SketchUcation Plugin Store
Help creating a 3D model of a hotwire cut airfoil.
Welcome! Ask and get answered - or just introduce yourself.
Postby GreenAce92 » Wed Aug 08, 2012 6:13 pm
Hello All,
I developed this aircraft as a proof of concept of an Ultralight that I designed. I wanted to create plans for it so that others may build it as well. I am having troubles figuring out how to create the airfoil you see it isn't simply a "draw airfoil - extrude - scale other end".
The way this airfoil is produced is by taking two templates, one for the root chord of the wing ( center ) and one for the tip chord of the wing ( wing tips ). Then by use of a hotwire cutter, the airfoil is created by basically tangential cutting, so you see, by using a blend of both a washout of 2 degrees and a 0 degree incidence airfoil, you get a twisting "washout" effect.
I don't know how to make something like this in sketchup, can someone help me out?
Here are the airfoils which I drew myself.
Regards,
Jacob Cunningham
GreenAce92
Name: Jacob Cunningham
Re: Help creating a 3D model of a hotwire cut airfoil.
Postby sdmitch » Wed Aug 08, 2012 7:19 pm
The main wing can be created in the same manner as I created this tail section.
http://sdmitch.blogspot.com/
User avatar
sdmitch
Operating system: Windows
SketchUp version: 8
License type: Free
SketchUp use: hobby
Level of SketchUp: Beginner
Postby GreenAce92 » Fri Aug 24, 2012 2:28 am
Hello Sam,
I watched your video. Unfortunately my wing is not as simple as your wing.
If you imagine the two templates above spaced 18" from each other, then a hot wire traces these two shapes, you can see how this shape is not something that can just be made by "scaling" one side, it is a shape that changes across the entire span of the wing.
One method I can think of is to cut sections from the wings and then trace those sections, align them and join them with the "draw-sandbox" tool but that defeats the purpose of designing since that would require a product that already exists to be reverse-designed into a CAD model.
I appreciate the response however.
Is it not possible to have two different shapes, then some sort of command creates a solid object as if a skin was rolled around these objects? Take an ellipse and a square then create a skin that joins these two shapes into a vase like structure.
Regards,
Jacob Cunningham
GreenAce92
Postby Gaieus » Fri Aug 24, 2012 2:38 am
Here is a method using only native SU tools (Arc, PushPull and Scale)
User avatar
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Level of SketchUp: Advanced
Postby mac1 » Fri Aug 24, 2012 4:21 am
AIRFOIL.skp
Take a look at Fredos curviloft tool. The attached used your info above, F spline fit to those, set scale of bottom to the 3" ref, did not set 2" of the top, 18 " separation. There are question about the station and position relation. Curves need clean up or provide x.y.z and station info. :?
mac1
Top SketchUcator
Postby mitcorb » Fri Aug 24, 2012 1:10 pm
@Gaieus:
That video has trouble starting.
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
SketchUp use: architecture
Level of SketchUp: Intermediate
Postby mac1 » Fri Aug 24, 2012 2:45 pm
Did for me also but it did run>
mac1
Top SketchUcator
Postby mitcorb » Sat Aug 25, 2012 4:19 am
Well, it's an oldie but a goodie. I remember it when I hopped on at SU v6.
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
by Ad Machine » 5 minutes ago
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
Return to Newbie Forum
Who is online
Users browsing this forum: Bing [Bot] and 6 guests
