SketchUcation Premium Membership
STEP file converter
STEP file converter
Postby MALAISE » Mon Jul 02, 2012 4:14 pm
Hi All
Facing a small difficulty to import STEP ( Stp ) file, I would ask to our " Code Masters ", if they know
a way to convert this kind of file ?
Many thanks.
Pierre
MALAISE
Re: STEP file converter
Postby Pilou » Mon Jul 02, 2012 4:42 pm
Use Free-CAD
Import / Export!
STEP, IGES, OBJ, DXF, SVG, STL, DAE, IFC or OFF
Seems you can use some one for SU ;)
Or Moment of inspiration but it's not the same price! ;)
But you can send me the file in MP ;)
The free 123D also ;)
123D can IMPORT (Open) 123D, SKP, SAT,OBJ, DWG (3D solids), STP, 123C (Mesh content).
123D can export (Save As): STL, SAT, DWG, STP and its native 123D. you can also publish an image.
Speedy Galerie
User avatar
Pilou
Top SketchUcator
Operating system: Windows
SketchUp version: 6
License type: Free
SketchUp use: hobby
Level of SketchUp: Advanced
Postby MALAISE » Tue Jul 03, 2012 9:53 am
Thanks Pilou,
I'll test freecad and then convert the file. :thumb:
Pierre
MALAISE
Postby chri » Tue Jul 03, 2012 6:45 pm
hello MALAISE
Please , take a look on the next file , it was something i have explain in french forum
It's possible to convert file in IGES STEP SKP STL with free soft and plugins .
STEP file is import with FreeCAD
a backup is done in STL
STL is import in SKETCHUP 8 with plugin jf_stl_importer.rb / Jim Foltz /
cleaning is done with plugin deletecoplanaredges.rb
des conversions sont possibles entre IGES STEP SKP STL
( EN UTILISANT DES LOGICIELS OU PLUGINS GRATUITS )
PREMIER TEST
LES BASES :
J'avais Autodesk 123D Beta
je viens aussi de télécharger FreeCAD comme me l'a suggéré PILOU .
DETAIL DU TEST EFFECTUE
dessin d'une piéce avec Autodesk 123D Beta
sauvegarde en STEP
( possible directement en STL et IGES )
Import du STEP dans FreeCAD
export en STL
( ce logiciel autorise de nombreuses extensions en import et en export )
import du STL dans SKETCHUP 8
( plugin jf_stl_importer.rb de Jim Foltz )
nettoyage
( plugin deletecoplanaredges.rb )
Le résultat est NICKEL
Le seul souci comme évoqué par PILOU étant la segmentation des cercles et arcs .
BONS TESTS A TOUS
User avatar
chri
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby chri » Tue Jul 03, 2012 6:49 pm
hello
sketch is done with SKETCHUP
file is export in IGES with plugin iges_export.rb
the backup is done in STEP avec FreeCAD
STEP file is open with 123D BETA
Manip inverse [/color]
DEUXIEME TEST
dessin SKETCHUP
export en IGES avec le plugin d'export IGES ( plugin iges_export.rb )
transformation en STEP avec FreeCAD
lecture du STEP avec Autodesk 123D Beta
NICKEL x 2
chri
User avatar
chri
SketchUp version: 8
License type: Pro
Postby Ken » Tue Jul 03, 2012 7:21 pm
I use SimLab Composer. I have tried the rest, Alibre, ViaCad, 123D beta and others programs, and Simlab does the best conversions. But to be honest, nothing is going to turn a high poly model into something that Sketchup is not going to choke on.
Ken
Government rushes to help the irresponsible and does little for the responsible.
User avatar
Ken
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby MALAISE » Thu Jul 05, 2012 1:19 pm
Great explanation Chri!
Exactly what I was looking for :thumb:
Pierre
MALAISE
by Ad Machine » 5 minutes ago
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: crichlie, m0rfe0, Mads Olesen, radiacor, rodman100 and 12 guests
