[Plugin] Make Fur v.2.1.0(20140323)
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)
Postby massimo » Mon Apr 08, 2013 7:14 am
Go to the very first post of the thread and scroll down a bit the page. Is there.
User avatar
massimo
Postby ATBP » Mon Apr 08, 2013 4:36 pm
Very nice. :sketchstatic:
ATBP
Postby Latetzki » Sun May 05, 2013 1:38 pm
What can I do to make this more precise so it wont place anything outside the selected face??
Latetzki
Postby DavorP » Sun May 05, 2013 3:23 pm
Plugin is great but I have a problem. I use previously modeled component as fur instance. What happens is that each component that fur drops is inverted. How can I make sure this does not happen?
DavorP
Postby DavorP » Sun May 05, 2013 7:01 pm
Latetzki wrote:What can I do to make this more precise so it wont place anything outside the selected face??
You could use offset tool to make the area smaller. If the component is proprely centered on origin then measure the horizontal distance from origin to the farthest point of component geometry. Use that value to offset the boundary. If you have surface use offset on surface tool.
DavorP
Postby tak2hata » Mon May 06, 2013 6:27 am
Hi,Davor.
I guess that problem....
Fur brade may up to Z aixis in the component.
so I think your component is filpped for Z axis.
or Your selected face for making fur is flipped.
The Selected Face must directed to upward for you want.
or The value of Force(Z) is too strong.
Is your case there?
Hi,Latetzki.
I think like as Davor's,too.
Fur is created on the points of selected face.
But,The blade of fur has width.
offset the face if you want more precise inside.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin] Make Fur (Updated - v.2.0.1 Jun 02, 2013)
Postby tak2hata » Sun Jun 02, 2013 5:27 am
Hi,All.
I update to version2.0.1 in 2013.06.02.
UI is improved.
Hi,zieios.
The icon is pretty cool! :ecstatic:
Fur will be grown thick on sketchup!
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby Anton_S » Sun Jun 02, 2013 6:51 am
Amazing plugin!!!
I just got a hair cut, and didn't know how to fullfill my hair.
But, now I found a way
Thank you :fro:
Anton_S
PluginStore Author
PluginStore Author
Postby pepa » Sun Jun 02, 2013 12:56 pm
Thanks for update, there is a czech translation.
pepa
Re: [Plugin] Make Fur (Updated - v.2.0.3 Jun 02, 2013)
Postby tak2hata » Sun Jun 02, 2013 1:14 pm
Hi,All.
Now I place the new language files in language folder.
fur_lang_farsi.txt:Persian translation by Majid.Thanks!
fur_lang_cz.txt:Czech translation by Pepa.Thanks!
Hi,Anton!
Nice hair!
I wish if I had hair like him.
It will need too much hair spray.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin] Make Fur (Updated - v.2.0.4 Jun 02, 2013)
Postby majid » Mon Jun 03, 2013 4:23 am
Thank you for update and new interface :ecstatic: :thumb:
My perspective shortcuts book: https://bit.ly/30Tdbce
User avatar
majid
Top SketchUcator
Postby macmac12 » Mon Jun 03, 2013 1:34 pm
thanks for the update :)
macmac12
Postby Oxer » Mon Jun 03, 2013 1:36 pm
Thanks for the update, I have done a new translation for Spanish Language, I add new strings to the file.
Spanish Language v2.0.4
fur_lang_esv2.0.4.txt
User avatar
Oxer
Postby hebeijianke » Mon Jun 03, 2013 3:53 pm
Chinese translation new
hebeijianke
Postby olishea » Mon Jun 03, 2013 4:08 pm
thanks for the update. great plugin :thumb:
oli
User avatar
olishea
Premium Member
Premium Member
Postby erikB » Mon Jun 03, 2013 4:20 pm
thanks for the update, great plugin I use it regularly.
erikB
User avatar
erikB
Postby tak2hata » Thu Jun 06, 2013 4:43 am
Thanks Hebeijianke and Oxer for uploading the translation files.
Now I'm busy ,so I will update plugin including these translation files in the end of this week.
Thank you very much!
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin] Make Fur (Updated - v.2.0.5 Jun 08, 2013)
Postby tak2hata » Sat Jun 08, 2013 3:38 am
Hi,All.
I update to v2.0.5.
Include new language file for Spanish and Chinese.
Thanks Oxer and Hebeijianke!
Enjoy!
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby meoa » Sat Jun 08, 2013 7:13 pm
Preview shows fur on the selected face but after clicking make fur, quite a number of it go off the selected face. The ones on the face are also scattered unevenly unlike the preview.
Is this what should happen or am i doing something wrong ?
Ok, sketchup just crashed. I tried it again and it seems to be fine now. Fur stays on the faces. I stil don't know what happened before and the cause.
meoa
Postby tak2hata » Sun Jun 09, 2013 2:14 pm
Hi,meoa.
I need more information for your problem.
I can not know what happened, too.
Please upload your model and the picture of the fur setting and selected face.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby meoa » Tue Jun 11, 2013 9:20 am
tak2hata wrote:Hi,meoa.
Thanks.
Sorry tak2hata, it was my mistake.
I deleted geometry in a component and for some reason it did not rescale or i may have moved the axes by mistake so the component size was far larger than the content(space when you edit the component). Thus, the make fur moved the components further away than the size of the content which explains why they were off the face.
meoa
Postby tak2hata » Tue Jun 11, 2013 3:46 pm
Thanks.
Hi,meoa.
This problem is solved by yourself.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby menes » Tue Jun 11, 2013 5:05 pm
Hello there,
First thanks tak2hata for the wonderful plugin.
I'm trying long time now to use this for create a nice Olive tree.
While the plugin work perfectly for create the single element.
I can not in any way create the proper effect randomizing the element using the "leaf" mode.
any suggestion?
thanks
menes
Postby srx » Tue Jun 11, 2013 6:03 pm
Wonderful plugin. Here is Serbian translation. Just to feel the excitement of taking part in an international project :D .
www.saurus.rs
User avatar
srx
Re: [Plugin] Make Fur (Updated - v.2.0.6 Jun 12, 2013)
Postby tak2hata » Wed Jun 12, 2013 2:09 pm
I upload to v2.0.6.
Include the language file for Serbian by SRX.Thanks!
Hi,menes.
I try it!
Component for leaves lay along to X-Axis(RED) with litte slope.
And place it with large Z value of "direction" and "force" in fur dialog.
It make like this placement.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby nektares » Wed Jun 12, 2013 3:57 pm
i loved this plugin already, and now it´s even better! Arigato Gozaimasu Tak2Hata
nektares
Postby menes » Wed Jun 12, 2013 4:28 pm
:sketchstatic:
Thank you very much indeed! TAK2HATA
Will try and let you know
menes
Postby menes » Wed Jun 12, 2013 6:32 pm
Thanks TAK2HATA
You put me in the right way :ecstatic: thank you!
My values were different
Main Detail
type : leaf top jitter :8
Density: 60.000 width jitter: 19
Max n. :60.000 stiffness jitter : 50
length :1 valid distance: 0,000
rootwidth : 0,200 direction (x): 0,000
stiffness : 1 direction (y): 0,000
divide :2 direction (z): 1
force (x):0
force (y):0,000
force (z):-30
now the only thing to try ,it's to avoid many leaves at the bottom of the branches and have more on the top.
menes
Postby thkian92 » Mon Jun 24, 2013 4:37 pm
Thanks for the plugin! But I have a problem. It seems that I can't get v2.0.6 to work on the new Sketchup 2013. Am i doing something wrong? As usual I've placed the plugin in C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins.
User avatar
thkian92
Postby mwm5053 » Mon Jun 24, 2013 8:23 pm
Great plugin :thumb: I updated to 2.0.6 but not getting sliders or realtime preview like video shows I get the older dialog style. I'm using latest SU8 Pro on Mac 10.7.5
2011 iMac
SU 2015 Pro, 2017 Make
V2 Twilight
macOS Sierra 10.12.5
mwm5053
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: boccn, Goryk7, jenner, jogr0381, laurennichols, samodelkin_77, Shiftfocus, XxSH3rAwExX and 28 guests
Visit our sponsors:
