SketchUcation Plugin Store
[Code] Detect Window's VirtualStore
Postby thomthom » Wed Jun 13, 2012 3:30 pm
I started to look into what happens when you try to write to the plugins folder with SketchUp Ruby when the user doesn't have admin rights. Ruby will say that the files a writable so I was having a hard time finding out how I could detect if the folder was in the virtual store or not. Initial test indicate that this snippet is able to detect if a file or folder exist in the VirtualStore. (Hoping "VirtualStore" is not localized - I think MS stopped doing that from Vista and onwards and XP didn't have the virtualstore.)
Code: Select all
module FileHelper
  def self
.is_virtual?( file )
# (!) Windows check.
filename File.basenamefile )
filepath File.dirnamefile )
# Verify file exists.
unless File.exist?( file )
raise IOError"The file '#{file}' does not exist."
# See if it can be found in virtual store.
virtualstore File.joinENV['LOCALAPPDATA'], 'VirtualStore' )
path filepath.split(':')[1]
virtualfile File.joinvirtualstorepathfilename )
File.exist?( virtualfile )
  def self
.is_plugins_folder_virtual?
plugins_path Sketchup.find_support_file'Plugins' )
self.is_virtual?( plugins_path )
# module
From what I remember of comments on this forum a non-admin user must give himself access to the plugin folder in order to allow Ruby to write to it. I guess there is no way to make Ruby set these permission - taking care of the problem for the user?
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: [Code] Detect Window's VirtualStore
Postby thomthom » Thu Jun 14, 2012 2:58 pm
Can you read folder permissions via SU Ruby? And can these permissions be used to determine if a file is truly writeable or if it'll end up in the virtual store.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Thu Jun 14, 2012 3:06 pm
hm... if the file already exists it appear that Ruby avoids VirtualStore - so is there some system command one can issue to create a file?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Dan Rathbun » Thu Jun 14, 2012 3:30 pm
thomthom wrote:Can you read folder permissions via SU Ruby?
You should be able to. A directory has always been treated as a "kind" of file.
The mixin module FileTest can be mixed into your class, and is already mixed into class File.
Also there is the File::Stat class.
see the Ruby reference CHM.
ADD: and do not forget about Kernel::test()
User avatar
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: education
Postby thomthom » Fri Jun 15, 2012 10:17 am
Permission appear to be identical even though creating a file on the Win8 machine will put it in VirtualStore...
Win7 Admin
Code: Select all
#<File::Stat
  dev=0x2,
  ino=0,
  mode=040755,
  nlink=1,
  uid=0,
  gid=0,
  rdev=0x2,
  size=0,
  blksize=nil,
  blocks=nil,
  atime=Mon Jun 11 12:44:30 +0200 2012,
  mtime=Mon Jun 11 12:44:30 +0200 2012,
  ctime=Wed Aug 03 13:33:27 +0200 2011
Win8
Code: Select all
#<File::Stat
  dev=0x2,
  no=0,
  mode=040755,
  nlink=1,
  uid=0,
  gid=0,
  rdev=0x2,
  size=0,
  blksize=nil,
  blocks=nil,
  atime=Thu Jun 14 16:02:35 +0200 2012,
  mtime=Thu Jun 14 16:02:35 +0200 2012,
  ctime=Fri Jun 01 10:44:03 +0200 2012
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Fri Jun 15, 2012 11:49 am
I used "Run as Administrator" and SketchUp Ruby still wrote to VirtualStore... :?: :?:
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Fri Jun 15, 2012 1:13 pm
thomthom wrote:I used "Run as Administrator" and SketchUp Ruby still wrote to VirtualStore... :?: :?:
Seems that I didn't actually launch it as administrator - but when I actually did I found I could not drag and drop files from Explorer to a WebDialog.
(I'm allowing drag and drop of files to a webdialog for easy installation of Ruby plugins etc.)
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Dan Rathbun » Fri Jun 15, 2012 8:05 pm
So did "Run as Administrator" allow you to write files where you wanted, rather than the VirtualStore ??
And.. are you saying that file writing is even more of a P.I.T.B on Win8, than it was in previous versions ??
User avatar
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby thomthom » Sat Jun 16, 2012 1:44 am
Dan Rathbun wrote:So did "Run as Administrator" allow you to write files where you wanted, rather than the VirtualStore ??
Didn't try that - because my fileread was triggered by the drag and drop which was prevented. But it'd be worth testing.
Dan Rathbun wrote:And.. are you saying that file writing is even more of a P.I.T.B on Win8, than it was in previous versions ??
I don't know - I've always used an administrator account on Vista and Win7 with UAC disabled. I cannot compare because Win8 is the first Windows OS I've tried with default user access. I suspect it's the same as Win7 and Vista, but I need to verify this.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
by Ad Machine » 5 minutes ago
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: Chiefwoodworker, rv1974 and 6 guests
