[Plugin] Smoothstep Animation
I made as well some small change to the script, I hope you don't mind.
Added support of saving the Export Property's to the Model.
If you cancel the export dialog or the save dialog the script stops instantly.
And reduced the filenumber padding to 6 numbers.
And my first Animation with Properanimation + SmoothstepAnim http://www.youtube.com/watch?v=agCUtjEJssM
Is it a similar plugin to this one http://forums.sketchucation.com/viewtopic.php?f=323&t=33417 ?
thanks jackson
@jakson said:
Thanks Jackson, I wish I can learn to do those scripts too
uploaded another test...take care
GREAT!!!
Best plugin ever!!
Solved all my problems.Congratulations!!!
Quicktime all the way. It works fast and does a very good job.
Thank you very much : )
i think it very work
Wow, great!!!
Whaat, many many thanks for this and the person who replied to my post solving my little artifact problem that the programmers appeared not to be interested in fixing. Great script!
how to install on mac..?
same as any .rb files & theres lots of info on this forum.
download from the first post in this thread, move to 'plugins' folder
if it's hidden you can paste this into 'Ruby Console' under 'Window' menu in Sketchup`open "/Library/Application Support/Google SketchUp 8/SketchUp/Plugins"`
, then hit return/enter
drag the ruby in and restart SU.
john -
thanks for the brilliant plugin!!
using Proper Animation, Smoothstep & Adobe Lightroom and getting an excellent video
is there any chance of adding support for exporting TIFF files?thanks
@pixero said:
Thanks for a great script.
Would it be possible to add an attribute to all the existing scenes in the model that they are "keyframes" and then add scenes for every frame in the animation with an attibute that they are "inbetweens" and add scene transition times according to your smoothstep script.
The script should then be able to delete all the "inbetweens" if you want to change the animation but leave the "keyframes" intact.
I believe this would make it work with external renderers.
What do you think, is it doable?dear sir ,
i m pritish from india , trying to render animation with vray can you make tutorial or may be some image/video format to explain your thoughts,it will be helpful .
waiting for your replay.
thanks in advance.regards,
pritish -
I have been using this plugin for a while but have been running into a few problems, particularly on my PC (Mac to lesser extent). When generating frames, sometimes the frame generation can hang for a considerable amount of time. Standard frames will take a minute or two and then there will be a rogue frame that takes 20mins! Sometimes even as much as an hour! This ain't good. Seems to happen more at HD resolutions. It makes video generating times completely unpredictable.
Some sort of feature to universally number frames so that the animation can be stopped/started or "farmed" to other computers without messing up the frame sequence would also be fantastic.
I know this plugin was written a while ago but I am just hoping Whaat that you will relook at it again because it is a very useful script for my line of work...
I see that the flow of additions to this post has slowed down. However, I've just read everything from the very beginning and curious if there is any further development on allowing this to work with rendering soft and plugins.
I have searched SketchUcation, Google and spent too much time looking for an answer to the question that too many are asking. How to make smooth animation from SU scene camera positions. I have seen Rendering programs make smooth camera position transitions but cannot find the plugin that makes this an automatic feature for animation exports from SU. Here is an example of non smooth camera positions and I'm looking for the trick that avoids these choppy positions between camera points. Could this plugin one day help?
I'd like to render animations with Thea and think this is really close to what we are looking for.
Youtube Video -
Hi Chris, do you mean Quicktime pro? And can you add still photos in between video clips or would you need to import the quicktime edited video into iMovie and do that in there? Thanks, best regards, Sally
Can it be that exporting animations via write_image is slower than using regular export?
Currently I am writing the connection to RenderPal, our renderfarm manager, and it seems that using this method for exporting is taking much more time.I observed that when using the the regular export, the 3d ui is completely paused. Maybe this might speed things up? But I was not able to pause it myself. Did not find a ruby function for that.
Hope somebody can enlighten me a bit.
Greetings
Andreas -
What file format are you using? What anti-aliasing and compression options are you using? Both of these can slow the export.
For both tests I used the same options. PNG and 1.0 compression. Anti aliasing also turned on.
Perhaps the problem is, for write_image() Sketchup has to create the frame twice. Once for the ui to make the geometry visible including all shadows and stuff and another time when exporting the image. If that is the case then it would be good the have the possibility to shut off the ui during animation export.
