SketchUcation Plugin Store
[Plugin] Geom Interpolated Curve ver. 1.3.
Postby kirill2008 » Thu Oct 22, 2009 8:47 pm
This plugin became obsolete but you can find all its functionality in 'Recursively Smoothed Curve' tool of 'LSS Toolbar 2.0' extension. It is still only a beta version, but this particular tool works stable enough. Find out more at viewtopic.php?f=323&t=47399
kirill2008
Re: [Plugin] Geometric curve smoothing ver. 1.1.
Postby remus » Thu Oct 22, 2009 10:05 pm
Very cool, particularly like the explanation lines :)
remus
Postby Pilou » Thu Oct 22, 2009 11:16 pm
Funny for curious caligraphy :)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
Operating system: Windows
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Level of SketchUp: Advanced
Postby Jörg » Fri Oct 23, 2009 6:41 am
very cool, kirill!!!!
:thumb: :thumb: :thumb:
Thank you very much!
Jörg
Postby notareal » Fri Oct 23, 2009 8:40 am
:thumb: I like it.
notareal
Thea Render
Postby Fletch » Sun Oct 25, 2009 7:39 pm
good idea...
I'm concerned that the word "Smooth" is already "taken" in SketchUp... and usually applies to a specific type of edge, so if we could come up with a better name for this tool, it may avoid confusion.
may I suggest "Curve Toy" or "Curve Control" or "Squishy Curve" or "Marilyn Monroe" :? I don't know... something unique.
Fletch
Twilight Render
Postby chango70 » Mon Oct 26, 2009 1:16 am
Very cool. What do you do with the explanation lines? can you manipulate the geometry with those lines? Sorry I am not with SU range.
chango70
Postby mitcorb » Mon Oct 26, 2009 3:07 am
Very interesting videos. I will have to review them again.
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
SketchUp use: architecture
Level of SketchUp: Intermediate
Postby kirill2008 » Mon Oct 26, 2009 6:23 am
Fletch wrote:I'm concerned that the word "Smooth" is already "taken" in SketchUp... and usually applies to a specific type of edge, so if we could come up with a better name for this tool, it may avoid confusion.
I agree. I like "Marilyn Monroe" :thumb: :)
Well maybe "Geom Interpolation" (long, but close to what it really is).
chango70 wrote:What do you do with the explanation lines? can you manipulate the geometry with those lines?
Unfortunately explanation lines are only to show, how intermediate vertices were modelled (lines are practically useless and there is no way to interact with them only to admire).
Actually it is necessary to implement 2 additional 'control lines' at the start and at the end of the initial opened curve to affect 1-st and last segment curvature (the same way as cubic spline). Closed curve does not need it.
And another issue: current version does not 'remember' control points across sessions also (the same as 'ctrlpnts.rb'). I'm on my way to implement such functionality.
kirill2008
Postby Panga » Mon Oct 26, 2009 9:02 am
Thanks a lot !! Very usefull for me.
Panga
Premium Member
Premium Member
Postby erikB » Mon Oct 26, 2009 10:20 am
Very usefull for me to ! :thumb:
Thanks,
erikB
User avatar
erikB
Postby kwistenbiebel » Mon Oct 26, 2009 11:25 am
Tremendously useful for me :)
It seems like a good plugin to make the curves as a start for a soap-skin-bubble session.
Thanks Kirill! :thumb:
kwistenbiebel
Postby ideas_arte » Tue Oct 27, 2009 8:56 pm
:berserk: :berserk: :berserk: :berserk:
This is amazing and very very helpful, thank you very much for your generosity.
greetings
ideas_arte
Re: [Plugin] Geom Interpolated Curve ver. 1.2.
Postby kirill2008 » Mon Jan 18, 2010 9:48 pm
In the current version (1.2.) the command name to launch the plugin was renamed to "Geom Interpolation..." to avoid confusions with other commands.
And now script recalls control points after opening the file which contains curve. I'm going also to add interactive control points editing (the same way as in ctrlpnts.rb).
kirill2008
Re: [Plugin] Geom Interpolated Curve ver. 1.3.
Postby Dave R » Sat Jan 30, 2010 1:05 pm
Kirill, thank you for this plugin.
Several I watched your videos demonstrating it and then tried to use it. I must be missing something because you seem to be able to make it do things I can't. Could you give a little basic training?
I can get the curve alright after setting the control points out. After that, I select Edit Geom Interpolated Curve... If I click on the left arrow key I get some additional points but no lines joining them to the points on the curve. Also, if I click on a control point and try to drag it, nothing happens. If I click on a control point and let go of the button, the next click creates a new point away from the first point as if placing a guide point with the Tape Measure tool. Nothing I do will let me edit the curve.
I've tried following the messages displayed at the bottom of the screen but with no luck. Could you give some guidance? Thank you.
Inspecting mirrors is a job I could easily see myself doing.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Postby chrisjk » Sat Jan 30, 2010 1:17 pm
Dave,
I have tried this and find it a bit hit and miss to pick a control point. You have to move the select tool around a fair bit until a tool tip says "Guide point". You can click on this and the curve turns red and a message in the status bar says "Feel free to pick a c_point to interact with" then clicking on that point allows you to move the point and the line will follow.
chrisjk
Postby Dave R » Sat Jan 30, 2010 1:52 pm
Thanks Chris. I did see that deal with the curve turning red and the message "Fill{sic} free to pick..." but even then I can't move the control point.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby chrisjk » Sat Jan 30, 2010 2:15 pm
Dave,
I don't know if it helps but here is a little video I made of using it.
http://www.youtube.com/watch?v=6dSNuvlzJwg
chrisjk
Postby kirill2008 » Fri Jun 22, 2012 4:21 pm
I think it would be interesting to check out the video of 'crvsmth.rb' revival:
Finally I decided to reanimate this ancient 'scripture' and make its use more intuitive this time... So now it is adapted into modernized 'LSS Toolbar' infrastructure and its reincarnation name is 'Recursively Smoothed Curve' tool.
For now 'pre-alpha' version of 'LSS Toolbar' is available. Feel free to use it at your own risk.
kirill2008
Postby Bob James » Fri Jun 22, 2012 5:43 pm
kirill2008 wrote:Finally I decided to reanimate this ancient 'scripture' and make its use more intuitive this time... So now it is adapted into modernized 'LSS Toolbar' infrastructure and its reincarnation name is 'Recursively Smoothed Curve' tool.
This is just downright awesome :thumb: :bounce:
"If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
"Bad is not good until worse happens" - Bob James
User avatar
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby notareal » Sat Jun 23, 2012 4:22 pm
Nice update!
notareal
Thea Render
Postby kirill2008 » Sun Jun 24, 2012 6:07 am
notareal wrote:Nice update!
Actually update is still under construction, I was just excited about the way it works and decided to share current stage :)
BTW, I'm a huge fan of Kerkythea :thumb: I use it very extensively and I'm very very happy with it! :enlight:
kirill2008
Postby pbacot » Sun Jun 24, 2012 7:48 am
Thankyou! How does one learn to use the tool (LSS toolbar)? I am just guessing and clicking and getting no results so far. Also the text fields are solid black.
User avatar
Top SketchUcator
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby kirill2008 » Sun Jun 24, 2012 10:05 am
pbacot wrote:Thankyou! How does one learn to use the tool (LSS toolbar)? I am just guessing and clicking and getting no results so far. Also the text fields are solid black.
I plan to make manuals after functionality update completion: there are 2 more tools are to be added in 'LSS Toolbar' and after their addition I'll start testing and documenting this plugin.
The reason, that 'LSS Toolbar' does not work on mac is that settings-dialog forms are not adapted yet for displaying by 'Safari' (default macOS browser, which SU uses to display web-dialog forms). I use pc at work and at home, so it'll be a bit tricky for me personally to make these dialog-forms work on mac too, but I'll try to do it anyway.
kirill2008
Postby mitcorb » Sun Jun 24, 2012 2:07 pm
Hi, kirill:
Your update video is very impressive.
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
Postby pbacot » Sun Jun 24, 2012 4:52 pm
I see. Thanks for the reply. I also found the black input fields is a problem on the Mac end that users need to sort out for themselves. http://forums.sketchucation.com/viewtopic.php?f=11&t=45382&hilit=black+dialog
But it's very impressive work!
User avatar
Top SketchUcator
SketchUp version: 8
License type: Pro
by Ad Machine » 5 minutes ago
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: bc28, bytor, dezmo, gerciowski, Google Feedfetcher, hebeijianke, Marcoprova, Norbay and 11 guests
