[Plugin] RichSection V0.5.8 UPDATED march 2015
Try again
@Rich
thanks,
that wil be for Tomorrow.....
(I'm now on my tablet)
I need to be on a PC to save it..... -
[highlight=#ffff00:36m3noq6]Sorry. I thought you might be more receptive to end user / potential customer feedback.[/highlight:36m3noq6]
Obviously I'm wasting my time testing the demo.
RichSection is now in the 'SketchUcation Plugin Store' browser...
Hi pgarmyn, I've been willing to test your plugin since a while now.
It is very good, fast and does what it purposes. Though in my workflow I still have some issues because of what I told you about in some posts earlier, I can see it becoming useful in the near future.
What I really like about it is that it creates instantly the ortho scenes (I must agree that so much "twin" scenes is a bit too much though. (for style saving wouldn't 1 of this scenes be enough? Well I suppose not...)
The projection feature by itself is a must but it will be erased by delete guides for sure every now and then. SU should be able not to delete at least the guides that are inside a locked group...
I have probably a bug and a question for you though, and you can look at attached images and file for more info on BUG and QUESTION
BUG (?) - I deleted a material that I previously have used as rich section (#Insulation) and then inserted a new material and named it after the deleted one. Rich section doesn't deal with the new (#Insulation) material. All groups in Layer Insulation now are getting sections on the #default material.
QUESTION - Would you consider adding a feature that would find loops in sections corresponding to groups inside other groups? Now, if you have those cases, sections from different groups will not intersect. They wiil only juxtapose/interfere on each other creating the effect that happens with two coplanar faces with different textures applied. It would probably be a viable alternative for getting some more detail in models.
Right now this feature and the fact that a lot of layers, materials and scenes are created that I don't need, are the only things keeping me waiting for further developments.
Congratulations again and best regards,
JQL
@JQL
I will take some time this evening to look at your file.
About the number of files and scenes: At this moment I need at least a scene and a style with the sectionplan active and visible, and without the camera applied. They are activated before changing parameters and (re)calculation. But the purpose is to use the result directly in Layout. To use it, the camera must be applied by and the sectionplan should be made invisible. Therefore I need a second scene. there is no way to hide a scene(?) I could load and save one scene on disk, but that will slow down, give a lot off crashes, and will give problems with the Undo-action.I will continue this evening....
Hello again.
I wouldn't like to bore you with my problems,
my intention is to help with development of this great plugin.New version fixed expiration problem.
But I'm afraid plugin is not working for me at all.
Rich section creates scenes and materials, but no new faces are added.I did a fresh install of skp without all plugins but problem remains.
Ruby console doesn't report any exception.I attached screenshot to describe problem...
It is sketchup 2013 on Win7 and newest release of RS from sketchucation plugin manager.
Maybe i'm missing some of extended or inherited rb's?
I hope it's problem on my side, so others can enjoy this plugin.
But i thought this should be reported as well.
Your screenshot is very complete :
I see that you have 0 groups and 0 component-instances.
RS generates only sectionplans of grouped elements or components (as explained in the first post)
The sectionplan can't be within de same context (= within the group or a component).OK Was that the solution
Thanks for taking your time to answer pgarmyn, I understand the need for those scenes and the workarounds you have to acomplish to get this working. As it is right now it is a very automatic process wich is excellent.
For simple presentations it's excellent, but for complex projects it probably creates some confusion with those extra scenes and layers. However there are viable alternatives for managing that too so you don't have to feel you should alter the scheme you have (wich you probably can't because of the limitations you described).
The problem is that the plugin has already so much potential, that I'll keep testing it and sometimes bothering you a bit. I hope you don't mind.
Best regards and thanks,
JQL
I feel like such dumbass.
Works very well.
Thank you so much, and sorry for bothering you without reading... -
About the Bug that isn't one : There was a blanc space in the beginning of your “ #Insulation” material. If you use the right name “#Insulation” and recalculate the scene, you will see your material.
Q :Would you consider adding a feature that would find loops in sections corresponding to groups inside other groups? : RS calculates group by group. Groups nor nested groups can interfere with each other. But I see other solutions to achieve the same visual effect. Thanks for this idea. I will work on it but it will take time. Actually I don't have much time. I started this plugin in march 2012.
Right now this feature and the fact that a lot of layers, materials and scenes are created that I don't need: I will work on it. But les layers, scenes … will give restrictions or strange behavior. I
still have the 231 previous versions of this RS plugin, but I can already imagine the posts if they were published.Try it out and show me the result ....
pgarmyn,
from SketchUcation Plugin Store : the file seems to be broken.
@micione :
I installed yesterday on SU8 and SU2013 from the pluginstore (sketchucation Tools), and didn't change anything since. What happend. Did you used the plugin installer? -
No. I just tried to open it as a file .Zip
But you have SU2013. Why not using the installer ? Do you need it for older SU versions ? The same files (as RBZ and ZIP) are also on the first post.
LOL. Actually I'm starting to get worried by those spaces I'm always having them in materials sometimes... It must be related to space being the key for select tool, that cancels other commands. In those complex projects I tend to waste a lot of time looking for materials just to find them on top of the list...
Sorry to have wasted your time on this...
Actually I'd prefer you didn't do it! It might seem strange but if you develop the plugin this way... I'll be forced to rethink and most probably change my modeling methodology completely, probably a lot of plugins I don't bother to think about will start making sense after all, Layout will never be the same again... You'll spread chaos in here, and you wouldn't want it because it seems you're actually trying to help!
Do you count versions late at night when you can't sleep?
Well it really feels like you put an great amount of effort in this as it has a lot of innovative and functional features.
Thanks for all your work.
Best regards,
JQL
@ladcwei said:
Yes,it's a temple ...... However,in some complex models,the plugin could give section lines but never fill the hole,I don't know is there some problem has not been solved? It seems to work right.
Hi ladcwei
Could it be that your complex model is in the same context as the sectionplan.
To produce a RichSection, the model must be in a group (or component) or composed by (groups or components). If the RichSection-sectionplan is within a group, there will be only RichSection-faces produced for the nested groups or components. Is that the problem ?If not, could you send me a model (private I necessary) ?
Placing a RichSection-sectionplan within a group or component is still experimental. You will have to update it manually if you move the sectionplan.
Once again : Magic model.
How did you made the helix ? -
Here is my model,wish you could solve all problems...
This model is made by Max,then it is transformed by 3DS format to SK,big software produce big models
quote="ladcwei"]Here is my model,wish you could solve all problems...
This model is made by Max,then it is transformed by 3DS format to SK,big software produce big models [/quote]
Hi ladcwei,
Big sofware, big problems... .... after conversion to SKP.
The problem is not the complexity. Even with a small part or the Max model, no intersection will be generated. It could be that adjacent faces dont share the same edge. Some faces have superposed edges.There are lot of coplanar faces subdivided without any reason. I tried to clean-up (plugins, by hand...).... no change,,,,
I’ve built in SU a model with the same complexity (not as beautiful as yours),
I used two excellent plugins : drawhelix14 from JIM and Extrusion-tools from TIG,
The section shown below (without projection) is generated in 3 seconds (For_ladcwei-02.png)
This image with projection, but les faces, was generated in 3,8 seconds, (For_ladcwei-03r.png)
PS : I only could read the first skp file the second is corrupted (tried to download 3 times...)
My SKP-file
QueJi Tower SKP SU2013
