[Plugin] FredoTools - v4.5a - 02 Apr 24
Very very strange.
I would expect that none works or all work.I'll have a closer look
Could you show me the content of the subfolder FREDOTOOLS_Dir_12 (files and dates)
very good contribution
NEW RELEASE: FredoTools v1.4a - 30 Oct 13
This update implements new naming conventions, fixes a few bugs for future compatibility.
See main post of this thread for download of FredoTools.
Some of my Fredo plugins need an update now. I've never done this before, so my question is how to update those plugins? Do I uninstall the older versions first and download the newer ones or just download the new version and the plugins are updated automatically in this way? Thanks for any help.
There is no 'uninstallation' of my plugins (as these are just files in folders). So You can safely install the new versions
I would suggest that you first install the SCF Plugin Store plugin, if not already done. This is the safest and easiest way to install plugins.
Install LibFredo6 first, then the other plugins
Once you have installed, you can go to Windows > LibFredo6 Settings... > Purge Obsolete files and delete the files and folders related to the previous versions
Thank you very much, I got it. Also thanks for all your great tools and plugins. I just start to learn and appreciate your tools since I'm beginner but nevertheless I can see the greatness.
Hello everybody!I'm trying to make a bent stair, so I created the stair's "profile" and intended to bend it using radial bending and then joint push pull in order to give it width.
in order to do that, I made the steps as simple as possible and turned slicing off (so that the shape would be bent only at the vertical edges.
unfortunatelly, bending screwed up the normals and when I tried to use the JPP faces were extruded weirdly.
Is there something I can do about it?
I know that a solution would be to extrude first and bend later, but because of reasons of repetition and workflow It would serve me better to do it this way -
When i install this plugin it tells me, you need the version 5.2 libfredo and so on, and i have that, or even a later one, so after ive installed it nothing happens? the same thing happened to fredoScale but for some reason that got installed, and im using it without a problem? any quick solution ?
Instead of using soften/smooth on the vertical almost-coplanar edges try making them just 'hidden' ??
NEW RELEASE: FredoTools v1.5a - 27 Nov 13
FredoTools 1.5a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
NEW RELEASE: FredoTools v1.6g - 24 Jan 14
FredoTools 1.6g is a release for EdgeInspector v1.0.
Fredo, thank you, again. You are generous, and talented.
Thanks Fredo for this new useful tool !!
I have updated the Spanish Language (Spain) to include EdgeInspector.
Spanish Language (Spain) v1.6g -
Oxer,
Thanks for that. This is a piece of work.
Will go into the next release, so very soon.Fredo
I now get this error:
FredoTools 1.6g: Error starting up plugin (creating menus and icons)
undefined method 'values' for nil:NilClass [in FredoTools.rb -
#'startup(): line 210]
...Lib6Core.rb:580in 'effective_load_part2'Then an error message with a Trace Log...
Am using LibFredo v5.5g. -
NEW RELEASE: FredoTools v1.7a - 15 Feb 14
FredoTools 1.7a is a release for EdgeInspector 1.1a, which introduces the detection and fixing of 2 new defects: lost junctions and needle-eyes.
See main post of this thread for Download of FredoTools.
Thank you for this great update!
dedmin, how do you grab into .wmv?
