[Plugin] Scale Face to Target Area - TIG
Postby EarthMover » Tue Aug 07, 2012 2:26 pm
Is it possible through ruby (or does something exist) to scale a face to a desired area size? Let's say I draw an irregular shape which needs to be a specific square footage. Is it possible to have a plugin which let you click on the face and set a desired square footage and the face automatically scales to that area?
I'm drawing a bunch of different free form (lagoon style) pools for a client, but have a target square footage the shapes. I can get close with trial and error and scale tool, just thought it would be nice to do it exact through a script.
EDIT - Plugin attached. Thanks TIG.
EDIT: by TIG - code fixed for all unit types !
TIG Donations==
Content Creator at Skapeup
User avatar
EarthMover
Premium Member
Premium Member
Re: [REQ] - Scale Face to Target Area
Postby thomthom » Tue Aug 07, 2012 3:35 pm
Code: Select all
module TT_ScaleToArea
  def self
.scale_face( face, target_area )
    unit_ratio = '1'.to_l ** 2
    target_area_inch
= target_area * unit_ratio
    ratio
= target_area_inch / face.area
    pt
= face.bounds.center
    tr
= Geom::Transformation.scaling( pt, ratio )
    face.parent.entities.transform_entities( tr, [face] )
TT_ScaleToArea.scale_face( Sketchup.active_model.selection[0], 4000 )
target_area is numeric input in the current model units.
User avatar
PluginStore Author
PluginStore Author
Postby TIG » Tue Aug 07, 2012 3:49 pm
Here's my version, with dialog...
Code: Select all
require 'sketchup.rb'
module TIG
  ### scales a select face about its center to a new area, in current uinits.
  def self.scale_face()
   model=Sketchup.active_model
   es=model.active_entities
   ss=model.selection
   fa=nil
   fa=ss[0] if ss[0]
   unless fa && fa.is_a?(Sketchup::Face)
     UI.messagebox("Scale_Face:\n\nPreSelect ONE FACE !")
     return nil
   ar=fa.area
   mo=model.options["UnitsOptions"]
   p mo["LengthFormat"]
   case mo["LengthUnit"]
   when 0
    units="in"
    if mo["LengthFormat"]==2 #Engineering trap ">>'
      units="ft"
      ar=ar/12.0/12.0
   when 1
    units="ft"
    ar=ar/12.0/12.0
   when 2
    units="mm"
    ar=ar*25.4*25.4
   when 3
    units="cm"
    ar=ar*25.4*25.4/10/10
   when 4
    units="m"
    ar=ar*25.4*25.4/1000/1000
   else
    units="??"
   rs=inputbox(["New Area [sq "+units+"]:        "], [ar], "Scale_Face")
   return nil unless rs
   na= rs[0]
   na= -na if na < 0
   unless na>0
     UI.beep
     return nil
   ro=Math.sqrt(na/ar)
   pt=fa.bounds.center
   tr=Geom::Transformation.scaling(pt, ro)
   model.start_operation("Scale_Face")
    es.transform_entities(tr, fa.vertices)
   model.commit_operation
  UI.menu("Plugins").add_item("Scale_Face"){self.scale_face()} unless file_loaded?(__FILE__)
  file_loaded(__FILE__)
Copy/paste code into a script in the Plugins folder named 'TIG-scale_face.rb', and restart Sketchup. Run it from the menu item or by typing TIG.scale_face in the Ruby Console...
EDIT: Typo fixed in menu code !!!
EDIT: Improved Unit/Fractional/Engineering handling - see 1st post in the thread for the .rb version.
User avatar
Global Moderator
Postby thomthom » Tue Aug 07, 2012 4:14 pm
na = -na if na < 0
Why not just use #abs ?
na = na.abs
User avatar
PluginStore Author
PluginStore Author
Postby TIG » Tue Aug 07, 2012 4:31 pm
thomthom wrote:na = -na if na < 0
na = na.abs
No reason.
I assume you meant na=results[0].abs as a one-step solution.
I was just writing it on the fly and needed to trap for a negative or zero reply...
Incidentally, I noted that you transformed the face while I did the face.vertices, is there any advantage in either way?
Presumably transforming the face changes its vertices and what they are connected to anyway, and conversely transforming the vertices transforms the face and also whatever they are connected to also ?
User avatar
Global Moderator
Postby thomthom » Tue Aug 07, 2012 4:47 pm
TIG wrote:Incidentally, I noted that you transformed the face while I did the face.vertices, is there any advantage in either way?
I'd expect that under the hood, when you feed entities to #transform_entities it collects the vertices - so [face] and face.vertices should have the exact same effect. I kind of liked face.vertices instead of wrapping the face in an array - feel it reads better as the brackets isn't so easy to see immediately.
User avatar
PluginStore Author
PluginStore Author
Postby TIG » Tue Aug 07, 2012 5:02 pm
Actually just face should work as well as [face] because the transformation is the first argument and you can then pass an array OR a series of arguments, so 'face' would be seen as the first one anyway ? ...
User avatar
Global Moderator
Postby thomthom » Tue Aug 07, 2012 5:17 pm
API-doh!
User avatar
PluginStore Author
PluginStore Author
Postby EarthMover » Tue Aug 07, 2012 9:31 pm
:thumb: You guys both rock! THANKS so much!
User avatar
EarthMover
Premium Member
Premium Member
Postby jorge2011 » Wed Aug 08, 2012 3:20 am
jorge2011
Postby thomthom » Wed Aug 08, 2012 8:47 am
jorge2011 wrote:You see this plugin?
http://rubits.com/play.php?file=areascale
That's nice looking. The VCB is a nice way to control it. But I think $10 is too much for such a trivial script. :?
User avatar
PluginStore Author
PluginStore Author
Postby EarthMover » Wed Aug 08, 2012 2:18 pm
TIG, having an issue with your script loading properly. I copied and pasted the code exactly into a notepad file and named it - TIG-scale_face.rb. Upon loading Sketchup, I get no errors, but none of my toolbars load. When I delete the script, all the toolbars load again.
User avatar
EarthMover
Premium Member
Premium Member
Postby EarthMover » Wed Aug 08, 2012 3:43 pm
Thom, excuse my ignorance, but how would I going about testing your code?
User avatar
EarthMover
Premium Member
Premium Member
Postby thomthom » Wed Aug 08, 2012 4:15 pm
EarthMover wrote:Thom, excuse my ignorance, but how would I going about testing your code?
Sorry Adam, I typed it up and posted in a hurry. You'd put it in a .rb file and form the console invoke: TT_ScaleToArea.scale_face( Sketchup.active_model.selection[0], 4000 )
Didn't have the time to add UI.
User avatar
PluginStore Author
PluginStore Author
Postby TIG » Wed Aug 08, 2012 4:53 pm
The code is now tested and working version... I edited the original ! viewtopic.php?p=419936#p419936
Stupid typo unless.file_loaded? instead of unless file_loaded?
I added the UI as an afterthought and never tested it sorry!
User avatar
Global Moderator
Postby EarthMover » Thu Aug 09, 2012 3:11 pm
Thanks TIG. It works as long as I am using a decimal unit type. With fractional units, it deletes everything in the model. Not sure why, just have to remember to switch the units before using the plugin. Thanks again. I'll update the first post with the rb file.
Also it is still stating inches in the dialog even when the units are feet. No big deal though. Works for what I need. Thanks again! :thumb: :thumb:
User avatar
EarthMover
Premium Member
Premium Member
Re: [Plugin] - Scale Face to Target Area - TIG
Postby TIG » Thu Aug 09, 2012 3:21 pm
I'll adjust the code... I did type it on the fly...
User avatar
Global Moderator
Postby EarthMover » Thu Aug 09, 2012 4:18 pm
If you have time. If not, no worries. I just figured I'd mention the issues in case anyone else needed to use the plugin.
User avatar
EarthMover
Premium Member
Premium Member
Postby TIG » Thu Aug 09, 2012 4:26 pm
I've updated the .rb in your post and edited the post's text to match [hope you are OK with that ;) ]
It now handles all Unit-types/Fractional/Engineering etc properly.
One oddity is that 'Engineering' displays on screen in 'feet', but the API unit-type [LengthUnit] is left in 'inches' [0] - unlike all other types where the 'LengthUnit' matches the displayed-unit.
Anyway it now works for all combos... I hope :?
User avatar
Global Moderator
Postby EarthMover » Thu Aug 09, 2012 5:12 pm
Works great now. Thanks again.
User avatar
EarthMover
Premium Member
Premium Member
Postby hebeijianke » Thu Aug 09, 2012 6:36 pm
TIG wrote:I've updated the .rb in your post and edited the post's text to match [hope you are OK with that ;) ]
This plug-in only applies to the quadrangle
hebeijianke
Postby TIG » Thu Aug 09, 2012 7:04 pm
NO, it works on any face.
The selected face is simply scaled to have the desired area.
The dialog shows the current area in current units.
You enter the new area and OK.
The selected face is made to have that area.
So if it's a square, a star or a circle it doesn't matter...
User avatar
Global Moderator
Postby bmike » Thu Aug 09, 2012 8:31 pm
This is a great little plugin.
Any chance to make it work in square ft, when my units are set to Architectural?
Or do I need to divide by hand first...?
User avatar
bmike
Postby EarthMover » Thu Aug 09, 2012 8:34 pm
Works on almost any face. Faces created by the freehand tool seem to fail to resize properly. Not sure why.
User avatar
EarthMover
Premium Member
Premium Member
Postby jorge2011 » Thu Aug 09, 2012 9:52 pm
YES thomthom. You are right, it's a plugin with a high cost.
I made the post, the plugin is very interesting, and has features that can be added to the free version plugin of sr. TIG.
jorge2011
Postby TIG » Fri Aug 10, 2012 9:46 am
bmike wrote:This is a great little plugin.
Here's a version of the code for users who want to work in feet OR inches [any kind] and see 'sq ft' areas; it also does 'sq m' areas if the user is using any metric units [m/cm/mm]... Copy the code and paste it into the .rb file using Notepad or similar plain-text editor - overwriting all of the original code...
Code: Select all
module TIG
### scales a selected face about its center to a new area, in current units.
      ss=model.selection
      fa=nil
      fa=ss[0] if ss[0]
         return nil
      ar=fa.area
      if mo["LengthUnit"] > 1 ### metric
         units="m"
      else ### ft/"
         units="ft"
         ar=ar/12.0/12.0
      na= rs[0]
      na= -na if na < 0
      unless na>0
         UI.beep
         return nil
      ro=Math.sqrt(na/ar)
      pt=fa.bounds.center
User avatar
Global Moderator
Postby EarthMover » Fri Aug 10, 2012 4:45 pm
Thanks TIG. That's even better!
User avatar
EarthMover
Premium Member
Premium Member
Postby TIG » Fri Aug 10, 2012 4:46 pm
Do you want to add an alternative version .rb in the first post ?
User avatar
Global Moderator
Postby EarthMover » Fri Aug 10, 2012 5:10 pm
Sure, I can. If you feel like dropping it in it's own thread for proper indexing, let me know and I'll remove the bracketed plugin wording. Or feel free to edit it yourself if need be. I don't mind at all.
User avatar
EarthMover
Premium Member
Premium Member
Re: [Plugin] Scale Face to Target Area - TIG
Postby irich » Thu Sep 27, 2012 9:27 pm
Hi guys!
Thank you for this plugin it’s very very useful.
My question is, is it possible to make it scale texture on face too?
If you for example have one projected texture on face.
irich
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: 3228, Google Bot, HyperBioEnzo, koxu, MZ090188 and 15 guests
Visit our sponsors:
