[Plugin] MoleculeImporter (1.3.3) – updated 8.10.2017
but I cant see that it is workning
Hi, can you tell me what is "not" working? Do you not see a menu item in the Plugins menu (and in File → Import), or do you see it, but when you import a specific file, it seems not to create a model?
The plugin supports SketchUp 8.0 (which is 2 years old, and didn't add/remove anything that easily breaks plugins). It could be that the plugin cannot yet handle every file of the .mol format, in that case, maybe you can send me the file (or a similar file). -
I am always amazed by the breadth of interests in this forum and uses of SU. I have a biology degree but I hadn't thought of such a scientific tie-in for SU or that people on this forum would be knowledgeable about these things. Well I guess I should not be amazed but just get used to it.
Thanks for the importer!
The plugin supports SketchUp 8.0 (which is 2 years old, and didn't add/remove anything that easily breaks plugins). It could be that the plugin cannot yet handle every file of the .mol format, in that case, maybe you can send me the file (or a similar file).Hi and thanks for your replay. I can not see the plugin in the menu (file - import) and when I open the possible types of import I can not see *.mol.
Then I assume the plugin is not loaded. Since you didn't mention a popup with "load errors" at the start of SketchUp, we should maybe check that it is installed correctly:
On the OS X operating system that is in: (the system path, not user path)
%(#000000)[MacIntosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins/]
If Windows is installed on your computer, it is in: (depending on language and drive letter)
%(#000000)[C:\Program Files\Google\Google SketchUp 8\Plugins\]
Small update (1.1.0):
- converted it into a SketchUp Extension (that you can turn on/off)
- added icon and translations
Thanks!!
I have created the spanish language file:
Spanish Language -
A new version 1.1.1 has been uploaded. Some regular expressions failed on OS X and have been fixed.
@danyhkim said:
Is there any possibility of a protein structural renderer that would calculate sheets and helices, kind of like RasMol does?
Aerilius, I am probably asking the same thing as DanYHKim, but is it possible to model the pink and yellow things in the attached graphic? I downloaded the .pdb file from rcsb.org, and then exported the file to MOL v3000. That worked fine to model the molecular structure... which I am guessing is by design, but I am trying to find a way to simply model the other stuff.
The surface representation is probably much more complicated. SketchUp has only faces and edges as primitives and is thus not really appropriate for chemical/biological visualizations (that are more focussed on atom positions, angles and electon density). This plugin just places components of spheres (which is easy) but I have no idea how the surface representation is stored in pdb and how to generate smooth SketchUp geometry from it.
It is probably easier to let a molecule/protein modeler do the surface generation and then export it to faces/edges to do SketchUp stuff with it. I've seen for example pymol can export to vrml (SketchUp Pro) and obj (free SketchUp importer plugin).
http://www.pymolwiki.org/index.php/Surface -
Hi again, I have been away. but now I realy need this going. I have know been able to set the plugin up corectly. I´m using ACD/chemsketch to build models and I export them as *.mol. But when I try to import them I can select the file and when i click ok nothing happens. just a blank screen.
Could I send you the file for try?? but I´m not allowed to put in *.mol file hear.I realy need to solve this
You can send the file if you put it in a zip file.
Hi Aerilius,
Like Andri (perhaps) I cannot get the plugin to import an mol file-- nothing happens in the Sketchup window. This is for Sketchup 2013. Any solution since that last post?
Thanks John E.
I am seeing the same thing right now on SketchUp 2013 and 2014. I've tried to import several different MOL files.
Is there possibly a bug here?
I am trying to 3D print some molecules and would love to be able to use this...
The importer has been closely designed around the Symyx specification (2010) for Molfile V2000 and V3000 formats. It maybe possible that there is a bug, but I don't have any file that failed so far (would be good if someone who wants this solved can send me such a file). It may also be possible that the file deviates slightly from the specification, or that it is a different version or file format with .mol ending.
From what software / source are these .mol files?
I tried a bunch from ACD/ChemSketch and they all failed no matter what format I saved them in...
I had some unpublished changes pending, can you check the 1.2.0 release? If it shows the issue, please send me a .mol file.
It looks like I'm on the 1.1 release, I got it from the Extension Warehouse. Should I wait for an update there, or just load the one that you have for download here?
I would prefer to update when I know the new version 1.2.0 in the SCF store is good (EW usually takes a week for review, so I couldn't push another revision).
Ok, I just installed the one in the SketchuCation plugin store and it works on my files perfectly so there's something up with the one in the Extension Warehouse.
Dear Aerilius,
thank you very much for great plugin. However I found difficulties, opening larger structures above 100 atoms. Can number of atoms indeed be the problem? Is there a way to solve it?Thanks a lot!
Ivan
