[Plugin] FredoTools - v4.5a - 02 Apr 24
Thank you very much, I got it. Also thanks for all your great tools and plugins. I just start to learn and appreciate your tools since I'm beginner but nevertheless I can see the greatness.
Hello everybody!I'm trying to make a bent stair, so I created the stair's "profile" and intended to bend it using radial bending and then joint push pull in order to give it width.
in order to do that, I made the steps as simple as possible and turned slicing off (so that the shape would be bent only at the vertical edges.
unfortunatelly, bending screwed up the normals and when I tried to use the JPP faces were extruded weirdly.
Is there something I can do about it?
I know that a solution would be to extrude first and bend later, but because of reasons of repetition and workflow It would serve me better to do it this way -
When i install this plugin it tells me, you need the version 5.2 libfredo and so on, and i have that, or even a later one, so after ive installed it nothing happens? the same thing happened to fredoScale but for some reason that got installed, and im using it without a problem? any quick solution ?
Instead of using soften/smooth on the vertical almost-coplanar edges try making them just 'hidden' ??
NEW RELEASE: FredoTools v1.5a - 27 Nov 13
FredoTools 1.5a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
NEW RELEASE: FredoTools v1.6g - 24 Jan 14
FredoTools 1.6g is a release for EdgeInspector v1.0.
Fredo, thank you, again. You are generous, and talented.
Thanks Fredo for this new useful tool !!
I have updated the Spanish Language (Spain) to include EdgeInspector.
Spanish Language (Spain) v1.6g -
Oxer,
Thanks for that. This is a piece of work.
Will go into the next release, so very soon.Fredo
I now get this error:
FredoTools 1.6g: Error starting up plugin (creating menus and icons)
undefined method 'values' for nil:NilClass [in FredoTools.rb -
#'startup(): line 210]
...Lib6Core.rb:580in 'effective_load_part2'Then an error message with a Trace Log...
Am using LibFredo v5.5g. -
NEW RELEASE: FredoTools v1.7a - 15 Feb 14
FredoTools 1.7a is a release for EdgeInspector 1.1a, which introduces the detection and fixing of 2 new defects: lost junctions and needle-eyes.
See main post of this thread for Download of FredoTools.
Thank you for this great update!
dedmin, how do you grab into .wmv?
Thanks for signaling. This is actually a bug concerning Curvizard, not FredoTools.
I fixed it and republished as Curvizard 1.7b.
The latest version, the pop-up dialog box displays a blank。
Be sure to activate the other tools, and then activate it to appear.
Earlier versions without problems -
guanjin,
This may be related to the Chinese translation. Do you get the error if you switch to English?
Also, could you check if there is no error displayed in the Ruby consoleFredo
@fredo6 said:
guanjin,
Also, like switching to English,The same problem。
After activation texture tool display properly activated, see the movie.
On SU 2014 Make the tool bar don't ok for:
Fredo tools
curvizardThanks.
