Hi All
Facing a small difficulty to import STEP ( Stp ) file, I would ask to our " Code Masters ", if they know
a way to convert this kind of file ?
Many thanks.
Pierre
STEP file converter
• Page 1 of 1
STEP file converterHi All
Facing a small difficulty to import STEP ( Stp ) file, I would ask to our " Code Masters ", if they know a way to convert this kind of file ? Many thanks. Pierre La Connaissance n'a de valeur que partagée
Re: STEP file converterUse Free-CAD
Import / Export! STEP, IGES, OBJ, DXF, SVG, STL, DAE, IFC or OFF Seems you can use some one for SU Or Moment of inspiration but it's not the same price! But you can send me the file in MP The free 123D also 123D can IMPORT (Open) 123D, SKP, SAT,OBJ, DWG (3D solids), STP, 123C (Mesh content). 123D can export (Save As): STL, SAT, DWG, STP and its native 123D. you can also publish an image.
Re: STEP file converterThanks Pilou,
I'll test freecad and then convert the file. Pierre La Connaissance n'a de valeur que partagée
Re: STEP file converterhello MALAISE
Please , take a look on the next file , it was something i have explain in french forum It's possible to convert file in IGES STEP SKP STL with free soft and plugins . STEP file is import with FreeCAD a backup is done in STL STL is import in SKETCHUP 8 with plugin jf_stl_importer.rb / Jim Foltz / cleaning is done with plugin deletecoplanaredges.rb des conversions sont possibles entre IGES STEP SKP STL ( EN UTILISANT DES LOGICIELS OU PLUGINS GRATUITS ) PREMIER TEST LES BASES : ----------- J'avais Autodesk 123D Beta je viens aussi de télécharger FreeCAD comme me l'a suggéré PILOU . DETAIL DU TEST EFFECTUE ----------------------- dessin d'une piéce avec Autodesk 123D Beta sauvegarde en STEP ( possible directement en STL et IGES ) Import du STEP dans FreeCAD export en STL ( ce logiciel autorise de nombreuses extensions en import et en export ) import du STL dans SKETCHUP 8 ( plugin jf_stl_importer.rb de Jim Foltz ) nettoyage ( plugin deletecoplanaredges.rb ) Le résultat est NICKEL Le seul souci comme évoqué par PILOU étant la segmentation des cercles et arcs . BONS TESTS A TOUS Please, register (free) to access all the attachments on the forums.
sketch is done with SKETCHUP file is export in IGES with plugin iges_export.rb the backup is done in STEP avec FreeCAD STEP file is open with 123D BETA Manip inverse [/color] DEUXIEME TEST dessin SKETCHUP export en IGES avec le plugin d'export IGES ( plugin iges_export.rb ) transformation en STEP avec FreeCAD lecture du STEP avec Autodesk 123D Beta NICKEL x 2 chri Please, register (free) to access all the attachments on the forums.
Re: STEP file converterI use SimLab Composer. I have tried the rest, Alibre, ViaCad, 123D beta and others programs, and Simlab does the best conversions. But to be honest, nothing is going to turn a high poly model into something that Sketchup is not going to choke on.
Ken Government rushes to help the irresponsible and does little for the responsible.
Re: STEP file converterGreat explanation Chri!
Exactly what I was looking for Pierre La Connaissance n'a de valeur que partagée
SketchUcation One-Liner AdvertsNeed SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Premium Members get 20% discount!
• Page 1 of 1
