[Plugin] ExtrudeTools - Full Set
Re: [Plugin] ExtrudeTools - Full Set 20130530
Postby Rich O Brien » Wed Oct 30, 2013 12:28 pm
And you are running the very latest release of 2013?
What's inside the ExtrudeTools folder?
You've the extension enabled under preferences?
You have it enabled in the SketchUcation Tools Managers?
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby Aris » Wed Oct 30, 2013 12:31 pm
That's weird!
after I checked and unchecked it from the toolbars dialogue and moving around the other toolbars, it finaly appeared but without a frame, so I cannot move it!
Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
User avatar
Aris
Premium Member
Premium Member
Postby Aris » Wed Oct 30, 2013 12:34 pm
yes, I told you, it is checked/visible everywhere
plugins manager, plugins menu, preferences/extensions, toolbars dialogue
it's only absent in the toolbar right click menu.
User avatar
Aris
Premium Member
Premium Member
Postby Box » Wed Oct 30, 2013 12:42 pm
Double click on it now you can see it and it will come loose.
User avatar
Postby Rich O Brien » Wed Oct 30, 2013 12:42 pm
Try this: Enable the toolbar in View>Toolbars. Pull all of the toolbars off the top rows. Does the Extrude Tool toolbar show up in the upper left corner? If so, you have now found it and can place it where you need but you really ought to install the current version of SU2013. there was a bug in the first release that caused new toolbars to appear under the existing ones. It was fixed though.
Dave earlier mentioned this...
To me it looks like this is related to the bug Dave flagged.
What happens when you check for update under the Help menu?
User avatar
Rich O Brien
Administrator
Postby Aris » Wed Oct 30, 2013 12:50 pm
Sometimes giving up helps!
I reverted to the old plugins folder, relaunched SU and every toolbar appeared undocked, including ET!!!
I relaunched it a couple of times and now it seems stable.
finally to enjoy it (it's a great plugin).
User avatar
Aris
Premium Member
Premium Member
Postby Aris » Wed Oct 30, 2013 12:51 pm
Doesn't installing it from plugin store guarantee that it's the latest version?
User avatar
Aris
Premium Member
Premium Member
Postby Box » Wed Oct 30, 2013 12:53 pm
He means the newest version of Sketchup itself, your problem suggests you have an old version.
User avatar
Postby Aris » Wed Oct 30, 2013 1:01 pm
sorry, my bad. I thought you were referring to the plugin version all this time, I'm downloading latest sketchup right now. Thanks for bearing with me.
User avatar
Aris
Premium Member
Premium Member
Postby Rich O Brien » Wed Oct 30, 2013 1:03 pm
Easy to miss out.
Glad it works
User avatar
Rich O Brien
Administrator
Postby Dave R » Wed Oct 30, 2013 1:04 pm
Yes. I wrote "...install the current version of SU2013." because I meant the current version of SketchUp.
User avatar
Global Moderator
Postby thegoodguy » Mon Nov 04, 2013 3:49 pm
HI,
Great set of tools. Thanks.
A two-part question:
About the "edges by face" and "edges by faces" tools. Is it possible to specify which point on the face(s) the edge endpoint aligns with? E.g. can you start the extrusion from the one of the pointed tips of a star-shape instead of the centre of the centre of the face?
About the "edges by faces" tool. Is it possible to specify which endpoints on the starting face align/match-up with which endpoints on the ending face?
I hope these questions make sense. I've attached an image to show what I mean. Shape (A) was produced using the tool. Shape (B) I did manually by choosing which endpoints are matched and then using a curve-stitching tool.
Thanks again.
thegoodguy
Postby jefecito » Mon Nov 11, 2013 9:16 pm
The toolbar not load, is it normal in SU 2013?
jefecito
Postby Dave R » Mon Nov 11, 2013 11:18 pm
The toolbar displays just fine in SU2013 unless you installed the plugin incorrectly or perhaps don't have sufficient privileges set for the Plugins folder. What operating system? (please update your profile), how did you install the plugin? Do you have sufficient privileges?
User avatar
Global Moderator
Postby pgarmyn » Tue Dec 10, 2013 10:53 pm
I use your excellent Extrude-tool in another thread :thumb: :thumb:
(http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072) )
I'm afraid that I have to report a small bug.
With the Extrude-by-rails (I didn't test the others).
I have almost always an unexpected result if the profile turns exactly 180° around Z (didn' test for the other axes). It could be a 'division by (almost) zero' (tangent).
I also used Jim's drawhelix14 plugin :thumb:
helix-extrude-bug.skp
pgarmyn
PluginStore Author
PluginStore Author
Postby TIG » Wed Dec 11, 2013 12:12 pm
If you pick the obvious profiles and rails you get your result.
However, if you pick a 'sweeping rail' as the first profile, then the two 'end' curves as the rails, and the other 'sweeping rail' as the melding profile, then it works... The 'direction' of the form might twist unexpectedly.
Another solution is to rotate the 4 curves [temporarily] by say 1 degree, then it works as I think you had hoped - no 'twisting' etc...
See the screen-grab...
It's not so much trigonometry, more having to decide in which direction the mesh goes, obviously if it's a 50:50 chance with axial alignments it can guess wrong... :?
User avatar
Global Moderator
Postby pgarmyn » Wed Dec 11, 2013 8:48 pm
TIG wrote:However, if you pick a 'sweeping rail' as the first profile, then the two 'end' curves as the rails, and the other 'sweeping rail' as the melding profile, then it works...
Yes, the result is also logic, but not the one i wanted.
TIG wrote:Another solution is to rotate the 4 curves [temporarily] by say 1 degree, then it works as I think you had hoped - no 'twisting' etc...
I can live with it. :D
Thanks for the 'research' and the explanation. :thumb:
pgarmyn
PluginStore Author
PluginStore Author
Postby TIG » Thu Dec 12, 2013 10:42 pm
Here's a new future-proofed update.
viewtopic.php?p=217663#p217663
User avatar
Global Moderator
Postby yhchen » Tue Jan 14, 2014 6:35 am
I have a problem. I tried to use the extrude edges by rails by face function. But the was one one component form on the profile section. I don't understand why.
Below there is 2 attached jpg files, it is the print screen of the process and the outcome.
Please help me!!!! Thank you
Yhchen
yhchen
Postby TIG » Tue Jan 14, 2014 8:56 am
@yhchen
If you run it with the Ruby Console open are there any error messages ?
Is the geometry very small ?
Try it with the profile face reversed - it should work either way but who knows ?
Can you attach a SKP containing the 4 curves and the face so we can look at it...
User avatar
Global Moderator
Postby yhchen » Tue Jan 14, 2014 10:58 am
Dear TIG,
Thank you for ur quick response.
I have tried to run it with Ruby Console, n I found lots of error occur, which I do not understand why.
Regards,
Yhchen
yhchen
Postby TIG » Tue Jan 14, 2014 2:55 pm
@ynchen
I have tested the SKP and get good results.
See the attached image.
The up/down orientation of the face does not affect the result.
The over all size of the geometry is within sensible limits.
You errors...
EE Error 3:
means that it is failing to add a curve from the cpoints it has got from the melding-profile...
EE Error 4:
is a similar error relating to the profile...
I can't reproduce any errors... :?
Your image shows one corrected located profile and one set on cpoints following a reversed curve, NOT the profile/melding-profiles lines... before the early failure :?
Here are my thoughts...
Do you have Guides switched on?
The toolset uses cpoints etc...
Your SKP is v6 - I don't have that version readily available to test so it might be a limitation - from available methods for your set up; although the API methods used are for >=v6 ?
Why not upgrade to a newer 'free' version of SketchUp - it is much improved... v2013 'Make' ?
Different versions can co-exists on the same PC.
Are you using the latest version of this Extrude toolset [v2.2] ?
If not then please get the latest RBZ from the PluginStore pages...
http://sketchucation.com/pluginstore?pln=ExtrudeTools
If you have v8M2 or newer you can AutoInstall from the SketchUcation PluginStore dialog within SketchUp or use the Preferences > Extensions > Install... button to do it automatically for you...
In SketchUp versions <8.M2 you'll need to rename the RBZ as a .ZIP file, and then extract its contents and manually move them into the Plugins folder***
[if you are not an Admin, make yourself an Admin using the Users Control-Panel: then make sure the Plugins folder has FULL read/write permissions set for every user/group listed under Properties > Security > Edit...]
***Always leave helper files within the same subfolder[s] that are inside the ZIP.
After an update restart SketchUp twice: as it'll need to remove older versions is you have a very out of date installation etc...
Lastly, what other plugins do you have loading?
Are any of those quarantined or rogues, as explained in other posts ?
User avatar
Global Moderator
Postby yhchen » Tue Jan 14, 2014 11:48 pm
Hello,
Thank you for your help, I have upgrade my sketchup to 2013 version. now it works perfectly.
Thank you again for your awesome plugins. All the best ^^
Regards,
Yh chen
yhchen
Postby bob777 » Sun Jan 19, 2014 10:24 pm
Very useful...this one and the others. Just made a donation.
bob777
Postby chri » Sun Mar 02, 2014 11:35 pm
hello TIG
I have SKETCHUP PRO 2013
I installed the plugin ExtrudeTools V2.2
it works fine.
I installed SKETCHUP 2014 2 days ago to test this new version.
Something does not work, can you, please take a look at the following pictures
Perhaps the plugin is'nt up to date or there is something wrong with my machine !
Chri
Best Regards
User avatar
chri
Postby Dave R » Sun Mar 02, 2014 11:41 pm
Did you install a fresh copy of TIG's plugin? Or did you just drag the old copy over from the previous Plugins folder?
User avatar
Global Moderator
Postby chri » Mon Mar 03, 2014 12:00 am
Dave R wrote:Did you install a fresh copy of TIG's plugin? Or did you just drag the old copy over from the previous Plugins folder?
hi DAVE
i have install a fresh copy directly in SKETCHUP 2014 with the plugin store
chri
User avatar
chri
Postby TIG » Mon Mar 03, 2014 12:11 am
@Chri
If you get v2.2 of the tool's RBZ from the PluginStore and install it from the RBZ [i.e. don't drag+drop from an opened RBZ as if it were a ZIP file etc] you should then get fresh copies of all of the needed files [including the required helper "deBabelizer.rb"].
The error you posted relates to an incompatible version of that file - old ANSI v new UTF8-without-BOM.
The new version of Ruby used by SketchUp 2014 is less forgiving and cannot use that text file encoding.
Most authors have updated their scripts to have the correct encoding, and thereby suit all versions of SketchUp.
The files in this tool's latest PluginStore RBZ are all correctly encoded.
To double check I have just reinstalled from a newly downloaded RBZ and it worked fine - the enclosed files are all correctly encoded - I checked :?
It looks like you copied an older one over from an earlier version's Plugins folder ?
Reinstall properly, restart and retest...
Or have you installed anything else including deBabelizer.rb ?
The few RBZs that do include it should all be correctly encoded if the latest versions are downloaded and installed...
An old version will cause issues...
User avatar
Global Moderator
Postby TIG » Mon Mar 03, 2014 3:18 pm
Here's v2.3
A minor glitch [typo] is now fixed and it's compatible with v2014 once again :roll:
User avatar
Global Moderator
Postby Box » Mon Mar 03, 2014 3:22 pm
If you want confirmation, loft wasn't working for me in 2014 and now is. Thanks.
User avatar
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: jbkuun, ldf, nuntapat, Phcg01 and 10 guests
Visit our sponsors:
