[Plugin] QuadFaceTools
Re: [Plugin] QuadFaceTools (0.7.0b) — 08 February 2012
Postby thomthom » Wed Feb 20, 2013 3:40 pm
Do you happen to have Organizer installed?
User avatar
PluginStore Author
PluginStore Author
Postby daforum » Wed Feb 20, 2013 5:03 pm
Hi thomthom,
I've done a search and nothing found, called Organizer on my machine.
User avatar
daforum
Postby driven » Thu Feb 21, 2013 1:15 am
hi daforum,
can you run this in Ruby Console and paste the results back into a 'code' box for easy checking of possible conflicts...
Code: Select all
$LOADED_FEATURES.join("\n")
if it dosen't have all your plugins try this one as well...
Code: Select all
$loaded_files.join("\n")
lastly, can your fill in your profile so we know your on mac, etc...
and since it doesn't tell us, which 'osx' version, a cat will do...
cheers
driven
PluginStore Author
PluginStore Author
Postby daforum » Thu Feb 21, 2013 11:40 am
Hi driven,
I will do the code pasting as soon as I can today; and I have updated my profile as suggested
but it doesn't seem to be showing up :(
Edit
ah, now it's there :)
User avatar
daforum
Postby thomthom » Thu Feb 21, 2013 11:48 am
daforum wrote:ah, now it's there :)
It's working? No errors?
User avatar
PluginStore Author
PluginStore Author
Postby driven » Thu Feb 21, 2013 12:15 pm
out of curiosity...
do you use a 'Finder' enhancer/manager of any sort?
I have found 'sometimes' I need to update 'Finder' before newly added files can be accessed.
Turning your mac off overnight would have refreshed 'Finder'...
driven
PluginStore Author
PluginStore Author
Postby daforum » Thu Feb 21, 2013 4:47 pm
Oops, sorry for the confusion. I meant about my Profile details on the left.
When I filled in my Profile details they didn't appear, then when I went back to this thread my details had updated and appeared.
Will have a go at the Code pasting as suggested earlier.
User avatar
daforum
Postby daforum » Thu Feb 21, 2013 4:53 pm
This is what I got when i pasted: $LOADED_FEATURES.join("\n")
Code: Select all
langhandler.rb
sketchup.rb
3d_grid.rb
[CASF]FunShapes.rb
arcs.rb
balustrade.rb
bezier.rb
box_pos.rb
boxes_random.rb
cleanuplines.rb
cloud_v6.rb
ContourMaker.rb
cratetool.rb
creat360view.rb
cylinder.rb
dashes.rb
dat_importer1.rb
edge-coplanar.rb
deleteCoplanar.rb
delfaces.rb
DoorMaker.rb
doortools/doortoolright.rb
doortools/doortoolleft.rb
doortools/3PointTool.rb
doortools/doortoolframe.rb
doortools/doortooltrim.rb
doortools/doortoolmullion.rb
doortools/doortoollouver.rb
doortools/doortoolglass.rb
DoorTools.rb
drawhelix13.rb
drop.rb
Sketchup.rb
Engraver.rb
extensions.rb
LangHandler.rb
examples/box.rb
examples/selection.rb
examples/contextmenu.rb
examples/linetool.rb
examples/animation.rb
examples/attributes.rb
examples/exampleScripts.rb
examples.rb
extend11.rb
extrud_selected_faces_along_normal.rb
extrude_lines.rb
ExtrudeAlongPath.rb
extrudelinetool.rb
FilletTool.rb
flattery/utils.rb
flattery/unfoldtool.rb
flattery/edgepairs.rb
flattery/reunitetool.rb
flattery/tabtool.rb
flattery/svgexport.rb
flattery/toolbar.rb
flattery.rb
flightpath.rb
fur_en.rb
Geodesic_SketchUp.rb
Grow.rb
heightfield_generator.rb
./offset.rb
holes.rb
housetool01.rb
import_from_folder.rb
jf_sine_wave.rb
joisttool.rb
kitchen.rb
label_stray_lines.rb
lathe.rb
Latticeizer.rb
linetool.rb
lsystem.rb
lwo_export/export.rb
lwo_export.rb
progressbar.rb
makefaces.rb
mesh_additions.rb
Mirror.rb
model_location.rb
normal_map_maker.rb
obj_importer.rb
OBJexporter.rb
offset.rb
orient_faces.rb
parametric.rb
parking.rb
Pipe Tool v4.3.rb
PipeAlongPath.rb
protrude.rb
pyramidtool.rb
QuadsFrom2Tris.rb
raftertool.rb
random_lines.rb
rectangle_hole.rb
rot90.rb
sceneExporter.rb
shapes.rb
SimplifyContours.rb
SketchyBevel.rb
skp_to_dxf.rb
slabtool.rb
stair_maker062.rb
SteelSections.rb
Stepping Stones.rb
thicklines.rb
tnt_bookshelf.rb
tnt_StairConcTool.rb
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/arc.rb
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/attributes.rb
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/babelfish.rb
TT_Lib2/geom3d.rb
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/bezier.rb
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/binary.rb
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/bounds.rb
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/color.rb
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/cursor.rb
unfoldtool.rb
Utilities/utilitiesTools.rb
utilities.rb
voxelizebeta04.rb
vrobj_exporter.rb
WindowGlass.rb
windowizer.rb
windows.rb
xLine2Line.rb
/Library/Application Support/Google SketchUp 7/SketchUp/Tools/sketchup.rb
DynamicComponents/ruby/dcloader.rb
dynamiccomponents.rb
make_pano_pm.rb
sandboxtools.rb
User avatar
daforum
Postby daforum » Thu Feb 21, 2013 4:56 pm
This is what I got when I pasted: $loaded_files.join("\n")
Code: Select all
sketchup.rb
rp_spherical_helix
User avatar
daforum
Postby driven » Thu Feb 21, 2013 6:49 pm
disable Geodesic_SketchUp.rb by renaming itGeodesic_SketchUp.rb! and see if this works then. if so there is a safer version about...
driven
PluginStore Author
PluginStore Author
Postby daforum » Thu Feb 21, 2013 7:21 pm
Hi John,
I renamed the Geodesic_Sketchup plugin and got this when Sketchup started:
Code: Select all
can't convert nil into StringError Loading File tt_quadface.rb
I've installed QuadFaceTools - (0.7.0) Do I need an earlier version?
User avatar
daforum
Postby driven » Thu Feb 21, 2013 8:57 pm
I just installed it using rbz file and you seem to be missing the entire TT_QuadFaceTools Folder?
driven
PluginStore Author
PluginStore Author
Postby thomthom » Fri Feb 22, 2013 1:10 am
Could it be some permission problem?
User avatar
PluginStore Author
PluginStore Author
Postby daforum » Fri Feb 22, 2013 11:45 am
driven wrote:Hi
TT_QuadfaceTools folder is installed!
Please see attached png
User avatar
daforum
Postby daforum » Sun Feb 24, 2013 6:18 pm
Oh well, if it's not working it's not working!
Thanks for your help guys with all suggestions. Time to move on :)
User avatar
daforum
Postby thomthom » Sun Feb 24, 2013 8:41 pm
You never replied to my questions to whether you'd checked the folder permissions...
User avatar
PluginStore Author
PluginStore Author
Postby daforum » Mon Feb 25, 2013 1:48 pm
Hi thomthom,
I originally downloaded the .rbz file and renamed it to a .zip file and unzipped it.
It unzipped fine and the folder and .rb file I installed into my plugins folder without any problems.
I'm the administrator on my computer so there are no problems with permissions.
User avatar
daforum
Postby thomthom » Mon Feb 25, 2013 2:02 pm
hmm..
I see you are using SketchUp 7 Free from your profile, why not SketchUp 8?
You could then use the RBZ installing feature - and there's lots of API fixes as well.
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Mon Feb 25, 2013 2:26 pm
By the way - have you checked in the Extension list to make sure it's enabled?
User avatar
PluginStore Author
PluginStore Author
Postby daforum » Mon Feb 25, 2013 2:40 pm
Yes, I had a look and it is ticked.
Should i download the version you have v0.8.0, and do you recommend i update to TT_Lib2_v2.71 ?
User avatar
daforum
Postby thomthom » Mon Feb 25, 2013 2:45 pm
You can't download 0.8.0 - it's not released. It's what I am working on right now.
You could try to update TT_Lib2 - but I'm not sure if it'll work. (to be honest, I don't understand why it fails to show at all.) Oh, you do know that the menus are under Tools - not Plugins?
But for the sake of it, can you install SU8 and use the Install Extension feature? Just to see if that works?
User avatar
PluginStore Author
PluginStore Author
Postby daforum » Mon Feb 25, 2013 2:50 pm
I can see the TT lib2 folder (i greyed it so to highlight it in my Plugins folder)
I have looked in the Tools section and it's not there.
The problem i have is that I'm still on Mac OSX 10.4.11 and SU8 runs on 10.5+
That's the reason I'm using SU7.
User avatar
daforum
Postby Mra » Fri Jun 14, 2013 6:06 am
Hi, is the toolbar supported in 2013?
I installed via the extension but it's not showing up even though its ticked?
Mra
Postby jo-ke » Fri Jun 14, 2013 7:37 am
mra wrote:Hi, is the toolbar supported in 2013?
I've got the same problem with my notebook. At the desktop PC the toolbar is shown.
both win7
User avatar
jo-ke
Premium Member
Premium Member
Postby thomthom » Fri Jun 14, 2013 9:00 am
That's a bug in the first release of SketchUp 2013. There is a new versiono out that fixes this. Go to sketchup.com and download SketchUp again.
User avatar
PluginStore Author
PluginStore Author
Postby jo-ke » Fri Jun 14, 2013 3:07 pm
Can I overwrite the old version or should I reinstall everything new?
User avatar
jo-ke
Premium Member
Premium Member
Postby thomthom » Fri Jun 14, 2013 3:18 pm
Just install over the old one.
User avatar
PluginStore Author
PluginStore Author
Postby Mra » Wed Jun 19, 2013 12:16 am
Confirmed. THanks thomthom.
And thanks Trimble for letting us all knwo about the patched 2013! :roll:
Mra
Postby jo-ke » Wed Jun 19, 2013 5:07 am
Yes that solved the problem
Thank you
User avatar
jo-ke
Premium Member
Premium Member
Postby ziiar » Tue Jul 23, 2013 10:51 pm
Is there any way to over-scale? I would like the stone texture to match (or at least get close to) the scale of the cube.
I'm still trying to texture stone aches like what you did for your UV Toolkit thread. Is it possible/easier to do with that plugin? I couldn't figure out how to do it.
User avatar
ziiar
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: lexmaglunob, swatikarhade1234, tien02683 and 12 guests
Visit our sponsors:
