[Plugin] FredoTools - v3.8a - 18 Nov 19
Re: [Plugin] FredoTools 1.2a - 08 May 12
Postby fredo6 » Fri May 17, 2013 10:33 pm
pbacot wrote::oops: I didn't realize it was under the FredoTools submenu... it used to be different right? Or am I imagining?
Thanks for the help. Now I have this oft-used function again!
Well! It is like this because the real estate of the contextual menu is precious.
But of course, it is less efficient.
User avatar
PluginStore Author
PluginStore Author
Postby AsiaStarArt » Wed May 22, 2013 7:44 am
:enlight:
谢谢你
Thank
AsiaStarArt
Postby asaavedra » Thu Jun 06, 2013 11:44 pm
Hello, I love Freddo plug ins, but I installed SketchUp 13 and these plug ins do not work ... you plan to make it compatible soon??
asaavedra
Postby Alan Fraser » Fri Jun 07, 2013 7:26 am
asaavedra wrote:Hello, I love Freddo plug ins, but I installed SketchUp 13 and these plug ins do not work ... you plan to make it compatible soon??
They do work. Update your Fredo6 Library file.
FormFonts
User avatar
Alan Fraser
Top SketchUcator
Postby ruggero56 » Tue Jun 25, 2013 11:34 pm
Devo studiare tutto in inglese, Fredo!! Ma la installazione è stata perfetta! Complimenti e grazie! :)
ruggero56
Postby davi » Sun Jul 14, 2013 2:16 pm
thank you very much!
davi
Postby jumboojum » Sun Aug 18, 2013 5:29 pm
Thank you so much sir :ecstatic:
jumboojum
Postby tolson68 » Sat Aug 24, 2013 11:21 pm
Fredo,
I have installed Sketchup 2013 Make on a Linux instance and it seems to be working well. Unfortunately I have a problem loading FredoTools 1.2a. The error message I receive is:
Error Loading File C:/Program Files/SketchUp/SketchUp 2013/Plugins/FREDOTOOLS_Dir_12/__loader.rb
can't convert nil into String
I have tried disabling my other plugins to isolate the cause and then adding them back one at a time and when FredoTools is enabled I start having this problem. I'm happy to assist you in any tracing, since I'm aware that SketchUp itself is not supported on Linux. This is a brand new install and all plugins packages have been downloaded within the past 24 hours.
I am also encountering the same problem in Sketchup 8 on the same machine.
Kind Regards,
Tom
tolson68
Postby TIG » Sun Aug 25, 2013 9:48 am
@Tom
Ensure that the SketchUp Plugins folder AND all of its contents [subfolders/files] have FULL Read/Write security permissions set.
On Windows existing contents typically adopt the settings of their parent.
Properties > Security > Edit... each user/group in the list > FULL... Apply/OK
On a MAC you need to deliberately tell the OS to apply the changes to contents.
On Linux it may be the same...
Also set Sketchup.exe to 'always run as administrator' [if you can] ...
Do you have that .rb file in the named subfolder
C:/Program Files/SketchUp/SketchUp 2013/Plugins/FREDOTOOLS_Dir_12/__loader.rbIf not, then it suggests you had limited permissions and the have not installed the files as you think you have...
User avatar
Global Moderator
Postby fredo6 » Sun Aug 25, 2013 9:45 pm
tolson68 wrote:Fredo,
Tom,
Strange message. Not sure it is related to your Linux installation.
Could you check that the file __loader.rb contains a single line:
Traductor::Plugin.myplugin('FredoTools').effective_load
User avatar
PluginStore Author
PluginStore Author
Postby tolson68 » Mon Aug 26, 2013 10:40 am
TIG, The __loader.rb does exist in the .../FREDOTOOLS_Dir_12/ folder and has it's permissions set to -rw-r--r-- and all other *.rb files have the same permissions.
Fredo, The __loader.rb file does contain the line:
...and nothing else.
If I rename the 000_AdditionalPluginFolders.rb file the error appears to go away, which seems like an acceptable workaround. I am unable to use WebDialog for that add-on for somereason. All other WebDialogs are working, but that one just displays raw HTML, but does not generate any exceptions other than when FredoTools is loaded, curious.
Thanks,
Tom
tolson68
Postby tolson68 » Mon Aug 26, 2013 10:49 am
Fredo,
I stand corrected renaming the 000_AdditionalPluginsFolder.rb did not resolve the problem, but it did expose a different/extended message:
Error Loading File ZLoader__GhostComp.rb
tolson68
Postby songkran77 » Thu Sep 26, 2013 6:14 am
:thumb: :thumb: thank you very much
songkran77
ThruPaint + MaxwellFire = BugSpalt
Postby dedmin » Sun Sep 29, 2013 7:14 am
dedmin
Re: ThruPaint + MaxwellFire = BugSpalt
Postby fredo6 » Sun Sep 29, 2013 9:07 am
dedmin wrote:http://screencast.com/t/lSl60f8IB
Very strange.
Can come from 2 possible causes:
1) MaxwellFire modifies the SU model and the texturing (does it?), and then ThruPaint or MaxWellFire script crashes when it is used (could be related to observers)
2) or there is a more traditional plugin conflict
Could you send me a model where you do the rendering, but just before you try to apply the TrhruPaint texturing.
User avatar
PluginStore Author
PluginStore Author
Postby dedmin » Sun Sep 29, 2013 11:46 am
There is no model - just a simple rectangle, then push-pull to a 3D box.
dedmin
Postby fredo6 » Sun Sep 29, 2013 1:53 pm
dedmin wrote:There is no model - just a simple rectangle, then push-pull to a 3D box.
That was just in case MaxwellFire modifies the texture. So just the model after you do the rendering.
Otherwise, this may simply come from a plugin conflict, either at code level, or due to handling of observers in MaxwellFire.
User avatar
PluginStore Author
PluginStore Author
Postby dedmin » Sun Sep 29, 2013 2:10 pm
The material was just default sketchup material. This file was rendered with Maxwell:
Buro_11.skp
dedmin
Postby fredo6 » Sun Sep 29, 2013 2:29 pm
dedmin wrote:The material was just default sketchup material. This file was rendered with Maxwell:
Buro_11.skp
I get NO crash when using ThurPaint.
So it must be another conflict between scripts (There was one for Vray Beta 1.6).
Maybe some other users have found a similar problem.
fredo
User avatar
PluginStore Author
PluginStore Author
Postby Bimbalas » Sun Oct 13, 2013 4:35 pm
Kind Regards,
Tom
Hi, Tom,
I have the same problem on my nature windows machine and on linux/ubuntu machine through wine. The workaround is very simple. I moved all Fredo6 plugins to default sketchup plugins folder and now all they works as expected. Probably problem occurs on AdditionalPluginFolders.rb level.
Bimbalas
Postby txusic » Sat Oct 26, 2013 4:19 am
Hi fredo.. I´ms sure you and all around are bored of answering the same questions.. but i read thoroughly and couldn't find an answer....
I work on an old PowerPc G5 (pre-Intel) and SketchUp 7 (7.1.6859)
i copy the plugins in the right place
mac hd >library > application support > google sketchup 7 > sketchip > plugins
tryed to change names, place them in original folders, change the web browser (downloader as safari was giving funny names), change the un-compressor.. every thing to no luck
Here is an image where u see shaded all the info
thanx for any help in advance...
PD congratulations other plugins i tryed, are fantastic!!
txusic
Postby chon » Mon Oct 28, 2013 9:38 am
Fredo,
I've got an issue using FredoTools with AdditionalPluginFolders.
The problem is related here with shortcuts for illustration.
Many thanks to look at that ! :thumb:
User avatar
chon
Postby fredo6 » Mon Oct 28, 2013 2:25 pm
chon wrote:Fredo,
It seems the issue is in LibFredo6 actually (error in the logging of errors!!). I don't know why you have FredoTools in error. Possibly you may open the Windows > LibFredo6 Settings > View Trace Files... dialog box and check if there is more info (in red).
Anyway, I would suggest the following
- Upgrade to AdditionalPluginFolders 4.2a
- Upgrade to LibFredo6 5.3g (just published).
Then, if you still get the error, could try to drop and replace the attached file Fredo6_!LibFredo6.rb in the directory where you installed my scripts.
User avatar
PluginStore Author
PluginStore Author
Postby chon » Mon Oct 28, 2013 4:24 pm
Thanks for help Fredo ! :thumb:
Here is the "View trace files" :
As you can see, my Fredo6 tools are up to date... ;)
Another question : Fredo6 has created a default parameters folder on the first level of C:/ (visible on the 4th line of the "View trace files").
Is it possible to locate this folder at another place ?
User avatar
chon
Postby chon » Wed Oct 30, 2013 9:11 am
Fredo,
update of Libfredo6 solved part of the problem but not all :
Here is the message error :
Here is the trace log (only error items) :
Code: Select all
>>>> 1383119187.795;Lib6Core.rb:649:  in `load_full_rubies'
?FredoTools 1.2a: ERROR in Loading ruby file FredoTools__ThruPaint.rb
undefined method `register_plug' for FredoTools:Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__ThruPaint.rb:34
>>>> 1383119187.824;Lib6Core.rb:649:  in `load_full_rubies'
?FredoTools 1.2a: ERROR in Loading ruby file FredoTools__RemoveLonelyVertices.rb
undefined method `register_plug' for FredoTools:Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__RemoveLonelyVertices.rb:36
>>>> 1383119187.853;Lib6Core.rb:649:  in `load_full_rubies'
?FredoTools 1.2a: ERROR in Loading ruby file FredoTools__MarkVertices.rb
undefined method `register_plug' for FredoTools:Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__MarkVertices.rb:36
>>>> 1383119187.877;Lib6Core.rb:649:  in `load_full_rubies'
?FredoTools 1.2a: ERROR in Loading ruby file FredoTools__CountFacesBySides.rb
undefined method `register_plug' for FredoTools:Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__CountFacesBySides.rb:34
>>>> 1383119187.892;Lib6Core.rb:649:  in `load_full_rubies'
?FredoTools 1.2a: ERROR in Loading ruby file FredoTools__ReverseOrientFaces.rb
undefined method `register_plug' for FredoTools:Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__ReverseOrientFaces.rb:34
>>>> 1383119187.942;Lib6Core.rb:649:  in `load_full_rubies'
?FredoTools 1.2a: ERROR in Loading ruby file FredoTools__ReportLabelArea.rb
undefined method `register_plug' for FredoTools:Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__ReportLabelArea.rb:34
ConstructFaceNormal, CurviShear and RevertCurve seem to work fine ! :thumb:
User avatar
chon
Postby fredo6 » Wed Oct 30, 2013 10:01 am
Very very strange.
I would expect that none works or all work.
I'll have a closer look
Could you show me the content of the subfolder FREDOTOOLS_Dir_12 (files and dates)
User avatar
PluginStore Author
PluginStore Author
Postby chon » Wed Oct 30, 2013 10:34 am
fredo6 wrote:Could you show me the content of the subfolder FREDOTOOLS_Dir_12 (files and dates)
User avatar
chon
Postby LAGRARI2012 » Wed Oct 30, 2013 3:33 pm
very good contribution :thumb: :thumb: :thumb:
User avatar
LAGRARI2012
Re: [Plugin] FredoTools 1.4a - 30 Oct 13
Postby fredo6 » Wed Oct 30, 2013 11:13 pm
NEW RELEASE: FredoTools v1.4a - 30 Oct 13
This update implements new naming conventions, fixes a few bugs for future compatibility.
See main post of this thread for download of FredoTools.
User avatar
PluginStore Author
PluginStore Author
Postby parsleybrain » Fri Nov 01, 2013 6:19 am
Some of my Fredo plugins need an update now. I've never done this before, so my question is how to update those plugins? Do I uninstall the older versions first and download the newer ones or just download the new version and the plugins are updated automatically in this way? Thanks for any help.
parsleybrain
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: Bing [Bot], dfgfxxbhgf, Javcgx, leece713, summerson1990 and 7 guests
Visit our sponsors:
