[Plugin] Scale Group Definition
Postby thomthom » Fri Feb 22, 2013 4:29 pm
Overview
Adds a Scale Definition menu item for groups to match the native function for components.
Access
Group > Context Menu > Scale Definition
Requirements
Guide: How to install RBZ Files
Download
Guide to installing SketchUp Plugins
Footprint
<Sketchup>/Plugins/
tt_scale_group_definition.rb
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] Scale Group Definition (1.0.0) — 22 February 20
Postby Rich O Brien » Fri Feb 22, 2013 4:43 pm
:thumb:
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby Chris Fullmer » Fri Feb 22, 2013 4:52 pm
Cool Thom, thanks!
User avatar
SketchUp Team
SketchUp Team
Postby dtrarch » Fri Feb 22, 2013 7:20 pm
TT
FYI:
SU 8 PRO latest
Only shows for components and no menu on selection ( rt clk)
Does not show on groups selected (contex rt click)
Does not show in plugins/tt menu
(all tt others do)
TT lib 2.7.1
file exists in SU plugins
dtr
dtrarch
Premium Member
Premium Member
Postby thomthom » Fri Feb 22, 2013 7:50 pm
Did you install the RBZ package properly?
If you only copied the RBZ file to the plugins folder you did it wrong. See link under download button.
User avatar
PluginStore Author
PluginStore Author
Postby dtrarch » Fri Feb 22, 2013 9:27 pm
Hi TT
Yes installed properly as below
Installed using SU Windows/preferences/System preferences etc
As required for .rbz plugins
dtr
dtrarch
Premium Member
Premium Member
Postby dtrarch » Fri Feb 22, 2013 9:42 pm
TT
Double check
.rbz install confirms install but does not show-up in the extensions list.
When the .rbz is re-named .zip and opened only the .rb file is there.
No tt_folder exists or icons
dtr
dtrarch
Premium Member
Premium Member
Postby thomthom » Sat Feb 23, 2013 1:06 am
It is not supposed to appear in the Extension list - didn't implement that feature.
It also doesn't have any support folders, it's just the .rb file.
There is only one menu item, when you right click a single group.
User avatar
PluginStore Author
PluginStore Author
Postby dtrarch » Sat Feb 23, 2013 1:28 am
TT
I created 2 groups
1-solids
2-non solid
Rt click on either shows your menu grey'd out
here is the file :( :thumbd:
dtr
dtrarch
Premium Member
Premium Member
Postby thomthom » Sat Feb 23, 2013 1:41 am
Yes? Everything is working exactly as expected. None of the groups are scaled, so there is no way it can scale the definition.
I suspect you might be expecting a different result from what this plugin actually does.
Have you used the native Scale Definition feature that is available to components?
User avatar
PluginStore Author
PluginStore Author
Postby dtrarch » Sat Feb 23, 2013 3:05 am
TT
Right on
OK now
Apologies for all the fuss.
Someone scrubbed a previous reply.
Thx a bunch
dtr
dtrarch
Premium Member
Premium Member
Postby bagatelo » Wed Jul 24, 2013 2:14 pm
This plugin can be used for entire scene? This is because your plugin "CleanUp" sometimes delete faces and edges too small...
User avatar
bagatelo
Postby thomthom » Wed Jul 24, 2013 3:17 pm
No, it works only on selected group. But can you not use the Tape Measure tool?
Sent from my LT25i using Tapatalk 2
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: Bing [Bot], carlossantmo, Google Bot, hq manh and 9 guests
Visit our sponsors:
