL
Premium Member
Premium Member
Postby HornOxx » Sun May 21, 2017 5:54 pm
:thumb: this is a great suggestion - i join this request :)
User avatar
HornOxx
Postby pilou » Sun May 21, 2017 8:15 pm
You can solve that in rotate your objects before apply the script! ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby JQL » Sun May 21, 2017 8:32 pm
I know I can do that but I have 1643 individual objects that I wanted to randomly rotate.
They were 1643 groups all aligned to the Y axis. I could get inside each one of them and change the Y axis to become the Z axis. But I would be mad if I did that...
Also, I can see myself wanting to do this a LOT more times, and I think, if this plugin would allow it my life would be easier.
Chris, certainly has other things in his mind though, because he hasn't dealt with plugins for ages, nor showed himself up around that often, but he is still very much connected to Sketchup and probably he could take a look at the script easily.
If not... I'll have to deal with this kind of stuff myself or find alternatives...
Thanks for your attention.
User avatar
JQL
Premium Member
Premium Member
Postby pilou » Sun May 21, 2017 9:31 pm
Random Rotation by Sdmitch ;)
+ few Random Select by Tig + Scale Multiple does make the trick!
Speedy Galerie
User avatar
Top SketchUcator
Postby JQL » Sun May 21, 2017 10:50 pm
Thanks Pilou I'll try Random Rotation
User avatar
JQL
Premium Member
Premium Member
2015
Postby tomaszdrgas » Mon Jul 03, 2017 6:49 am
Does it work with sKetchup 2015.. ?
I installed but nothing in Extensions>Chris Fullmer Tools> I have there extended views already.. Maybe issue is only the change of "plugins" folder name to "extensions"..
Tomasz
tomaszdrgas
Re: 2015
Postby TIG » Mon Jul 03, 2017 8:27 pm
tomaszdrgas wrote:Does it work with sKetchup 2015.. ?
Tomasz
This is an old toolset...
However, I are concerned about your comment regarding Plugins folder versus Extensions folder !
All installed extension/plugins go into your user Plugins folder.
The renaming of the menu item from Plugins to Extensions is not important.
Any code referencing the Plugins menu auto-corrects to the Extensions menu.
This tool appears under the Extensions > Chris Fulmer Tools submenu ???
https://sketchucation.com/pluginstore?p ... e_multiple gets you the RBZ...
Use the built-in Extensions > Installer tool to get it installed properly.
User avatar
Global Moderator
Postby Einstein » Tue Jan 09, 2018 1:04 pm
Hey! Adding a non-uniform scale (1 axis only) would be cool!
But the plugin is cool anyways :D
Einstein
Postby Einstein » Sat Feb 03, 2018 12:11 pm
And also adding a feature of remembering settings and ability to rotate horizontally and vertically.
If you have any plans to continue developing this great plug ;)
Einstein
Postby stuff4oleg » Wed Jan 23, 2019 2:06 pm
+1 vote for doing non-uniform scale.
Let me describe the purpose. I use it for making tiled texture tiling not so noticeable. For example if I have 1 wood plank texture and I create 100 plank faces and apply texture to them - this is Not very convincing. I can add some variation by using Random Select + Scale and Rotate Multiple to rotate some of the planks 180 degrees around their center points. Now tiling is less noticeable. But with Random Select + (-1 Scale X/Scale Y/Scale XY) I can have 8 different variations from a single texture! basic+3 scale variations + 180 rotated+3 its scale variations
stuff4oleg
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
cron
Who is online
Users browsing this forum: elijahpekaar, Grauer, Skyflyer, spacewalker43, witnessoftheend and 53 guests
Visit our sponsors:
