Real world model entirely modelled in Sketchup
• Page 1 of 1
Real world model entirely modelled in SketchupHello Folks,
I would like to share a video I've made. It is done by using the stop-motion thechnique. All the different parts are modelled in Sketchup first. I have counted them: there are 1845 different parts in total. The model is about 1m25 in heighth and at the floor it is about 1m50 x 1m50. It is build to scale 1/200, so in reality the building would be about 240 meters tall. Here is a link to the video on Vimeo (for higher resolution): https://vimeo.com/38913543 This is my website:
Citypixels - 3d Visualisatie Architectuur Re: Real world model entirely modelled in SketchupAstounding work! I would like to see more "behind the scenes".
(The beginning reminded me of "Metropolis" and early stop motion animation --should've stuck with that dramatic opening music. ![]() MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
Re: Real world model entirely modelled in SketchupWOW! Impressive video. How long did you work on this? Did you lasercut the parts?
Re: Real world model entirely modelled in Sketchupexcellent work !
![]() nice use of the snowflake ![]() Re: Real world model entirely modelled in SketchupThanks!
![]() @ Pbacot: I'll add some more 'behind the scenes' materials. I think you have a good point: I could have stuck with the dramatic (North-Korean) opening music, but it was not so easy to find a piece of classical music that would fit because of the high tempo of the footage. My knowledge on different genres of music is not so great, so if anyone has a suggestion, it's always welcome! @ Cotty: I worked on the project (from the first sketches to the final result) for about a year (mostly in the weekends). Yes, it is lasercut. @ Orgelf: Thanks! Here is a video where you see how I cut angled corners onto the different pieces. (Do not try this at home actualy. ![]() About 1845 parts in total. Sketchup construction drawings: First sketches This is my website:
Citypixels - 3d Visualisatie Architectuur Re: Real world model entirely modelled in SketchupCrazy cool! I think it deserves a place in the Sketchup Showcase: http://showcase.sketchup.com/ Have you thought about submitting it there?
http://goo.gl/f7ooYh
Re: Real world model entirely modelled in Sketchup...yes and "most impressive sketchup modelling" thread!
@d12dozr: Thanks for the tip! Maybe I'll just do that! This is my website:
Citypixels - 3d Visualisatie Architectuur Re: Real world model entirely modelled in SketchupConstructivism revival!
Re: Real world model entirely modelled in SketchupHere is another project where I have used Sketchup to make the illustration and the construction. You can find more photos here: http://pietervermeersch.blogspot.be/201 ... ct-m2.html
This is my website:
Quite job... I was thinking that this must be done with laser cutting ![]() Welcome to try Thea Render, Thea support | kerkythea.net -team member
Re: Real world model entirely modelled in SketchupHey Notareal,
All the peices are done with lasercutting, but I have done the angled corners with the saw. ![]() This is my website:
Citypixels - 3d Visualisatie Architectuur Re: Real world model entirely modelled in SketchupThat is very nice work.
Did you use layout to arrange the pieces for the laser cutter? Toby
Philippians 4:13 I can do everything through him who gives me strength. Re: Real world model entirely modelled in SketchupHey Tobobo,
Thanks, I have used illustrator to arrange the pieces. This is my website:
When I did my MA, I used Illustrator to do the same thing but then had to eps it. As the driver only worked through Corel Draw. Toby
Philippians 4:13 I can do everything through him who gives me strength. Re: Real world model entirely modelled in SketchupThat is AWESOME Pieterv...
Re: Real world model entirely modelled in SketchupGreat patience and excellent result! I admire your passion for the design & construction.
Re: Real world model entirely modelled in Sketchup@ Boofredlay:
@ cadmunkey: @ Tomasz: Thanks a lot! ![]() This is my website:
• Page 1 of 1
