[Plugin] 3D Text Editor
Postby thomthom » Tue Feb 19, 2013 9:04 pm
Overview
This plugin started out as part of BaseCamp 2012 coding challenge when I was given the keyword "Text Editor" to write a plugin around.
After BaseCamp I developed it further, improving it.
Access
Draw > Editable 3d Text
3D Text > Context Menu > Edit Text
Requirements
  • SketchUp 7 or newer - ( Other versions untested )
  • Internet Explorer 9 or newer - ( Other versions untested )
  • TT_Lib2 (v>=2.7.0)
Guide: How to install RBZ Files
Get the latest version from the SCF PluginStore http://sketchucation.com/resources/plug ... texteditor
Download
Footprint
<Sketchup>/Plugins/
tt_texteditor.rb
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] 3D Text Editor (1.0.0) — 19 February 2013
Postby nickchun » Tue Feb 19, 2013 9:11 pm
This looks like a much awaited improvement to 3D text. I will try it out ,thanks a lot.
nickchun
Postby d12dozr » Tue Feb 19, 2013 9:27 pm
Does it work with Text that has been created with the native 3D Text tool?
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Postby gilles » Tue Feb 19, 2013 9:32 pm
Well I have play a little with it on Mac and it is ok, just remove material if you have one applied.
Note: There was nothing else in the model.
User avatar
gilles
Top SketchUcator
Postby gilles » Tue Feb 19, 2013 9:34 pm
d12dozr wrote:Does it work with Text that has been created with the native 3D Text tool?
Not for me.
User avatar
gilles
Top SketchUcator
Postby thomthom » Tue Feb 19, 2013 11:12 pm
No. And there is no way I can make it do so either because the native tool just creates a group with some mesh and there is nothing to extract the original text from.
gilles wrote:Well I have play a little with it on Mac and it is ok, just remove material if you have one applied.
No crash? :shock:
...if the crash turn out to be only on my machine I'll cry - as I would have spent hours trying to fix it. :s
Did you apply the material on the outside or inside the text group?
User avatar
PluginStore Author
PluginStore Author
Postby gilles » Wed Feb 20, 2013 1:37 am
Inside, then editing material just disappear. Seems to work fine.
User avatar
gilles
Top SketchUcator
Postby thomthom » Wed Feb 20, 2013 9:35 am
Apply it to the outside and you should be fine. The geometry is constantly recreated.
User avatar
PluginStore Author
PluginStore Author
Postby TIG » Wed Feb 20, 2013 10:38 am
You can make a MAC crash by specifying a 3dtext font-name that doesn't exists - on a PC it simply reverts to using the last used font-name.
So is your MAC crashing issue caused by assembling your list of fonts that is somehow including some that are inaccessible to Sketchup?
The MAC seems to keep its fonts in various places and perhaps Sketchup doesn't look for fonts from every location?
Or perhaps it's using 'Xxxx' when it's really named 'Xxxx Bold'?
It's easy enough to test on a MAC, by running a line of code on the Ruby Console that contains:
a real-font name ['Helvetica'] >>> 3dtext
a certainly non-existent font-name ['TT_foobar'] >>> crash
a suspect font-name [perhaps tested in turn from each finder-found 'font' directory, or with alternative 'naming' like 'Xxxx'/'Xxxx Bold' etc] >>> 3dtext or crash ?
If you find it's a folder of fonts that's getting listed but actually not being searched by Sketchup, then somehow exclude that folder from the listing process; or if it's 'Xxxx'/'Xxxx Bold' somehow recode to ensure full name is got, not it's 'Generic' name ??
User avatar
Global Moderator
Postby thomthom » Wed Feb 20, 2013 10:44 am
I got crashes when using a font that existed on the Mac.
User avatar
PluginStore Author
PluginStore Author
Postby pilou » Wed Feb 20, 2013 11:36 am
Some problems of visibility on V7 XP :)
(Old Explorer ? )
Speedy Galerie
User avatar
Top SketchUcator
Postby thomthom » Wed Feb 20, 2013 12:20 pm
Yes. Your Explorer is way too old. I doubt I'll make anything that's compatible with anything older than IE9 from now on. It's just too much work.
User avatar
PluginStore Author
PluginStore Author
Postby pilou » Wed Feb 20, 2013 12:24 pm
As I have not more modern than IE6 ;)
This if needing will work on another computer :)
Speedy Galerie
User avatar
Top SketchUcator
Postby thomthom » Wed Feb 20, 2013 12:25 pm
Pilou wrote:As I have not more modern than IE6 ;)
How are you even able to navigate websites with such an old browser?
User avatar
PluginStore Author
PluginStore Author
Postby jolran » Wed Feb 20, 2013 12:39 pm
+1
lot of work(forIE7). CSS sheet grows large!
OT:
I'm trying to make IE8 compatible dialog, but when reading this I might jump up one step.
You are still sticking to CSS2? I havent dared touching any CSS3 stuff yet,
but some are available to IE9 by the looks of it.
Plugin looks handy BTW :D :thumb:
User avatar
jolran
PluginStore Author
PluginStore Author
Postby pilou » Wed Feb 20, 2013 12:42 pm
I don't use it for navigate! ;) It's just a spleeping one :)
Speedy Galerie
User avatar
Top SketchUcator
Postby thomthom » Wed Feb 20, 2013 12:46 pm
I'm using some CSS3 features. Gradients, rounded corners and other things. But generally the more stable CSS3 features. I have a plugin in the works, which will require IE10 - it allows you to install plugins by dragging files into a webdialog window.
IE has lost a lot of users - and Microsofts automatic updates are starting to make it's effect as well as they try hard to push users to keep IE up to date. I would only concern myself about anything older than IE9 if I really had a good reason - like if I made a commercial plugin where a significant amount of users has older systems.
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Wed Feb 20, 2013 12:51 pm
Pilou wrote:I don't use it for navigate! ;) It's just a spleeping one :)
Gotcha. Well, I hope you one day can upgrade. Because there really isn't much I can do with IE6. But XP supports older IE versions than IE6, why not just let it update?
It's 11 years old - time to let it die. Even Microsofts wants it gone: http://www.ie6countdown.com/
User avatar
PluginStore Author
PluginStore Author
Postby jolran » Wed Feb 20, 2013 1:05 pm
Thanks for the info.
I will have to rethink about my css support then. I think your philosophy is sound.
And yeah! I had IE8 on my computer. And overnight "Badabing!" it became IE9.
Just like that :)
Sorry sorry, back to the plugin discussion.
User avatar
jolran
PluginStore Author
PluginStore Author
Postby TIG » Wed Feb 20, 2013 3:34 pm
thomthom wrote:I got crashes when using a font that existed on the Mac.
BUT is the 'font-name' you pass from your tool the exact same name as the MAC reports?
Or is that font perhaps in a fold-folder that Sketchup doesn't look-in, but your script does ?
E.g. some user or xfonts thing ?
User avatar
Global Moderator
Postby pilou » Wed Feb 20, 2013 3:48 pm
I am romantic, attached to the old things! :)
For 99 % my old one is sufficient! :enlight:
I don't see any major advantage to install new things ... except for launch your very elabrated plugins :)
For this if needing i can use other modern computers! :roll:
Speedy Galerie
User avatar
Top SketchUcator
Postby Dave R » Wed Feb 20, 2013 3:51 pm
Thomas, this is very cool. I'm using it on my MacBook Pro with 10.6.8 with no problems.
User avatar
Global Moderator
Postby thomthom » Wed Feb 20, 2013 3:55 pm
Dave R wrote:Thomas, this is very cool. I'm using it on my MacBook Pro with 10.6.8 with no problems.
So my message box warning is just an annoyance then... :shock: :?
User avatar
PluginStore Author
PluginStore Author
Postby Dave R » Wed Feb 20, 2013 3:59 pm
It doesn't bother me that much. :D
It may cause crashes later. I haven't used it that much.
User avatar
Global Moderator
Postby thomthom » Wed Feb 20, 2013 4:10 pm
I'll let it be like this for a while and wait for the mayhem.
User avatar
PluginStore Author
PluginStore Author
Postby Dave R » Wed Feb 20, 2013 4:41 pm
Be sure, I'll let you know.
User avatar
Global Moderator
Postby Ben Ritter » Wed Feb 20, 2013 8:32 pm
Thomthom, a very appreciative thank you.
Ben Ritter
Postby Dave R » Wed Feb 20, 2013 10:04 pm
Thomas, I played with it a little more on my Mac and the only thing I can find is the close button doesn't do anything. No biggie for me. I'm flexible and can close it with the X button at the top left.
User avatar
Global Moderator
Postby pilou » Thu Feb 21, 2013 9:13 am
Seems another friendly systems than IE exist for old computers or it's the same?
here by Kiril2008
Speedy Galerie
User avatar
Top SketchUcator
Postby thomthom » Thu Feb 21, 2013 9:14 am
Dave R wrote:Thomas, I played with it a little more on my Mac and the only thing I can find is the close button doesn't do anything. No biggie for me. I'm flexible and can close it with the X button at the top left.
hm... that's odd. Anything in the Ruby Console?
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: aschmitz, GauthierDk, ivoadriel, mikeltsr, naser712, spiteo25, vmask and 11 guests
Visit our sponsors:
